1 #ifndef __CS_EQUATION_PARAM_H__
2 #define __CS_EQUATION_PARAM_H__
97 #define CS_EQUATION_LOCKED (1 << 0)
98 #define CS_EQUATION_UNSTEADY (1 << 1)
99 #define CS_EQUATION_CONVECTION (1 << 2)
100 #define CS_EQUATION_DIFFUSION (1 << 3)
101 #define CS_EQUATION_CURLCURL (1 << 4)
102 #define CS_EQUATION_GRADDIV (1 << 5)
103 #define CS_EQUATION_REACTION (1 << 6)
104 #define CS_EQUATION_FORCE_VALUES (1 << 7)
105 #define CS_EQUATION_INSIDE_SYSTEM (1 << 8)
106 #define CS_EQUATION_BUILD_HOOK (1 << 9)
107 #define CS_EQUATION_USER_TRIGGERED (1 << 10)
133 #define CS_EQUATION_POST_BALANCE (1 << 0)
134 #define CS_EQUATION_POST_PECLET (1 << 1)
135 #define CS_EQUATION_POST_UPWIND_COEF (1 << 2)
136 #define CS_EQUATION_POST_NORMAL_FLUX (1 << 3)
1261 assert(eqp != NULL);
1278 assert(eqp != NULL);
1298 assert(eqp != NULL);
1318 assert(eqp != NULL);
1338 assert(eqp != NULL);
1358 assert(eqp != NULL);
1378 assert(eqp != NULL);
1398 assert(eqp != NULL);
1419 assert(eqp != NULL);
1440 assert(eqp != NULL);
1466 assert(eqp != NULL);
1492 if (eqp->
name == NULL)
1494 if (strcmp(eqp->
name, name) == 0)
1643 const char *keyval);
2057 const char *z_name);
2075 const char *z_name);
2093 const char *z_name);
2108 const char *z_name);
#define restrict
Definition: cs_defs.h:141
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
unsigned short int cs_flag_t
Definition: cs_defs.h:334
cs_xdef_t * cs_equation_add_ic_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the unknown related to this equation. This definition applies to a v...
Definition: cs_equation_param.cxx:2163
void cs_equation_param_set(cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_equation_param_t structure.
Definition: cs_equation_param.cxx:1408
cs_xdef_t * cs_equation_add_bc_by_field(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_field_t *field)
Define and initialize a new structure to set a boundary condition related to the given equation struc...
Definition: cs_equation_param.cxx:2504
cs_xdef_t * cs_equation_add_volume_mass_injection_by_value(cs_equation_param_t *eqp, const char *z_name, double *val)
Add a new volume mass injection definition source term by initializing a cs_xdef_t structure,...
Definition: cs_equation_param.cxx:3514
int cs_equation_add_reaction(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the reaction operator for the equation associated to the given cs_equ...
Definition: cs_equation_param.cxx:3228
void cs_equation_add_graddiv(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the grad-div operator for the equation associated to the given cs_equ...
Definition: cs_equation_param.cxx:3127
void cs_equation_param_unlock_settings(cs_equation_param_t *eqp)
Unlock settings. Be sure that is really wanted (inconsistency between the setup logging and what is u...
Definition: cs_equation_param.cxx:1584
static void cs_equation_set_param(cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval)
Definition: cs_equation_param.h:1659
cs_xdef_t * cs_equation_add_ic_by_qov(cs_equation_param_t *eqp, const char *z_name, double quantity)
Definition: cs_equation_param.cxx:2104
static bool cs_equation_param_has_time(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs an unsteady term.
Definition: cs_equation_param.h:1376
void cs_equation_param_lock_settings(cs_equation_param_t *eqp)
Lock settings to prevent from unwanted modifications.
Definition: cs_equation_param.cxx:1566
static bool cs_equation_param_has_curlcurl(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs a curl-curl term.
Definition: cs_equation_param.h:1296
cs_xdef_t * cs_equation_add_bc_by_analytic(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define and initialize a new structure to set a boundary condition related to the given equation param...
