34 #if defined(HAVE_CONFIG_H)
35 # include "cs_config.h"
49 #if defined(ENABLE_NLS) && defined(HAVE_GETTEXT)
52 # define _(String) dgettext(PACKAGE, String)
54 # define N_(String) gettext_noop(String)
56 # define N_(String) String
66 # define _(String) (String)
67 # define N_(String) String
68 # define textdomain(String) (String)
69 # define gettext(String) (String)
70 # define dgettext(Domain,String) (String)
71 # define dcgettext(Domain,String,Type) (String)
72 # define bindtextdomain(Domain, Directory) (Domain)
84 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
88 # if !defined(MPI_VERSION)
89 # define MPI_VERSION 1
94 # define MPI_INFO_NULL 0
99 #if defined(HAVE_OPENMP)
103 #if _OPENMP >= 201307
104 #undef HAVE_OPENMP_SIMD
105 #define HAVE_OPENMP_SIMD 1
112 #if defined(HAVE_CUDA)
114 #elif defined(HAVE_SYCL)
116 #elif defined(HAVE_OPENMP_TARGET)
128 #if !defined(__STDC_VERSION__)
129 # define __STDC_VERSION__ 1989
137 #if (__STDC_VERSION__ < 199901L)
139 # if defined(__GNUC__)
140 # define inline __inline__
141 # define restrict __restrict__
151 # ifndef HAVE_RESTRICT
159 #if defined(__GNUC__) || defined(__clang__)
160 # define DEPRECATED __attribute__((deprecated))
161 #elif defined(_MSC_VER)
162 # define DEPRECATED __declspec(deprecated)
190 #elif HAVE_INTTYPES_H
191 # include <inttypes.h>
198 #if defined(HAVE_SYS_TYPES_H)
199 #include <sys/types.h>
205 # include <stdbool.h>
209 # define _Bool signed char;
217 # define __bool_true_false_are_defined 1
222 #if !defined(HAVE_INT32_T)
223 # if (SIZEOF_INT == 4)
225 # elif (SIZEOF_SHORT == 4)
226 typedef short int32_t;
234 #if !defined(HAVE_INT64_T)
235 # if (SIZEOF_INT == 8)
237 # elif (SIZEOF_LONG == 8)
238 typedef long int64_t;
239 # elif (HAVE_LONG_LONG == 8)
240 typedef long long int64_t;
248 #if !defined(HAVE_UINT32_T)
249 # if (SIZEOF_INT == 4)
250 typedef unsigned uint32_t;
251 # elif (SIZEOF_SHORT == 4)
252 typedef unsigned short uint32_t;
260 #if !defined(HAVE_UINT64_T)
261 # if (SIZEOF_INT == 8)
262 typedef unsigned uint64_t;
263 # elif (SIZEOF_LONG == 8)
264 typedef unsigned long uint64_t;
265 # elif (HAVE_LONG_LONG)
266 typedef unsigned long long uint64_t;
311 #if defined(HAVE_LONG_GNUM)
312 #if (SIZEOF_LONG == 8)
314 #elif (SIZEOF_LONG_LONG == 8)
325 #if defined(HAVE_LONG_LNUM)
399 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
401 # define CS_MPI_REAL MPI_DOUBLE
405 # if defined(HAVE_LONG_GNUM)
406 # if (SIZEOF_LONG == 8)
407 # define CS_MPI_GNUM MPI_UNSIGNED_LONG
408 # elif (SIZEOF_LONG_LONG == 8)
409 # if defined(MPI_UNSIGNED_LONG_LONG)
410 # define CS_MPI_GNUM MPI_UNSIGNED_LONG_LONG
411 # elif defined(MPI_LONG_LONG)
412 # define CS_MPI_GNUM MPI_LONG_LONG
415 # if !defined(CS_MPI_GNUM)
419 # define CS_MPI_GNUM MPI_UNSIGNED
424 # if defined(HAVE_LONG_LNUM)
425 # define CS_MPI_LNUM MPI_LONG
427 # define CS_MPI_LNUM MPI_INT
430 # define CS_MPI_EFLAG MPI_UNSIGNED
431 # define CS_MPI_FLAG MPI_UNSIGNED_SHORT
432 # define CS_MPI_COORD MPI_DOUBLE
439 #if defined(HAVE_LONG_GNUM)
440 # define CS_GNUM_TYPE CS_UINT64
441 #elif (SIZEOF_INT == 8)
442 # define CS_GNUM_TYPE CS_UINT64
444 # define CS_GNUM_TYPE CS_UINT32
447 #if defined(HAVE_LONG_LNUM)
448 # if (SIZEOF_LONG == 8)
449 # define CS_LNUM_TYPE CS_INT64
451 # define CS_LNUM_TYPE CS_INT32
454 # if (SIZEOF_INT == 8)
455 # define CS_LNUM_TYPE CS_INT64
457 # define CS_LNUM_TYPE CS_INT32
461 #if (SIZEOF_INT == 8)
462 # define CS_INT_TYPE CS_INT64
464 # define CS_INT_TYPE CS_INT32
467 #if (SIZEOF_INT == 8)
468 # define CS_UINT_TYPE CS_UINT64
470 # define CS_UINT_TYPE CS_UINT32
473 #define CS_FLAG_TYPE CS_UINT16
474 #define CS_EFLAG_TYPE CS_UINT_TYPE
475 #define CS_REAL_TYPE CS_DOUBLE
476 #define CS_COORD_TYPE CS_DOUBLE
482 #define CS_THR_MIN 128
487 #define CS_CL_SIZE 64
493 #define CS_ABS(a) ((a) < 0 ? -(a) : (a))
494 #define CS_MIN(a,b) ((a) < (b) ? (a) : (b))
495 #define CS_MAX(a,b) ((a) > (b) ? (a) : (b))
517 #define CS_UNUSED(x) (void)(x)
518 #define CS_NO_WARN_IF_UNUSED(x) (void)(x)
527 #if defined(__cplusplus)
528 # define BEGIN_C_DECLS extern "C" {
529 # define END_C_DECLS }
531 # define BEGIN_C_DECLS
541 #define CS_F_HOST __host__
542 #define CS_F_DEVICE __device__
543 #define CS_F_HOST_DEVICE __host__ __device__
549 #define CS_F_HOST_DEVICE
562 #if !defined (__hpux)
563 #define CS_PROCF(x, y) x##_
565 #define CS_PROCF(x, y) x
575 #define CS_ARGF_SUPP_CHAINE , ...
