1 #ifndef __CS_CDOFB_MONOLITHIC_H__ 2 #define __CS_CDOFB_MONOLITHIC_H__ 163 void *scheme_context);
179 void *scheme_context);
195 void *scheme_context);
void cs_cdofb_monolithic_set_sles(const cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to coupled the syste...
Definition: cs_cdofb_monolithic.c:1874
time step descriptor
Definition: cs_time_step.h:51
cs_boundary_type_t
Definition: cs_boundary.h:51
void cs_cdofb_monolithic_compute_implicit(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a monolithic approach and ...
Definition: cs_cdofb_monolithic.c:2224
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns...
Definition: cs_equation.c:2361
void * cs_cdofb_monolithic_free_scheme_context(void *scheme_context)
Destroy a cs_cdofb_monolithic_t structure.
Definition: cs_cdofb_monolithic.c:1839
void cs_cdofb_monolithic_init_common(const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_monolithic.c:1720
Definition: cs_defs.h:467
#define CS_UNUSED(x)
Definition: cs_defs.h:453
void * cs_cdofb_monolithic_init_scheme_context(const cs_navsto_param_t *nsp, cs_boundary_type_t *fb_type, void *nsc_input)
Initialize a cs_cdofb_monolithic_t structure.
Definition: cs_cdofb_monolithic.c:1747
Definition: cs_cdo_connect.h:74
Definition: cs_navsto_param.h:255
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
void cs_cdofb_monolithic_compute_theta(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition: cs_cdofb_monolithic.c:2483
static cs_real_t * cs_cdofb_monolithic_get_face_velocity(void *scheme_context)
Retrieve the values of the velocity on the faces.
Definition: cs_cdofb_monolithic.h:76
void cs_cdofb_monolithic_compute_steady(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the steady Navier-Stokes system with a CDO face-based scheme using a monolithic approach...
Definition: cs_cdofb_monolithic.c:1992
Definition: cs_defs.h:468
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return NULL if not find.
Definition: cs_equation.c:350