Definition: cs_equation_param.cxx:2588
cs_equation_param_t * cs_equation_param_free(cs_equation_param_t *eqp)
Free a cs_equation_param_t.
Definition: cs_equation_param.cxx:1384
cs_xdef_t * cs_equation_add_source_term_by_dof_func(cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function.
Definition: cs_equation_param.cxx:3375
cs_xdef_t * cs_equation_add_bc_by_dof_func(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Define and initialize a new structure to set a boundary condition related to the given cs_equation_pa...
Definition: cs_equation_param.cxx:2790
The term related to the curl-curl operator is needed.
Definition: cs_equation_param.h:101
bool cs_equation_param_has_robin_bc(const cs_equation_param_t *eqp)
Ask if the parameter settings of the equation has requested the treatment of Robin boundary condition...
Definition: cs_equation_param.cxx:2013
void cs_equation_remove_ic(cs_equation_param_t *eqp, const char *z_name)
Remove initial condition from the given equation param structure for a given zone.
Definition: cs_equation_param.cxx:2979
void cs_equation_remove_bc(cs_equation_param_t *eqp, const char *z_name)
Remove boundary condition from the given equation param structure for a given zone.
Definition: cs_equation_param.cxx:2928
static cs_equation_param_t * cs_equation_create_param(const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc)
Create a cs_equation_param_t structure.
Definition: cs_equation_param.h:1539
cs_xdef_t * cs_equation_add_volume_mass_injection_by_dof_func(cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Definition: cs_equation_param.cxx:3667
cs_enforcement_param_t * cs_equation_add_vertex_dof_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t ref_value[], const cs_real_t vtx_values[])
Add an enforcement of the value of degrees of freedom located at the mesh vertices....
Definition: cs_equation_param.cxx:3729
void cs_equation_add_sliding_condition(cs_equation_param_t *eqp, const char *z_name)
Define and initialize a new structure to set a sliding boundary condition related to the given equati...
Definition: cs_equation_param.cxx:3027
cs_xdef_t * cs_equation_add_ic_by_dof_func(cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input)
Definition: cs_equation_param.cxx:2227
Unsteady term is needed.
Definition: cs_equation_param.h:98
Diffusion term is needed. A scalar-/vector-valued Laplacian with div .grad.
Definition: cs_equation_param.h:100
cs_enforcement_param_t * cs_equation_add_face_dof_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t ref_value[], const cs_real_t face_values[])
Add an enforcement of the value of degrees of freedom located at the mesh faces. The spatial discreti...
Definition: cs_equation_param.cxx:3873
cs_xdef_t * cs_equation_add_ic_by_value(cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
Definition: cs_equation_param.cxx:2045
cs_equation_param_t * cs_equation_param_create(const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc)
Definition: cs_equation_param.cxx:833
void cs_equation_param_set_sles(cs_equation_param_t *eqp)
Set parameters for initializing SLES structures used for the resolution of the linear system....
Definition: cs_equation_param.cxx:1487
static bool cs_equation_param_has_graddiv(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs a grad-div term.
Definition: cs_equation_param.h:1316
Reaction term is needed.
Definition: cs_equation_param.h:103
cs_equation_key_t
List of available keys for setting the parameters of an equation.
