cs_lagr_boundary_interactions_t Struct Reference
#include <cs_lagr.h>
Collaboration diagram for cs_lagr_boundary_interactions_t:
Data Fields
int npstf
int npstft
int has_part_impact_nbr
int iclgst
int inbr
int inclg
int inclgt
int iclogt
int iclogh
int iscovc
int ihdepm
int ihdepv
int ihdiam
int ihsum
cs_real_t tstatp
char ** nombrd
Boundary interactions statistics parameters
Field Documentation
◆ has_part_impact_nbr
activation (=1) or not (=0) of the recording of the number of particle/boundary interactions, and of the calculation of the associated boundary statistics.
◆ iclgst
int iclgst
activation (=1) or not (=0) of the recording of clogging parameters involved in a particle/boundary interaction, and of the calculation of the associated boundary statistics.
◆ iclogh
int iclogh
id for particle consolidation height
◆ iclogt
int iclogt
id for particle deposition time
◆ ihdepm
int ihdepm
◆ ihdepv
int ihdepv
◆ ihdiam
int ihdiam
◆ ihsum
int ihsum
◆ inbr
int inbr
id for number of particle/boundary interactions
◆ inclg
int inclg
id for number of deposited particles
◆ inclgt
int inclgt
id for particle deposition part
◆ iscovc
int iscovc
id for particle surface coverage
◆ nombrd
char** nombrd
name of the boundary statistics, displayed in the log and the post-processing files. Warning: this name is also used to reference information in the restart file. If the name of a variable is changed between two calculations, it will not be possible to read its value from the restart file
◆ npstf
int npstf
Number of iterations during which steady boundary statistics have been accumulated. Useful if isttio=1 and nstist inferior or equal to the current time step. npstf is initialized and updated automatically by the code, its value is not to be modified by the user
◆ npstft
int npstft
number of iterations during which boundary statistics have been calculated (the potential iterations during which unsteady statistics have been calculated are counted in npstft). npstft is initialized and updated automatically by the code, its value is not to be modified by the user
◆ tstatp
cs_real_t tstatp
If the recording of the boundary statistics is steady, tstatp contains the cumulated physical duration of the recording of the boundary statistics. If the recording of the boundary statistics is unsteady, then tstatp = dtp (it is the Lagrangian time step, because the statistics are reset to zero at every time step).
