#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <bft_mem.h>#include "cs_mesh_location.h"#include "cs_reco.h"#include "cs_time_step.h"#include "cs_xdef_eval.h"
Macros | |
| void | cs_xdef_eval_scalar_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a scalar-valued quantity for a list of elements. More... | |
| void | cs_xdef_eval_vector_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a vector-valued quantity for a list of elements. More... | |
| void | cs_xdef_eval_tensor_by_val (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a tensor-valued quantity for a list of elements. More... | |
| void | cs_xdef_eval_scalar_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a scalar-valued quantity with only a time-dependent variation for a list of elements. More... | |
| void | cs_xdef_eval_vector_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a vector-valued quantity with only a time-dependent variation for a list of elements. More... | |
| void | cs_xdef_eval_tensor_at_cells_by_time_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a tensor-valued quantity with only a time-dependent variation for a list of elements. More... | |
| void | cs_xdef_eval_at_cells_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a quantity defined at cells using an analytic function. More... | |
| void | cs_xdef_eval_at_b_faces_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a quantity defined at border faces using an analytic function. More... | |
| void | cs_xdef_eval_avg_at_b_faces_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, const int dim, cs_real_t *eval) |
| void | cs_xdef_eval_at_vertices_by_analytic (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a quantity defined at vertices using an analytic function. More... | |
| void | cs_xdef_eval_scalar_at_cells_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a scalar-valued quantity at cells defined by an array. Array is assumed to be interlaced. More... | |
| void | cs_xdef_eval_nd_at_cells_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a nd-valued quantity at cells defined by an array. Array is assumed to be interlaced. More... | |
| void | cs_xdef_eval_at_vertices_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a quantity defined at vertices using an array. More... | |
| void | cs_xdef_eval_3_at_all_vertices_by_array (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a vector-valued quantity at all vertices defined by an array. Array is assumed to be interlaced. More... | |
| void | cs_xdef_eval_cell_by_field (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool compact, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a quantity inside a cell defined using a field. More... | |
| void cs_xdef_eval_3_at_all_vertices_by_array | ( | cs_lnum_t | n_elts, |
| bool | compact, | ||
| cs_real_t | time_eval, | ||
| void * | input, | ||
| cs_real_t * | eval | ||
| [in] | elt_ids | list of element ids |
| [in] | compact | true:no indirection, false:indirection for output |
| [in] | input | pointer to an input structure |
| [out] | eval | result of the evaluation |
| void cs_xdef_eval_at_b_faces_by_analytic | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_cells_by_analytic | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_vertices_by_analytic | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_at_vertices_by_array | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_avg_at_b_faces_by_analytic | ( | cs_lnum_t | n_elts, |
| cs_quadrature_type_t | qtype, | ||
| const int | dim, | ||
| [in] | qtype | quadrature type |
| [in] | dim | dimension of the analytic function return |
| void cs_xdef_eval_cell_by_field | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_nd_at_cells_by_array | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_scalar_at_cells_by_array | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_scalar_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_scalar_by_val | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_tensor_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_tensor_by_val | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_vector_at_cells_by_time_func | ( | cs_lnum_t | n_elts, |
| void cs_xdef_eval_vector_by_val | ( | cs_lnum_t | n_elts, |