Definition: cs_equation_param.h:1184
@ CS_EQKEY_SOLVER_RESTART
Definition: cs_equation_param.h:1217
@ CS_EQKEY_SOLVER_RTOL
Definition: cs_equation_param.h:1218
@ CS_EQKEY_ITSOL_RTOL
Definition: cs_equation_param.h:1210
@ CS_EQKEY_SADDLE_SOLVER
Definition: cs_equation_param.h:1229
@ CS_EQKEY_SOLVER_FAMILY
Definition: cs_equation_param.h:1234
@ CS_EQKEY_SOLVER_RESNORM_TYPE
Definition: cs_equation_param.h:1216
@ CS_EQKEY_SADDLE_PRECOND
Definition: cs_equation_param.h:1226
@ CS_EQKEY_ADV_EXTRAPOL
Definition: cs_equation_param.h:1187
@ CS_EQKEY_VERBOSITY
Definition: cs_equation_param.h:1238
@ CS_EQKEY_ITSOL_ATOL
Definition: cs_equation_param.h:1204
@ CS_EQKEY_HODGE_TIME_ALGO
Definition: cs_equation_param.h:1201
@ CS_EQKEY_ADV_STRATEGY
Definition: cs_equation_param.h:1190
@ CS_EQKEY_SADDLE_AUGMENT_SCALING
Definition: cs_equation_param.h:1223
@ CS_EQKEY_ITSOL_MAX_ITER
Definition: cs_equation_param.h:1207
@ CS_EQKEY_ITSOL
Definition: cs_equation_param.h:1203
@ CS_EQKEY_BC_WEAK_PENA_COEFF
Definition: cs_equation_param.h:1195
@ CS_EQKEY_HODGE_DIFF_COEF
Definition: cs_equation_param.h:1200
@ CS_EQKEY_SOLVER_MAX_ITER
Definition: cs_equation_param.h:1214
@ CS_EQKEY_ITSOL_DTOL
Definition: cs_equation_param.h:1205
@ CS_EQKEY_SADDLE_ATOL
Definition: cs_equation_param.h:1222
@ CS_EQKEY_SADDLE_SCHUR_APPROX
Definition: cs_equation_param.h:1228
@ CS_EQKEY_HODGE_DIFF_ALGO
Definition: cs_equation_param.h:1199
@ CS_EQKEY_AMG_TYPE
Definition: cs_equation_param.h:1192
@ CS_EQKEY_SADDLE_RTOL
Definition: cs_equation_param.h:1227
@ CS_EQKEY_ITSOL_RESNORM_TYPE
Definition: cs_equation_param.h:1208
@ CS_EQKEY_ITSOL_EPS
Definition: cs_equation_param.h:1206
@ CS_EQKEY_ADV_UPWIND_PORTION
Definition: cs_equation_param.h:1191
@ CS_EQKEY_SADDLE_MAX_ITER
Definition: cs_equation_param.h:1225
@ CS_EQKEY_SOLVER
Definition: cs_equation_param.h:1211
@ CS_EQKEY_TIME_SCHEME
Definition: cs_equation_param.h:1236
@ CS_EQKEY_DO_LUMPING
Definition: cs_equation_param.h:1196
@ CS_EQKEY_PRECOND
Definition: cs_equation_param.h:1220
@ CS_EQKEY_ADV_CIP_COEF
Definition: cs_equation_param.h:1186
@ CS_EQKEY_PRECOND_BLOCK_TYPE
Definition: cs_equation_param.h:1221
@ CS_EQKEY_ADV_SCHEME
Definition: cs_equation_param.h:1189
@ CS_EQKEY_SOLVER_ATOL
Definition: cs_equation_param.h:1212
@ CS_EQKEY_BC_STRONG_PENA_COEFF
Definition: cs_equation_param.h:1194
@ CS_EQKEY_TIME_THETA
Definition: cs_equation_param.h:1237
@ CS_EQKEY_SADDLE_SOLVER_CLASS
Definition: cs_equation_param.h:1230
@ CS_EQKEY_ADV_FORMULATION
Definition: cs_equation_param.h:1188
@ CS_EQKEY_SOLVER_NO_OP
Definition: cs_equation_param.h:1215
@ CS_EQKEY_EXTRA_OP
Definition: cs_equation_param.h:1198
@ CS_EQKEY_DOF_REDUCTION
Definition: cs_equation_param.h:1197
@ CS_EQKEY_SADDLE_DTOL
Definition: cs_equation_param.h:1224
@ CS_EQKEY_ITSOL_RESTART
Definition: cs_equation_param.h:1209
@ CS_EQKEY_SPACE_SCHEME
Definition: cs_equation_param.h:1235
@ CS_EQKEY_BC_ENFORCEMENT
Definition: cs_equation_param.h:1193
@ CS_EQKEY_SADDLE_VERBOSITY
Definition: cs_equation_param.h:1232
@ CS_EQKEY_HODGE_REAC_ALGO
Definition: cs_equation_param.h:1202
@ CS_EQKEY_OMP_ASSEMBLY_STRATEGY
Definition: cs_equation_param.h:1219
@ CS_EQKEY_SLES_VERBOSITY
Definition: cs_equation_param.h:1233
@ CS_EQKEY_SOLVER_DTOL
Definition: cs_equation_param.h:1213
@ CS_EQKEY_N_KEYS
Definition: cs_equation_param.h:1240
@ CS_EQKEY_SADDLE_SOLVER_RESTART
Definition: cs_equation_param.h:1231
static bool cs_equation_param_has_implicit_advection(const cs_equation_param_t *eqp)
Ask if the parameters of the equation induces an implicit treatment of the advection term.
