8.2
cs_xdef.h File Reference
#include "cs_boundary_zone.h"
#include "cs_param_types.h"
#include "cs_quadrature.h"
#include "cs_volume_zone.h"
+ Include dependency graph for cs_xdef.h:
Data Structures
struct  cs_xdef_t
 Structure storing medata for defining a quantity in a very flexible way. More...
struct  cs_xdef_array_context_t
 Context structure when an array is used for the definition. More...
struct  cs_xdef_analytic_context_t
 Context structure when a definition by analytic function is used. More...
struct  cs_xdef_dof_context_t
 Context structure when a definition by DoF function is used. More...
struct  cs_xdef_time_func_context_t
 Context structure when a time step function is used for the definition. More...
Typedefs
typedef void *() cs_xdef_free_input_t(void *input)
 Destroy an input data structure. Complex data structure can be used when a cs_xdef_t structure is defined by an analytic function, a DoF function or a time function. Please refer to cs_xdef_analytic_context_t, cs_xdef_time_func_context_t or cs_xdef_dof_context_t. More...
Enumerations
enum  cs_xdef_type_t {
  CS_XDEF_BY_ANALYTIC_FUNCTION , CS_XDEF_BY_ARRAY , CS_XDEF_BY_DOF_FUNCTION , CS_XDEF_BY_FIELD ,
  CS_XDEF_BY_FUNCTION , CS_XDEF_BY_QOV , CS_XDEF_BY_SUB_DEFINITIONS , CS_XDEF_BY_TIME_FUNCTION ,
  CS_XDEF_BY_VALUE , CS_N_XDEF_TYPES
enum  cs_xdef_support_t { CS_XDEF_SUPPORT_TIME , CS_XDEF_SUPPORT_BOUNDARY , CS_XDEF_SUPPORT_VOLUME , CS_N_XDEF_SUPPORTS }
static cs_real_t cs_xdef_get_scalar_value (cs_xdef_t *def)
 Retrieve the value associated to the given definition. This should be a definition by value and the dimension should be equal to one. More...
static cs_real_tcs_xdef_array_get_values (const cs_xdef_t *def)
 Retrieve the values associated to the given definition. This should be a definition by array. More...
static cs_field_tcs_xdef_field_get (cs_xdef_t *def)
 When the definition relies on a cs_field_t structure, return the pointer to the field structure. More...
cs_xdef_tcs_xdef_volume_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
 Allocate and initialize a new cs_xdef_t structure based on volumic elements. More...
cs_xdef_tcs_xdef_boundary_create (cs_xdef_type_t type, int dim, int z_id, cs_flag_t state, cs_flag_t meta, void *context)
 Allocate and initialize a new cs_xdef_t structure based on boundary elements. More...
cs_xdef_tcs_xdef_timestep_create (cs_xdef_type_t type, cs_flag_t state, cs_flag_t meta, void *context)
 Allocate and initialize a new cs_xdef_t structure for setting the time step. More...
cs_xdef_tcs_xdef_free (cs_xdef_t *d)
 Free a cs_xdef_t structure. More...
cs_xdef_tcs_xdef_copy (cs_xdef_t *src)
 copy a cs_xdef_t structure More...
void cs_xdef_set_input_context (cs_xdef_t *d, void *input)
 In the case of a definition by an analytic function, a time function or a function relying on degrees of freedom (DoFs), this function allows one to set a more or less complex input data structure. This call should be done before the first evaluation of the associated cs_xdef_t structure. More...
void cs_xdef_set_free_input_function (cs_xdef_t *d, cs_xdef_free_input_t *free_input)
 In case of a definition by an analytic function, a time function or a function relying on degrees of freedom (DoFs). One can set a function to free a complex input data structure (please refer to cs_xdef_free_input_t) for more details. More...
void cs_xdef_set_quadrature (cs_xdef_t *d, cs_quadrature_type_t qtype)
 Set the type of quadrature to use for evaluating the given description. More...
