Routines to handle structures used as a context when solving the Navier-Stokes equations. Structures are cast on-the-fly according to the type of coupling. Routines to handle the settings of coupling algorithms. More...
| struct | cs_navsto_ac_t |
| Set of parameters specific for solving the Navier-Stokes system with the "artificial compressibility" algorithm. More... | |
| struct | cs_navsto_ac_vpp_t |
| Set of parameters specific for solving the Navier-Stokes system with the "artificial compressibility" solved by the VPP_eps algorithm. More... | |
| struct | cs_navsto_monolithic_t |
| Set of parameters specific for solving the Navier-Stokes system with a fully coupled monolithic algorithm. More... | |
| struct | cs_navsto_projection_t |
| Set of parameters specific for solving the Navier-Stokes system with an incremental projection algorithm. More... | |
| struct | cs_navsto_uzawa_t |
| Set of parameters specific for solving the Navier-Stokes system with a fully coupled algorithm using a Uzawa algorithm and an Augmented Lagrangian approach inside each sub-iteration. More... | |
| void * | cs_navsto_uzawa_create_context (cs_navsto_param_t *nsp, cs_param_bc_type_t bc) |
| Allocate and initialize a context structure when the Navier-Stokes system is coupled using an Uzawa-Augmented Lagrangian approach. More... | |
| void * | cs_navsto_uzawa_free_context (const cs_navsto_param_t *nsp, void *context) |
| Free the context structure related to an Uzawa-Augmented Lagrangian approach. More... | |
| void | cs_navsto_uzawa_init_setup (const cs_navsto_param_t *nsp, void *context) |
| Start setting-up the Navier-Stokes equations when a Uzawa Augmented Lagrangian algorithm is used to coupled the system No mesh information is available at this stage. More... | |
| void | cs_navsto_uzawa_last_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context) |
| Finalize the setup for the Navier-Stokes equations when an Uzawa Augmented Lagrangian algorithm is used to coupled the system. Connectivity and geometric quantities are available at this stage. More... | |
| cs_equation_t * | cs_navsto_uzawa_get_momentum_eq (void *context) |
| Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of Uzawa coupling. More... | |
| void * | cs_navsto_ac_create_context (cs_navsto_param_t *nsp, cs_param_bc_type_t bc) |
| Allocate and initialize a context structure when the Navier-Stokes system is coupled using an Artificial Compressibility approach. More... | |
| void * | cs_navsto_ac_free_context (const cs_navsto_param_t *nsp, void *context) |
| Free the context structure related to an Artificial Compressibility approach. More... | |
| void | cs_navsto_ac_init_setup (const cs_navsto_param_t *nsp, void *context) |
| Start setting-up the Navier-Stokes equations when an Artificial Compressibility algorithm is used to coupled the system. No mesh information is available at this stage. More... | |
| void | cs_navsto_ac_last_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context) |
| Finalize the setup for the Navier-Stokes equations when an Artificial Compressibility algorithm is used to coupled the system. Connectivity and geometric quantities are available at this stage. More... | |
| cs_equation_t * | cs_navsto_ac_get_momentum_eq (void *context) |
| Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of artificial compressibility coupling. More... | |
| void * | cs_navsto_ac_vpp_create_context (cs_navsto_param_t *nsp, cs_param_bc_type_t bc) |
| Allocate and initialize a context structure when the Navier-Stokes system is coupled using an Artificial Compressibility - VPP approach. More... | |
| void * | cs_navsto_ac_vpp_free_context (const cs_navsto_param_t *nsp, void *context) |
| Free the context structure related to an Artificial Compressibility with the VPP approach. More... | |
| void | cs_navsto_ac_vpp_init_setup (const cs_navsto_param_t *nsp, void *context) |
| Start setting-up the Navier-Stokes equations when an Artificial Compressibility with VPP algorithm is used to coupled the system. No mesh information is available at this stage. More... | |
| void | cs_navsto_ac_vpp_last_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context) |
| cs_equation_t * | cs_navsto_ac_vpp_get_momentum_eq (void *context) |
| Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of artificial compressibility coupling with the VPP extension. More... | |
| void * | cs_navsto_monolithic_create_context (cs_navsto_param_t *nsp, cs_param_bc_type_t bc) |
