Include dependency graph for cs_log.h:Go to the source code of this file.
Enumerations | |
| enum | cs_log_t { CS_LOG_DEFAULT , CS_LOG_SETUP , CS_LOG_PERFORMANCE , CS_LOG_WARNINGS , CS_LOG_N_TYPES } |
| void | cs_log_default_activate (bool activate) |
| Update "active" or "inactive" flag of default log. More... | |
| bool | cs_log_default_is_active (void) |
| size_t | cs_log_strlen (const char *s) |
| Count printable length of a character string. More... | |
| void | cs_log_strpad (char *dest, const char *src, size_t width, size_t destsize) |
| Pad a string so that its printable length is the required length. More... | |
| void | cs_log_strpadl (char *dest, const char *src, size_t width, size_t destsize) |
| Pad a string on the left so that its printable length is the required length. More... | |
| void | cs_log_binary_pp_int32 (int32_t code, char buf[33]) |
| Pretty-print int-32 based bit field to string. More... | |
| int | cs_log_vprintf (cs_log_t log, const char *format, va_list arg_ptr) |
| Print log info to a given log type. More... | |
| int | cs_log_printf (cs_log_t log, const char *format,...) |
| int | cs_log_printf_flush (cs_log_t log) |
| Flush output of a log file. More... | |
| void | cs_log_separator (cs_log_t log) |
| Print a separator line in a log file. More... | |
| void | cs_log_timer_array_header (cs_log_t log, int indent, const char *header_title, bool calls) |
| Output timing data array header to a given log. More... | |
| void | cs_log_timer_array (cs_log_t log, int indent, int n_lines, const char *line_titles[], const unsigned calls[], const cs_timer_counter_t time_count[]) |
| Output timing data block to a given log. More... | |
| int | cs_log_warning (const char *format,...) |
| enum cs_log_t |
| void cs_log_binary_pp_int32 | ( | int32_t | code, |
| char | buf[33] | ||
| [in] | code | value to print |
| [out] | buf | output buffer (must be at least 33 bytes). |
| void cs_log_default_activate | ( | bool | activate | ) |
This does not prevent output to the log file, but the flag can be queried using cs_log_default_is_active, so in most cases, this status should be checked before logging output
| [in] | activate | true to activate, false to deactivate. |
| bool cs_log_default_is_active | ( | void | ) |
This does not prevent output to the log file, but the flag can be queried using \
| int cs_log_printf | ( | cs_log_t | log, |
| const char * | format, | ||
The format and variable arguments are similar to those of the printf() type functions.
In parallel, output is only handled by rank 0.
| [in] | log | log file type |
| [in] | format | format string, as printf() and family. |
| [in] | ... | variable arguments based on format string. |
| int cs_log_printf_flush | ( | cs_log_t | log | ) |
If the argument is set to CS_LOG_N_TYPES, all log files are flushed.
| void cs_log_separator | ( | cs_log_t | log | ) |
| size_t cs_log_strlen | ( | const char * | str | ) |
This should also include UTF-8 strings.
| [in] | str | pointer to printable string |
| void cs_log_strpad | ( | char * | dest, |
| const char * | src, | ||
| size_t | width, | ||
| size_t | destsize | ||
This allows pretty-printing with UTF-8 strings, whose actual length may be larger than their printable length in the presence of multibyte characters.
If either the printable length of the string is longer than the target width or the actual length is long than the destination buffer's size, it is truncated.
| [out] | dest | pointer to destination buffer |
| [in] | src | pointer to printable string |
| [in] | width | desired printed length |
| [in] | destsize | destination buffer size |
| void cs_log_strpadl | ( | char * | dest, |
| void cs_log_timer_array | ( | cs_log_t | log, |
| int | indent, | ||
| int | n_lines, | ||
| const char * | line_titles[], | ||
| const unsigned | calls[], | ||
| const cs_timer_counter_t | time_count[] | ||
If the optional array of call counters is used, only lines with a number of calls greater than 0 are logged.
| [in] | indent | indentation before first column |
| [in] | n_lines | number of lines in array, excluding header |
| [in] | line_titles | array of titles for data lines |
| [in] | calls | optional array of call counters, or NULL |
| [in] | time_count | array of time counters |
| void cs_log_timer_array_header | ( | cs_log_t | log, |
| int | indent, | ||
| const char * | header_title, | ||
| bool | calls | ||
| [in] | header_title | title for optional header line |
| [in] | calls | true if calls column is to be used |
| int cs_log_vprintf | ( | cs_log_t | log, |
| va_list | arg_ptr | ||
The format and variable arguments are similar to those of the vprintf() type functions.
| [in] | arg_ptr | variable arguments list pointer |
| int cs_log_warning | ( | const char * | format, |