cs_quadrature_type_t cs_xdef_get_quadrature (cs_xdef_t *d)
 Get the type of quadrature to use for evaluating the given description. More...
cs_xdef_type_t cs_xdef_get_type (const cs_xdef_t *d)
 Retrieve the flag dedicated to the state. More...
cs_flag_t cs_xdef_get_state_flag (const cs_xdef_t *d)
void cs_xdef_log_setup (const char *prefix, const cs_xdef_t *d)
 Output the settings related to a cs_xdef_t structure in the setup logging file. More...
void cs_xdef_log (cs_log_t log_type, const char *prefix, const cs_xdef_t *d)
 Output the settings related to a cs_xdef_t structure. More...
const char * cs_xdef_type_get_name (cs_xdef_type_t xdef_type)
 Retrieve a pointer to the cs_xdef_type's name string. More...
void cs_xdef_array_set_values (cs_xdef_t *d, bool is_owner, cs_real_t *values)
 In case of definition by array, set the array values after having added this definition. More...
void cs_xdef_array_set_zone_id (cs_xdef_t *d, int z_id)
 In case of definition by array, set the zone id related to the size of the array. By default, the zone id is the same as the zone id related to the definition so that there is no need to call this function. More...
void cs_xdef_array_build_full2subset (const cs_xdef_t *d)
 In case of definition by array, build the full2subset array. The direct members of the cs_xdef_t structure are not modified but the context dedicated to definition by array is updated. d is declared as const to avoid a compiler warning. More...
void cs_xdef_array_set_adjacency (cs_xdef_t *d, const cs_adjacency_t *adj)
 In case of definition by array, set the optional adjacency structure. More...
void cs_xdef_array_set_sublist (cs_xdef_t *d, cs_lnum_t n_elts, const cs_lnum_t elt_ids[])
 In case of definition by array, set the optional sub-list of elements used to link elements in the partial view and in the full-length view. More...
cs_real_tcs_xdef_field_get_values (cs_xdef_t *def)
 Get the current field values in case of definition by field. More...
Typedef Documentation
◆ cs_xdef_free_input_t
typedef void*() cs_xdef_free_input_t(void *input)
[in,out]inputpointer to an input structure associated to a context structure
a NULL pointer
◆ cs_xdef_support_t
Enumerator
Definition for the time step. No zone is attached.
Definition for a boundary zone. Zones are attached to a list of boundary faces.
Definition for a volumic zone. Zones are attached to a list of cells.
CS_N_XDEF_SUPPORTS
◆ cs_xdef_type_t
Enumerator
Definition relying on a cs_analytic_func_t function pointer
CS_XDEF_BY_ARRAY
Definition based on an array
Definition relying on a cs_dof_func_t function pointer
CS_XDEF_BY_FIELD
Definition based on a field (see cs_field_t)
CS_XDEF_BY_FUNCTION
Definition relying on a generic user-defined function. TODO
CS_XDEF_BY_QOV
QOV = Quantity Over a Volume Definition which enables to spread a given quantity inside a volume. Useful to initialized a tracer in a subdomain for instance.
Definition relying on a combination of other CS_XDEF_*** This kind of definition is useful for the definition of a property as the product of two existing ones.