Definition: cs_equation_param.h:1438
static bool cs_equation_param_has_internal_enforcement(const cs_equation_param_t *eqp)
Ask if the parameters of the equation has an internal enforcement of the degrees of freedom.
Definition: cs_equation_param.h:1417
cs_xdef_t * cs_equation_add_bc_by_time_func(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_time_func_t *t_func, void *input)
Definition: cs_equation_param.cxx:2689
void cs_equation_add_curlcurl(cs_equation_param_t *eqp, cs_property_t *property, int inversion)
Associate a new term related to the curl-curl operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.cxx:3096
cs_enforcement_param_t * cs_equation_add_or_replace_cell_enforcement(cs_equation_param_t *eqp, int enforcement_id, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
Add a new enforcement if enforcement_id does not exist or replace it otherwise. Enforcement of the va...
Definition: cs_equation_param.cxx:4008
cs_xdef_t * cs_equation_add_volume_mass_injection_by_qov(cs_equation_param_t *eqp, const char *z_name, double *quantity)
Definition: cs_equation_param.cxx:3563
cs_xdef_t * cs_equation_add_source_term_by_array(cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array.
Definition: cs_equation_param.cxx:3440
cs_enforcement_param_t * cs_equation_add_edge_dof_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_edges, const cs_lnum_t edge_ids[], const cs_real_t ref_value[], const cs_real_t edge_values[])
Add an enforcement of the value of degrees of freedom located at the mesh edges. The spatial discreti...
Definition: cs_equation_param.cxx:3800
cs_xdef_t * cs_equation_add_bc_by_array(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
Definition: cs_equation_param.cxx:2399
cs_xdef_t * cs_equation_find_bc(cs_equation_param_t *eqp, const char *z_name)
Return pointer to existing boundary condition definition structure for the given equation param struc...
Definition: cs_equation_param.cxx:2888
void cs_equation_param_ensure_consistent_settings(cs_equation_param_t *eqp)
At this stage, the numerical settings should not be modified anymore by the user. One makes a last se...
Definition: cs_equation_param.cxx:1603
cs_param_sles_t * cs_equation_param_get_sles_param(cs_equation_param_t *eqp)
Get the pointer to the set of parameters to handle the SLES solver associated to this set of equation...
Definition: cs_equation_param.cxx:1446
void cs_equation_param_set_quadrature_to_all(cs_equation_param_t *eqp, cs_quadrature_type_t qtype)
Apply the given quadrature rule to all existing definitions under the cs_equation_param_t structure....
Definition: cs_equation_param.cxx:1530
Add an algebraic manipulation to set the value of a given set of interior degrees of freedom.
Definition: cs_equation_param.h:104
void cs_equation_add_advection_scaling_property(cs_equation_param_t *eqp, cs_property_t *property)
Associate a scaling property to the advection.
Definition: cs_equation_param.cxx:3202
void cs_equation_add_xdef_bc(cs_equation_param_t *eqp, cs_xdef_t *xdef)
Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structur...
