#include "base/cs_defs.h"#include <limits.h>#include <stdio.h>#include <stddef.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <ctype.h>#include <float.h>#include <assert.h>#include "bft/bft_mem.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_base.h"#include "base/cs_field.h"#include "base/cs_field_pointer.h"#include "base/cs_math.h"#include "mesh/cs_mesh_location.h"#include "base/cs_boundary_conditions.h"#include "base/cs_boundary_zone.h"#include "base/cs_volume_zone.h"#include "base/cs_parameters.h"#include "base/cs_prototypes.h"#include "base/cs_time_step.h"#include "base/cs_physical_constants.h"#include "base/cs_thermal_model.h"#include "turb/cs_turbulence_model.h"#include "pprt/cs_physical_model.h"#include "base/cs_parall.h"#include "base/cs_post.h"#include "base/cs_post_default.h"#include "rayt/cs_rad_transfer.h"#include "gui/cs_gui_particles.h"#include "gui/cs_gui_util.h"#include "lagr/cs_lagr.h"#include "lagr/cs_lagr_lec.h"#include "lagr/cs_lagr_geom.h"#include "lagr/cs_lagr_dlvo.h"#include "lagr/cs_lagr_roughness.h"#include "lagr/cs_lagr_clogging.h"#include "lagr/cs_lagr_injection.h"#include "lagr/cs_lagr_aux_mean_fluid_quantities.h"#include "lagr/cs_lagr_car.h"#include "lagr/cs_lagr_coupling.h"#include "lagr/cs_lagr_new.h"#include "lagr/cs_lagr_particle.h"#include "lagr/cs_lagr_resuspension.h"#include "lagr/cs_lagr_stat.h"#include "lagr/cs_lagr_tracking.h"#include "lagr/cs_lagr_print.h"#include "lagr/cs_lagr_poisson.h"#include "lagr/cs_lagr_post.h"#include "lagr/cs_lagr_sde.h"#include "lagr/cs_lagr_sde_model.h"#include "lagr/cs_lagr_orientation.h"#include "lagr/cs_lagr_prototypes.h"#include "lagr/cs_lagr_agglo.h"#include "lagr/cs_lagr_fragmentation.h"#include "base/cs_random.h"| cs_lagr_agglomeration_model_t * cs_get_lagr_agglomeration_model | ( | void | ) |
| cs_lagr_boundary_interactions_t * cs_get_lagr_boundary_interactions | ( | void | ) |
| cs_lagr_brownian_t * cs_get_lagr_brownian | ( | void | ) |
| cs_lagr_clogging_model_t * cs_get_lagr_clogging_model | ( | void | ) |
| cs_lagr_consolidation_model_t * cs_get_lagr_consolidation_model | ( | void | ) |
| cs_lagr_encrustation_t * cs_get_lagr_encrustation | ( | void | ) |
| cs_lagr_extra_module_t * cs_get_lagr_extra_module | ( | void | ) |
| cs_lagr_physico_chemical_t * cs_get_lagr_physico_chemical | ( | void | ) |
| cs_lagr_precipitation_model_t * cs_get_lagr_precipitation_model | ( | void | ) |
Provide access to cs_lagr_precipitation_model_t.
| cs_lagr_reentrained_model_t * cs_get_lagr_reentrained_model | ( | void | ) |
Provide access to cs_lagr_reentrained_model_t.
| cs_lagr_shape_model_t * cs_get_lagr_shape_model | ( | void | ) |
| cs_lagr_source_terms_t * cs_get_lagr_source_terms | ( | void | ) |
| cs_lagr_specific_physics_t * cs_get_lagr_specific_physics | ( | void | ) |
Provide access to cs_lagr_specific_physics_t.
| cs_lagr_time_step_t * cs_get_lagr_time_step | ( | void | ) |
| void cs_lagr_add_fields | ( | void | ) |
Create additional fields needed by the Lagrangien model.
Most additional fields can be defined directly in cs_lagr_options_definition, but some fields may be mapped to different fields based on the calling module (i.e. code_saturne or neptune_cfd), and possibly defined after that call.
| void cs_lagr_finalize | ( | void | ) |
| void cs_lagr_finalize_internal_cond | ( | void | ) |
| void cs_lagr_finalize_zone_conditions | ( | void | ) |
Return pointer to the main internal conditions structure.
Finalize the global boundary and volume condition structures.
| cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions | ( | void | ) |
Return pointer to the main boundary conditions structure.
| cs_lagr_injection_set_t * cs_lagr_get_injection_set | ( | cs_lagr_zone_data_t * | zone_data, |
| int | zone_id, | ||
| int | set_id ) |
Provide access to injection set structure.
This access method ensures the strucure is initialized for the given zone and injection set.
| [in] | zone_data | pointer to boundary or volume conditions structure |
| [in] | zone_id | zone id |
| [in] | set_id | injection set id |
| cs_lagr_internal_condition_t * cs_lagr_get_internal_conditions | ( | void | ) |
The structure is allocated on demand, when this function is first called.
| cs_lagr_particle_counter_t * cs_lagr_get_particle_counter | ( | void | ) |
Get read/write pointer to global particle counter.
| cs_lagr_zone_data_t * cs_lagr_get_volume_conditions | ( | void | ) |
Return pointer to the main volume conditions structure.
| void cs_lagr_init_arrays | ( | void | ) |
| void cs_lagr_initialize_extra | ( | cs_lnum_t | n_continuous_phases | ) |
| void cs_lagr_injection_set_default | ( | cs_lagr_injection_set_t * | zis | ) |
Initialize injection set data structure fields to defaults.
| [in,out] | zis | pointer to structure to initialize |
| void cs_lagr_map_specific_physics | ( | void | ) |
Map specific phyical model features to Lagrangian structures.
| void cs_lagr_solve_initialize | ( | const cs_real_t * | dt | ) |
| void cs_lagr_solve_time_step | ( | const int | itypfb[], |
| const cs_real_t * | dt ) |
| cs_lagr_particle_counter_t * cs_lagr_update_particle_counter | ( | void | ) |
Update global particle counter.
All fields handled in the local particle set are updated relative to that data (using global sums).