| Allocate and initialize a context structure when the Navier-Stokes system is coupled using a monolithic approach. More... | |
| void * | cs_navsto_monolithic_free_context (const cs_navsto_param_t *nsp, void *context) |
| Free the context structure related to a monolithic approach. More... | |
| void | cs_navsto_monolithic_init_setup (const cs_navsto_param_t *nsp, void *context) |
| Start setting-up the Navier-Stokes equations when a monolithic algorithm is used to coupled the system. No mesh information is available at this stage. More... | |
| void | cs_navsto_monolithic_last_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context) |
| Finalize the setup for the Navier-Stokes equations when a monolithic algorithm is used to coupled the system. Connectivity and geometric quantities are available at this stage. More... | |
| cs_equation_t * | cs_navsto_monolithic_get_momentum_eq (void *context) |
| Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of a monolithic coupling. More... | |
| void * | cs_navsto_projection_create_context (cs_navsto_param_t *nsp, cs_param_bc_type_t bc) |
| Allocate and initialize a context structure when the Navier-Stokes system is coupled using an incremental Projection approach in the the rotational form (see Minev & Guermond, 2006, JCP) More... | |
| void * | cs_navsto_projection_free_context (const cs_navsto_param_t *nsp, void *context) |
| Free the context structure related to a Projection approach. More... | |
| void | cs_navsto_projection_init_setup (const cs_navsto_param_t *nsp, int loc_id, bool has_previous, void *context) |
| Start setting-up the Navier-Stokes equations when a projection algorithm is used to coupled the system. No mesh information is available at this stage. More... | |
| void | cs_navsto_projection_last_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_navsto_param_t *nsp, void *context) |
| Finalize the setup for the Navier-Stokes equations when a projection algorithm is used to coupled the system. Connectivity and geometric quantities are available at this stage. More... | |
| cs_equation_t * | cs_navsto_projection_get_momentum_eq (void *context) |
| Retrieve the pointer to the cs_equation_t structure related to the momentum equation in case of a projection coupling. More... | |
| void* cs_navsto_ac_create_context | ( | cs_navsto_param_t * | nsp, |
| cs_param_bc_type_t | bc | ||
| [in] | bc | default cs_param_bc_type_t for the equation |
| void* cs_navsto_ac_free_context | ( | const cs_navsto_param_t * | nsp, |
| void * | context | ||
| cs_equation_t* cs_navsto_ac_get_momentum_eq | ( | void * | context | ) |
| [in] | context | pointer to a context structure cast on-the-fly |
| void cs_navsto_ac_init_setup | ( | const cs_navsto_param_t * | nsp, |
| void cs_navsto_ac_last_setup | ( | const cs_cdo_connect_t * | connect, |
| void* cs_navsto_ac_vpp_create_context | ( | cs_navsto_param_t * | nsp, |
| void* cs_navsto_ac_vpp_free_context | ( | const cs_navsto_param_t * | nsp, |
| cs_equation_t* cs_navsto_ac_vpp_get_momentum_eq | ( | void * | context | ) |
| void cs_navsto_ac_vpp_init_setup | ( | const cs_navsto_param_t * | nsp, |
| void cs_navsto_ac_vpp_last_setup | ( | const cs_cdo_connect_t * | connect, |
| void* cs_navsto_monolithic_create_context | ( | cs_navsto_param_t * | nsp, |
| void* cs_navsto_monolithic_free_context | ( | const cs_navsto_param_t * | nsp, |
| cs_equation_t* cs_navsto_monolithic_get_momentum_eq | ( | void * | context | ) |
| void cs_navsto_monolithic_init_setup | ( | const cs_navsto_param_t * | nsp, |
| void cs_navsto_monolithic_last_setup | ( | const cs_cdo_connect_t * | connect, |
| void* cs_navsto_projection_create_context | ( | cs_navsto_param_t * | nsp, |
| void* cs_navsto_projection_free_context | ( | const cs_navsto_param_t * | nsp, |
| cs_equation_t* cs_navsto_projection_get_momentum_eq | ( | void * | context | ) |
| void cs_navsto_projection_init_setup | ( | const cs_navsto_param_t * | nsp, |
| int | loc_id, | ||
| bool | has_previous, | ||
| [in] | loc_id | id related to a mesh location |
| [in] | has_previous | values at different time steps (true/false) |
| void cs_navsto_projection_last_setup | ( | const cs_cdo_connect_t * | connect, |
| void* cs_navsto_uzawa_create_context | ( | cs_navsto_param_t * | nsp, |
| void* cs_navsto_uzawa_free_context | ( | const cs_navsto_param_t * | nsp, |
| cs_equation_t* cs_navsto_uzawa_get_momentum_eq | ( | void * | context | ) |
| void cs_navsto_uzawa_init_setup | ( | const cs_navsto_param_t * | nsp, |
| void cs_navsto_uzawa_last_setup | ( | const cs_cdo_connect_t * | connect, |
