cs_lagr_coupling.h
1#ifndef __CS_LAGR_COUPLING_H__
2#define __CS_LAGR_COUPLING_H__
5 * Functions and types for the Lagrangian module
30#include "base/cs_defs.h"
32/*----------------------------------------------------------------------------*/
36/*=============================================================================
37 * Macro definitions
41 * Type definitions
45 * Global variables
48/*=============================================================================
49 * Public function prototypes
51
52/*----------------------------------------------------------------------------*/
53/*
54 * \brief Compute source terms for Lagrangian 2-way coupling.
55 *
56 * \remark Source terms are computed for the starting cell of a particle
57 * during a given iteration. Even if particle exits the domain,
58 * it s necessary to compute a source term matching the exchange
59 * between the carrier fluid and the particle at the beginning
60 * of the time step. If cs_glob_lagr_time_step->nor == 2 and the
61 * particle interacts with a boundary, then the source terms
62 * are computed as if nor == 1.
63 *
64 * \param[in] taup dynamic characteristic time
65 * \param[in] tempct thermal charactersitic time
66 * \param[out] tsfext external forces
67 * \param[in] force_p forces per mass unit on particles (m/s^2)
68 */
69/*----------------------------------------------------------------------------*/
70
71void
72cs_lagr_coupling(const cs_real_t **taup,
73 const cs_real_t tempct[],
74 cs_real_t tsfext[],
75 const cs_real_3_t *force_p);
76
77/*----------------------------------------------------------------------------*/
78
80
81#endif /* __CS_LAGR_COUPLING_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
cs_real_t cs_real_3_t[3]
Definition cs_defs.h:359
void cs_lagr_coupling(const cs_real_t **taup, const cs_real_t tempct[], cs_real_t tsfext[], const cs_real_3_t *force_p)
Definition cs_lagr_coupling.cpp:118
