1 #ifndef __CS_HHO_SCALEQ_H__ 2 #define __CS_HHO_SCALEQ_H__ 61 typedef struct _cs_hho_scaleq_t cs_hho_scaleq_t;
282 void *scheme_context);
298 void *scheme_context);
Definition: cs_equation_common.h:61
time step descriptor
Definition: cs_time_step.h:51
Definition: cs_field.h:124
Definition: cs_equation_param.h:148
void cs_hho_scaleq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
Definition: cs_hho_scaleq.c:716
Definition: cs_defs.h:467
Definition: cs_cdo_connect.h:74
void cs_hho_scaleq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued HHO schemes.
Definition: cs_hho_scaleq.c:991
void cs_hho_scaleq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values required for ...
Definition: cs_hho_scaleq.c:1319
Definition: cs_defs.h:302
Definition: cs_cdo_quantities.h:94
Definition: cs_cdo_local.h:93
Definition: cs_matrix.h:90
cs_real_t * cs_hho_scaleq_get_cell_values(void *data)
Get the computed values at cells (DoF used in the linear system are located at primal faces) ...
Definition: cs_hho_scaleq.c:1458
void cs_hho_scaleq_finalize_common(void)
Free buffers and generic structures related to HHO schemes.
Definition: cs_hho_scaleq.c:739
Definition: cs_hho_builder.h:53
Definition: cs_restart.h:87
void cs_hho_scaleq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Write additional arrays (not defined as fields) but useful for the checkpoint/restart process...
Definition: cs_hho_scaleq.c:1562
void cs_hho_scaleq_init_common(cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_structure_t *ms0, const cs_matrix_structure_t *ms1, const cs_matrix_structure_t *ms2)
Allocate work buffer and general structures related to HHO schemes Set shared pointers.
Definition: cs_hho_scaleq.c:608
Set of local and temporary buffers useful for building the algebraic system with a cellwise process...
Definition: cs_cdo_local.h:56
void cs_hho_scaleq_extra_op(const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Definition: cs_hho_scaleq.c:1625
void cs_hho_scaleq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Read additional arrays (not defined as fields) but useful for the checkpoint/restart process...
Definition: cs_hho_scaleq.c:1480
cs_real_t * cs_hho_scaleq_get_face_values(void *data)
Get the computed values at faces (DoF used in the linear system are located at primal faces) ...
Definition: cs_hho_scaleq.c:1436
double precision, dimension(:,:), allocatable solu
Definition: atincl.f90:265
Definition: cs_defs.h:468
unsigned short int cs_flag_t
Definition: cs_defs.h:304
void cs_hho_scaleq_initialize_system(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associ...
Definition: cs_hho_scaleq.c:1033
Structure and routines handling the specific settings related to a cs_equation_t structure.
void * cs_hho_scaleq_init_context(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_hho_scaleq_t structure storing data useful for building and managing such a scheme...
Definition: cs_hho_scaleq.c:778
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:86
void cs_hho_scaleq_build_system(const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *rhs, cs_matrix_t *matrix)
Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme...
Definition: cs_hho_scaleq.c:1078
void * cs_hho_scaleq_free_context(void *data)
Destroy a cs_hho_scaleq_t structure.
Definition: cs_hho_scaleq.c:953