592 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
609 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
651 return ((i > 0) ? ((i-1)/m+1)*m : 0);
666 #if defined(HAVE_OPENMP)
667 return omp_get_thread_num();
int cs_glob_n_ranks
Definition: cs_defs.c:175
cs_datatype_t
Definition: cs_defs.h:284
@ CS_FLOAT
Definition: cs_defs.h:288
@ CS_CHAR
Definition: cs_defs.h:287
@ CS_UINT16
Definition: cs_defs.h:290
@ CS_INT64
Definition: cs_defs.h:292
@ CS_UINT64
Definition: cs_defs.h:294
@ CS_DOUBLE
Definition: cs_defs.h:289
@ CS_UINT32
Definition: cs_defs.h:293
@ CS_INT32
Definition: cs_defs.h:291
@ CS_DATATYPE_NULL
Definition: cs_defs.h:286
void *() cs_destructor_t(void *s)
Destroy a given structure.
Definition: cs_defs.h:627
cs_lnum_t cs_lnum_3_t[3]
Definition: cs_defs.h:341
const char * cs_datatype_name[]
Definition: cs_defs.c:143
char cs_byte_t
Definition: cs_defs.h:333
Definition: cs_defs.h:332
const size_t cs_datatype_size[]
Definition: cs_defs.c:133
cs_real_33_t cs_real_332_t[2]
vector of 2 3x3 matrices of floating-point values
Definition: cs_defs.h:368
int cs_glob_node_rank_id
Definition: cs_defs.c:177
cs_real_t cs_real_69_t[6][9]
Definition: cs_defs.h:366
cs_nreal_t cs_nreal_3_t[3]
Definition: cs_defs.h:373
const char cs_empty_string[]
Definition: cs_defs.c:129
int cs_glob_n_threads
Definition: cs_defs.c:172
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:340
static int cs_get_thread_id(void)
Retrieve the associated thread id (0 if no OpenMP or if outside an OpenMP region)
Definition: cs_defs.h:661
int cs_glob_node_n_ranks
Definition: cs_defs.c:178
cs_real_t cs_real_4_t[4]
vector of 4 floating-point values
Definition: cs_defs.h:348
MPI_Datatype cs_datatype_to_mpi[]
Definition: cs_defs.c:157
cs_real_t cs_real_10_t[10]
Definition: cs_defs.h:352
cs_real_t cs_real_99_t[9][9]
Definition: cs_defs.h:358
double cs_coord_t
Definition: cs_defs.h:330
cs_real_t cs_real_34_t[3][4]
Definition: cs_defs.h:362
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:357
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
cs_coord_t cs_coord_3_t[3]
Definition: cs_defs.h:343
cs_real_66_t cs_real_662_t[2]
Definition: cs_defs.h:370
cs_real_t cs_real_2_t[2]
Definition: cs_defs.h:346
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:310
cs_interlace_t
Definition: cs_defs.h:500
@ CS_INTERLACE
Definition: cs_defs.h:502
@ CS_NO_INTERLACE
Definition: cs_defs.h:503
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:349
static cs_lnum_t cs_align(cs_lnum_t i, cs_lnum_t m)
Given a base index i, return the next index aligned with a size m.
Definition: cs_defs.h:645
cs_real_t cs_real_333_t[3][3][3]
Definition: cs_defs.h:360
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:356
MPI_Comm cs_glob_mpi_comm
Definition: cs_defs.c:183
Definition: cs_defs.h:325
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:364
double cs_nreal_t
Definition: cs_defs.h:336
cs_real_t cs_real_9_t[9]
Definition: cs_defs.h:351
cs_real_t cs_real_23_t[2][3]
Definition: cs_defs.h:354
unsigned short int cs_flag_t
Definition: cs_defs.h:334
int cs_glob_rank_id
Definition: cs_defs.c:174
Definition: cs_defs.h:376
Definition: cs_defs.h:386