Definition relying on a function for setting the time step (see cs_time_func_t)
CS_XDEF_BY_VALUE
Simple definition by a constant value
CS_N_XDEF_TYPES
◆ cs_xdef_array_build_full2subset()
void cs_xdef_array_build_full2subset ( const cs_xdef_t d)
[in,out]dpointer to a cs_xdef_t structure
◆ cs_xdef_array_get_values()
static cs_real_t* cs_xdef_array_get_values ( const cs_xdef_t def)
inlinestatic
[in]defpointer to a cs_xdef_t structure
the pointer to the array of values
◆ cs_xdef_array_set_adjacency()
void cs_xdef_array_set_adjacency ( cs_xdef_t d,
const cs_adjacency_t adj
[in]adjpointer to the adjacency structure
◆ cs_xdef_array_set_sublist()
void cs_xdef_array_set_sublist ( cs_xdef_t d,
cs_lnum_t  n_elts,
[in]n_eltsnumber of elements in the sub-list
[in]elt_idslist of element ids constituting the sub-list
◆ cs_xdef_array_set_values()
void cs_xdef_array_set_values ( cs_xdef_t d,
bool  is_owner,
cs_real_t values
[in]is_ownermanage or not the lifecycle of the array values
[in]valuesarray of values
◆ cs_xdef_array_set_zone_id()
void cs_xdef_array_set_zone_id ( cs_xdef_t d,
int  z_id
[in]z_idzone id associated to the array size
◆ cs_xdef_boundary_create()
cs_xdef_t* cs_xdef_boundary_create ( cs_xdef_type_t  type,
int  dim,
int  z_id,
cs_flag_t  state,
cs_flag_t  meta,
void *  context
[in]typetype of definition
[in]dimdimension of the values to define
[in]z_idvolume zone id
[in]stateflag to know if this uniform, cellwise, steady...
[in]metametadata associated to this description
[in]contextpointer to a structure
a pointer to the new cs_xdef_t structure
◆ cs_xdef_copy()
cs_xdef_t* cs_xdef_copy ( cs_xdef_t src)
[in]srcpointer to a cs_xdef_t structure to copy
a pointer to a new allocated cs_xdef_t structure
◆ cs_xdef_field_get()
static cs_field_t* cs_xdef_field_get ( cs_xdef_t def)
inlinestatic
◆ cs_xdef_field_get_values()
cs_real_t* cs_xdef_field_get_values ( cs_xdef_t def)
the pointer to the current field values
◆ cs_xdef_free()
cs_xdef_t* cs_xdef_free ( cs_xdef_t d)
NULL
◆ cs_xdef_get_quadrature()
cs_quadrature_type_t cs_xdef_get_quadrature ( cs_xdef_t d)
[in]dpointer to a cs_xdef_t structure
◆ cs_xdef_get_scalar_value()
static cs_real_t cs_xdef_get_scalar_value ( cs_xdef_t def)
inlinestatic
the value of the definition
◆ cs_xdef_get_state_flag()
cs_flag_t cs_xdef_get_state_flag ( const cs_xdef_t d)
the value of the flag
◆ cs_xdef_get_type()
cs_xdef_type_t cs_xdef_get_type ( const cs_xdef_t d)
◆ cs_xdef_log()
void cs_xdef_log ( cs_log_t  log_type,
const char *  prefix,
const cs_xdef_t d
[in]log_typerelated log file to consider
[in]prefixoptional string
◆ cs_xdef_log_setup()
void cs_xdef_log_setup ( const char *  prefix,
const cs_xdef_t d
◆ cs_xdef_set_free_input_function()
void cs_xdef_set_free_input_function ( cs_xdef_t d,
cs_xdef_free_input_t free_input
[in]free_inputpointer to a function which free the input structure
◆ cs_xdef_set_input_context()
void cs_xdef_set_input_context ( cs_xdef_t d,
void *  input
[in]inputpointer to an input structure
◆ cs_xdef_set_quadrature()
void cs_xdef_set_quadrature ( cs_xdef_t d,
[in]qtypetype of quadrature
◆ cs_xdef_timestep_create()
cs_xdef_t* cs_xdef_timestep_create ( cs_xdef_type_t  type,
cs_flag_t  state,
cs_flag_t  meta,
void *  context
[in]contextpointer to a structure storing the parameters (cast on-the-fly according to the type of definition)
◆ cs_xdef_type_get_name()
const char* cs_xdef_type_get_name ( cs_xdef_type_t  xdef_type)
[in]xdef_typetype to query
a pointer to mathing name string
◆ cs_xdef_volume_create()
cs_xdef_t* cs_xdef_volume_create ( cs_xdef_type_t  type,
int  dim,
int  z_id,
cs_flag_t  state,
cs_flag_t  meta,
void *  context