Definition: cs_equation_param.cxx:2289
Activate a build hook function to get a fine control of the discretization process during the cellwis...
Definition: cs_equation_param.h:106
void cs_equation_add_advection(cs_equation_param_t *eqp, cs_adv_field_t *adv_field)
Associate a new term related to the advection operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.cxx:3178
void cs_equation_param_clear(cs_equation_param_t *eqp)
Free the contents of a cs_equation_param_t.
Definition: cs_equation_param.cxx:1299
Convection term is needed.
Definition: cs_equation_param.h:99
static void cs_equation_copy_param_from(const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fid)
Copy the settings from one cs_equation_param_t structure to another one. The name is not copied.
Definition: cs_equation_param.h:1592
static bool cs_equation_param_has_sourceterm(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs a source term.
Definition: cs_equation_param.h:1396
void cs_equation_param_copy_from(const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fld_id)
Definition: cs_equation_param.cxx:1039
static bool cs_equation_param_has_name(cs_equation_param_t *eqp, const char *name)
Check if a cs_equation_param_t structure has its name member equal to the given name.
Definition: cs_equation_param.h:1487
static void cs_equation_param_set_flag(cs_equation_param_t *eqp, cs_flag_t flag)
Update the flag related to a cs_equation_param_t structure.
Definition: cs_equation_param.h:1258
cs_xdef_t * cs_equation_add_bc_by_value(cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values)
Definition: cs_equation_param.cxx:2317
static bool cs_equation_param_has_diffusion(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs a diffusion term.
Definition: cs_equation_param.h:1276
cs_xdef_t * cs_equation_add_source_term_by_val(cs_equation_param_t *eqp, const char *z_name, cs_real_t *val)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value...
Definition: cs_equation_param.cxx:3268
cs_xdef_t * cs_equation_add_source_term_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical fu...
Definition: cs_equation_param.cxx:3319
void cs_equation_add_time(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the time derivative operator for the equation associated to the given...
Definition: cs_equation_param.cxx:3153
cs_enforcement_param_t * cs_equation_add_cell_enforcement(cs_equation_param_t *eqp, cs_lnum_t n_cells, const cs_lnum_t elt_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[])
Add an enforcement of the value related to the degrees of freedom associated to the list of selected ...
Definition: cs_equation_param.cxx:3942
The term related to the grad-div operator is needed.
Definition: cs_equation_param.h:102
cs_equation_type_t
Type of equations managed by the solver.
Definition: cs_equation_param.h:172
@ CS_EQUATION_TYPE_NAVSTO
Definition: cs_equation_param.h:176
@ CS_EQUATION_TYPE_USER
Definition: cs_equation_param.h:180
@ CS_EQUATION_TYPE_THERMAL
Definition: cs_equation_param.h:178
@ CS_EQUATION_TYPE_GROUNDWATER
Definition: cs_equation_param.h:174
@ CS_EQUATION_TYPE_SOLIDIFICATION
Definition: cs_equation_param.h:179
@ CS_EQUATION_TYPE_PREDEFINED
Definition: cs_equation_param.h:177
@ CS_EQUATION_N_TYPES
Definition: cs_equation_param.h:182
@ CS_EQUATION_TYPE_MAXWELL
Definition: cs_equation_param.h:175
static bool cs_equation_param_has_convection(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs a convection term.
Definition: cs_equation_param.h:1336
static bool cs_equation_param_has_user_hook(const cs_equation_param_t *eqp)
Ask if the parameters of the equation has activated a user hook to get a fine tuning of the cellwise ...
Definition: cs_equation_param.h:1464
static bool cs_equation_param_has_reaction(const cs_equation_param_t *eqp)
Ask if the parameters of the equation needs a reaction term.
Definition: cs_equation_param.h:1356
void cs_equation_add_diffusion(cs_equation_param_t *eqp, cs_property_t *property)
Associate a new term related to the Laplacian operator for the equation associated to the given cs_eq...
