| void | csfpva (void) |
| void | csivis (void) |
| void | csidtv (void) |
| void | csiphy (void) |
| void | cscfgp (void) |
| void | cstime (void) |
| void | uiporo (void) |
| void | uiphyv (void) |
| void | uiexop (void) |
| void | cs_gui_checkpoint_parameters (void) |
| | Read GUi-defined Checkpoint parameters. More...
| void | cs_gui_equation_parameters (void) |
| void | cs_gui_finalize (void) |
| cs_equation_param_t * | cs_gui_get_equation_param (const char *name) |
| void | cs_gui_fluid_properties_value (const char *param, double *value) |
| void | cs_gui_groundwater_property_laws (int permeability, int diffusion, int unsaturated) |
| void | cs_gui_head_losses (const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6]) |
| | Compute GUI-defined head losses for a given volume zone. More...
| void | cs_gui_initial_conditions (void) |
| | Apply initial conditions based on GUI-defined settings. More...
| void | cs_gui_linear_solvers (void) |
| void | cs_gui_momentum_source_terms (const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp) |
| void | cs_gui_numerical_options (void) |
| void | cs_gui_parallel_io (void) |
| void | cs_gui_partition (void) |
| void | cs_gui_mpi_algorithms (void) |
| void | cs_gui_physical_constants (void) |
| void | cs_gui_physical_properties (void) |
| void | cs_gui_porous_model (void) |
| void | cs_gui_properties_value (const char *property_name, double *value) |
| void | cs_gui_properties_value_by_fluid_id (const int fluid_id, const char *property_name, double *value) |
| void | cs_gui_scalar_model_settings (void) |
| void | cs_gui_thermal_model (void) |
| int | cs_gui_thermal_model_code (void) |
| void | cs_gui_time_moments (void) |
| void | cs_gui_turbomachinery (void) |
| void | cs_gui_turbomachinery_rotor (void) |
| void | cs_gui_turb_model (void) |
| void | cs_gui_turb_ref_values (void) |
| void | cs_gui_usage_log (void) |
| void | cs_gui_user_variables (void) |
| void | cs_gui_user_arrays (void) |
| void | cs_gui_calculator_functions (void) |
| void | cs_gui_zones (void) |
| void | cs_gui_balance_by_zone (void) |
| void | cs_gui_pressure_drop_by_zone (void) |
| void | cs_gui_define_fans (void) |
| void | cs_gui_error_estimator (void) |
| void | cs_gui_internal_coupling (void) |
| const cs_gui_volume_meg_context_t * | cs_gui_add_volume_meg_context (const cs_zone_t *zone, const cs_field_t *fields[], const int n_fields) |
| | Add new MEG context info. More...
| void | cs_gui_scalar_source_terms (cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp) |
| void | cs_gui_thermal_source_terms (cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp) |
| void | cs_gui_time_tables (void) |
| | Read GUI defined time tables. More...
