cs_lagr_tracking.h
1#ifndef __CS_LAGR_TRACKING_H__
2#define __CS_LAGR_TRACKING_H__
5 * Functions and types for the Lagrangian module
30#include "base/cs_defs.h"
33 * Local headers
42/*=============================================================================
43 * Macro definitions
45
47 * Type definitions
49
50/* State where a particle can be.
51 (order is chosen so as to make tests simpler;
52 inside domain first, outside after) */
53
63
64/*=============================================================================
65 * Global variables
66 *============================================================================*/
67
68/*============================================================================
69 * Public function prototypes
70 *============================================================================*/
71
72/*----------------------------------------------------------------------------*/
76/*----------------------------------------------------------------------------*/
77
78void
80
81/*----------------------------------------------------------------------------*/
89/*----------------------------------------------------------------------------*/
90
91void
93 cs_lnum_t particle_range[2]);
94
95/*----------------------------------------------------------------------------*/
100
101void
103
104/*----------------------------------------------------------------------------*/
117/*----------------------------------------------------------------------------*/
118
119void
120cs_lagr_test_wall_cell(const void *particle,
121 const cs_lagr_attribute_map_t *p_am,
122 const cs_real_t visc_length[],
124 cs_lnum_t *face_id);
125
126/*----------------------------------------------------------------------------*/
127
128
130
131#endif /* __CS_LAGR_TRACKING_H__ */
Definition cs_defs.h:542
Definition cs_defs.h:342
Definition cs_defs.h:543
Definition cs_defs.h:335
@ yplus
Definition cs_field_pointer.h:218
void cs_lagr_tracking_initialize(void)
Initialize particle tracking subsystem.
Definition cs_lagr_tracking.cpp:3137
cs_lagr_tracking_state_t
Definition cs_lagr_tracking.h:54
@ CS_LAGR_PART_STUCK
Definition cs_lagr_tracking.h:58
@ CS_LAGR_PART_MERGED
Definition cs_lagr_tracking.h:59
@ CS_LAGR_PART_OUT
Definition cs_lagr_tracking.h:60
@ CS_LAGR_PART_TO_SYNC
Definition cs_lagr_tracking.h:55
@ CS_LAGR_PART_TO_SYNC_NEXT
Definition cs_lagr_tracking.h:56
@ CS_LAGR_PART_TREATED
Definition cs_lagr_tracking.h:57
@ CS_LAGR_PART_ERR
Definition cs_lagr_tracking.h:61
void cs_lagr_tracking_particle_movement(const cs_real_t visc_length[], cs_lnum_t particle_range[2])
Apply one particle movement step.
Definition cs_lagr_tracking.cpp:3175
void cs_lagr_tracking_finalize(void)
Finalize Lagrangian module.
Definition cs_lagr_tracking.cpp:3343
void cs_lagr_test_wall_cell(const void *particle, const cs_lagr_attribute_map_t *p_am, const cs_real_t visc_length[], cs_real_t *yplus, cs_lnum_t *face_id)
Determine the number of the closest wall face from the particle as well as the corresponding wall nor...
Definition cs_lagr_tracking.cpp:3401
Definition cs_lagr_particle.h:190