Definition: cs_equation_param.cxx:3070
void cs_equation_param_log(const cs_equation_param_t *eqp)
Print the detail of a cs_equation_param_t structure.
Definition: cs_equation_param.cxx:1674
cs_param_saddle_t * cs_equation_param_get_saddle_param(cs_equation_param_t *eqp)
Definition: cs_equation_param.cxx:1468
cs_xdef_t * cs_equation_add_volume_mass_injection_by_analytic(cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input)
Definition: cs_equation_param.cxx:3612
void cs_equation_param_copy_bc(const cs_equation_param_t *ref, cs_equation_param_t *dst)
Copy only the part dedicated to the boundary conditions and the DoF (degrees of freedom) enforcement ...
Definition: cs_equation_param.cxx:1238
Handle the settings of saddle-point systems. These systems arise from the monolithic coupling of the ...
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
cs_param_space_scheme_t
Definition: cs_param_types.h:211
cs_param_advection_form_t
Definition: cs_param_types.h:307
cs_param_bc_type_t
Definition: cs_param_types.h:476
cs_param_advection_extrapol_t
Choice of how to extrapolate the advection field in the advection term.
Definition: cs_param_types.h:419
cs_param_bc_enforce_t
Definition: cs_param_types.h:521
void() cs_time_func_t(double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the current time and any structure gi...
Definition: cs_param_types.h:172
cs_param_time_scheme_t
Definition: cs_param_types.h:274
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:581
cs_param_advection_scheme_t
Definition: cs_param_types.h:351
cs_param_dof_reduction_t
Definition: cs_param_types.h:239
cs_param_advection_strategy_t
Choice of how to handle the advection term in an equation.
Definition: cs_param_types.h:384
@ CS_PARAM_ADVECTION_IMPLICIT_LINEARIZED
Definition: cs_param_types.h:387
@ CS_PARAM_ADVECTION_IMPLICIT_FULL
Definition: cs_param_types.h:386
Type of quadrature to use when computing an integral quantity. This rationale is used for integrals a...
Definition: cs_quadrature.h:84
Definition: cs_advection_field.h:150
Set of data defining an enforcement.
Definition: cs_enforcement.h:89
Definition: cs_equation_param.h:193
cs_real_t strong_pena_bc_coeff
Definition: cs_equation_param.h:529
int istat
Definition: cs_equation_param.h:457
cs_real_t upwind_portion
Definition: cs_equation_param.h:675
int imligr
Definition: cs_equation_param.h:471
int n_reaction_terms
Definition: cs_equation_param.h:701
cs_param_nl_algo_t incremental_algo_type
Definition: cs_equation_param.h:800
int ndircl
Definition: cs_equation_param.h:459
int iwarni
Definition: cs_equation_param.h:214
cs_real_t weak_pena_bc_coeff
Definition: cs_equation_param.h:530
double blencv
Definition: cs_equation_param.h:479
cs_param_bc_enforce_t default_enforcement
Definition: cs_equation_param.h:528
cs_xdef_t ** volume_mass_injections
Definition: cs_equation_param.h:739
cs_property_t * diffusion_property
Definition: cs_equation_param.h:593
cs_param_sles_t * sles_param
Definition: cs_equation_param.h:797
int isstpc
Definition: cs_equation_param.h:466
cs_enforcement_param_t ** enforcement_params
Definition: cs_equation_param.h:760
int space_poly_degree
Definition: cs_equation_param.h:240
int ibdtso
Definition: cs_equation_param.h:465
double cip_scaling_coef
Definition: cs_equation_param.h:676
cs_real_t incremental_relax_factor
Definition: cs_equation_param.h:802
int nswrsm
Definition: cs_equation_param.h:468
cs_param_advection_scheme_t adv_scheme
Definition: cs_equation_param.h:672
int idften
Definition: cs_equation_param.h:462
cs_property_t * curlcurl_property
Definition: cs_equation_param.h:609
