| int | cs_variable_cdo_field_create (const char *name, const char *label, int location_id, int dim, int has_previous) |
| | Add a field shared between CDO and legacy schemes. This field is related to a general solved variable, with default options. More...
| int | cs_variable_field_create (const char *name, const char *label, int location_id, int dim) |
| | Add field defining a general solved variable, with default options. More...
| cs_equation_param_t * | cs_field_get_equation_param (cs_field_t *f) |
| | Access a field's equation parameters. More...
| const cs_equation_param_t * | cs_field_get_equation_param_const (const cs_field_t *f) |
| | Access a field's equation parameters for read only. More...
| cs_field_t * | cs_field_get_variance (const cs_field_t *f) |
| | For a given field, returns field defined as its variance, if present. More...
| void | cs_field_build_bc_codes_all (void) |
| | Allocate and map boundary condition coefficients for all variable fields. More...
| void | cs_field_free_bc_codes_all (void) |
| | Deallocate and unmap boundary condition coefficients for all variable fields. More...
| void | cs_field_map_and_init_bcs (void) |
| | Initialize all field BC coefficients. More...
◆ cs_field_build_bc_codes_all()
| void cs_field_build_bc_codes_all |
void |
◆ cs_field_free_bc_codes_all()
| void cs_field_free_bc_codes_all |
void |
◆ cs_field_get_equation_param()
If the equation parameters were never initialized, they will be initialized based on the current defaults.
If the field does not have associated equation paremeters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), NULL is returned.
- Parameters
| [in,out] | f | pointer to associated field |
- Returns
- pointer to field's equation parameters, or NULL
◆ cs_field_get_equation_param_const()
If the equation parameters were never initialized, the current default parameters will be returned instead.
If the field does not have associated equation parameters (i.e. is not a variable field or is a CDO field (which is referenced by but does not directly reference equations), NULL is returned.
- Parameters
| [in] | f | pointer to associated field |
- Returns
- const-qualified pointer to field's equation parameters, or NULL
◆ cs_field_get_variance()
- Parameters
- Returns
- pointer to matching variance (variable) field, or NULL.
◆ cs_field_map_and_init_bcs()
| void cs_field_map_and_init_bcs |
void |
◆ cs_variable_cdo_field_create()
| int cs_variable_cdo_field_create |
const char * |
name, |
const char * |
label, |
int |
location_id, |
int |
dim, |
int |
has_previous |
- Parameters
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [in] | location_id | id of associated location |
| [in] | dim | field dimension |
| [in] | has_previous | no if lower than 1 |
- Returns
- newly defined field id
◆ cs_variable_field_create()
| int cs_variable_field_create |
const char * |
name, |
const char * |
label, |
int |
location_id, |
int |
dim |
- Parameters
- Returns
