8.2
cs_field_default.h
1 #ifndef __CS_FIELD_DEFAULT_H__
2 #define __CS_FIELD_DEFAULT_H__
5  * Field utility functions.
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_equation_param.h"
36
38
41 /*=============================================================================
42  * Macro definitions
46  * Type definitions
48
50  * Global variables
52
53 /*=============================================================================
54  * Public function prototypes
56
57 /*----------------------------------------------------------------------------*/
70 /*----------------------------------------------------------------------------*/
71
72 int
73 cs_variable_cdo_field_create(const char *name,
74  const char *label,
75  int location_id,
76  int dim,
77  int has_previous);
78
79 /*----------------------------------------------------------------------------*/
91
92 int
93 cs_variable_field_create(const char *name,
94  const char *label,
95  int location_id,
96  int dim);
97
98 /*----------------------------------------------------------------------------*/
113 /*----------------------------------------------------------------------------*/
114
117
118 /*----------------------------------------------------------------------------*/
133 /*----------------------------------------------------------------------------*/
134
135 const cs_equation_param_t *
137
138 /*----------------------------------------------------------------------------*/
147
148 cs_field_t *
150
151 /*----------------------------------------------------------------------------*/
156 /*----------------------------------------------------------------------------*/
157
158 void
160
161 /*----------------------------------------------------------------------------*/
166 /*----------------------------------------------------------------------------*/
167
168 void
170
171 /*----------------------------------------------------------------------------*/
175 /*----------------------------------------------------------------------------*/
176
177 void
179
180 /*----------------------------------------------------------------------------*/
181
183
184 #endif /* __CS_FIELD_DEFAULT_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
void cs_field_free_bc_codes_all(void)
Deallocate and unmap boundary condition coefficients for all variable fields.
Definition: cs_field_default.c:473
void cs_field_build_bc_codes_all(void)
Allocate and map boundary condition coefficients for all variable fields.
Definition: cs_field_default.c:370
cs_field_t * cs_field_get_variance(const cs_field_t *f)
For a given field, returns field defined as its variance, if present.
Definition: cs_field_default.c:339
void cs_field_map_and_init_bcs(void)
Initialize all field BC coefficients.
Definition: cs_field_default.c:514
cs_equation_param_t * cs_field_get_equation_param(cs_field_t *f)
Access a field's equation parameters.
Definition: cs_field_default.c:282
int cs_variable_field_create(const char *name, const char *label, int location_id, int dim)
Add field defining a general solved variable, with default options.
Definition: cs_field_default.c:228
int cs_variable_cdo_field_create(const char *name, const char *label, int location_id, int dim, int has_previous)
Add a field shared between CDO and legacy schemes. This field is related to a general solved variable...
Definition: cs_field_default.c:174
const cs_equation_param_t * cs_field_get_equation_param_const(const cs_field_t *f)
Access a field's equation parameters for read only.
Definition: cs_field_default.c:314
char * label
Definition: keywords.h:58
Definition: cs_equation_param.h:193
Definition: cs_field.h:131