double epsrsm
Definition: cs_equation_param.h:482
cs_xdef_t ** ic_defs
Definition: cs_equation_param.h:545
int idiff
Definition: cs_equation_param.h:460
double relaxv
Definition: cs_equation_param.h:485
cs_param_time_scheme_t time_scheme
Definition: cs_equation_param.h:578
int idifft
Definition: cs_equation_param.h:461
cs_hodge_param_t reaction_hodgep
Definition: cs_equation_param.h:700
cs_hodge_param_t graddiv_hodgep
Definition: cs_equation_param.h:624
int imrgra
Definition: cs_equation_param.h:470
int iswdyn
Definition: cs_equation_param.h:463
cs_xdef_t ** source_terms
Definition: cs_equation_param.h:719
cs_hodge_param_t time_hodgep
Definition: cs_equation_param.h:576
int idircl
Definition: cs_equation_param.h:458
cs_param_saddle_t * saddle_param
Definition: cs_equation_param.h:798
cs_param_advection_strategy_t adv_strategy
Definition: cs_equation_param.h:673
cs_adv_field_t * adv_field
Definition: cs_equation_param.h:678
int n_ic_defs
Definition: cs_equation_param.h:544
int dim
Definition: cs_equation_param.h:202
double epsilo
Definition: cs_equation_param.h:481
int nswrgr
Definition: cs_equation_param.h:467
bool do_lumping
Definition: cs_equation_param.h:559
cs_flag_t flag
Definition: cs_equation_param.h:222
cs_flag_t post_flag
Definition: cs_equation_param.h:229
cs_hodge_param_t curlcurl_hodgep
Definition: cs_equation_param.h:608
cs_hodge_param_t diffusion_hodgep
Definition: cs_equation_param.h:592
cs_param_dof_reduction_t dof_reduction
Definition: cs_equation_param.h:234
int verbosity
Definition: cs_equation_param.h:213
double epsrgr
Definition: cs_equation_param.h:483
Definition: cs_equation_param.h:201
int n_source_terms
Definition: cs_equation_param.h:718
cs_param_convergence_t incremental_algo_cvg
Definition: cs_equation_param.h:801
cs_property_t * graddiv_property
Definition: cs_equation_param.h:625
double thetav
Definition: cs_equation_param.h:477
double climgr
Definition: cs_equation_param.h:484
cs_property_t ** reaction_properties
Definition: cs_equation_param.h:702
cs_param_advection_form_t adv_formulation
Definition: cs_equation_param.h:671
cs_property_t * adv_scaling_property
Definition: cs_equation_param.h:679
cs_xdef_t ** bc_defs
Definition: cs_equation_param.h:526
int icoupl
Definition: cs_equation_param.h:474
int imvisf
Definition: cs_equation_param.h:469
int n_volume_mass_injections
Definition: cs_equation_param.h:738
int iwgrec
Definition: cs_equation_param.h:473
int n_bc_defs
Definition: cs_equation_param.h:525
cs_property_t * time_property
Definition: cs_equation_param.h:577
cs_param_advection_extrapol_t adv_extrapol
Definition: cs_equation_param.h:674
int ischcv
Definition: cs_equation_param.h:464
Definition: cs_equation_param.h:524
char *restrict name
Definition: cs_equation_param.h:200
int n_enforcements
Definition: cs_equation_param.h:759
cs_param_space_scheme_t space_scheme
Definition: cs_equation_param.h:233
cs_iter_algo_param_aac_t incremental_anderson_param
Definition: cs_equation_param.h:803
int ircflu
Definition: cs_equation_param.h:472
int iconv
Definition: cs_equation_param.h:456
double theta
Definition: cs_equation_param.h:476
int b_gradient_r
Definition: cs_equation_param.h:487
double blend_st
Definition: cs_equation_param.h:480
Definition: cs_field.h:131
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator.
Definition: cs_hodge.h:151
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:137
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_types.h:537
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition: cs_param_saddle.h:272
Definition: cs_param_sles.h:64
Definition: cs_xdef.h:160
