55 #define CS_FIELD_INTENSIVE (1 << 0)
58 #define CS_FIELD_EXTENSIVE (1 << 1)
63 #define CS_FIELD_VARIABLE (1 << 2)
66 #define CS_FIELD_PROPERTY (1 << 3)
69 #define CS_FIELD_POSTPROCESS (1 << 4)
72 #define CS_FIELD_ACCUMULATOR (1 << 5)
75 #define CS_FIELD_USER (1 << 6)
78 #define CS_FIELD_CDO (1 << 7)
282 const char *name_suffix,
519 const char *name_suffix);
537 const char *name_suffix);
641 double default_value,
663 const char *default_value,
689 const void *default_value,
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_field.c:2465
const void * cs_field_get_key_struct_const_ptr(const cs_field_t *f, int key_id)
Return a read-only pointer to a simple structure for a given key to a field.
Definition: cs_field.c:3787
const char * cs_field_get_label(const cs_field_t *f)
Return a label associated with a field.
Definition: cs_field.c:4514
const char * cs_field_get_key_str(const cs_field_t *f, int key_id)
Return a string for a given key associated with a field.
Definition: cs_field.c:3515
int cs_field_set_key_int(cs_field_t *f, int key_id, int value)
Assign a integer value for a given key to a field.
Definition: cs_field.c:3165
int cs_field_clear_key_int_bits(cs_field_t *f, int key_id, int mask)
Set integer bits matching a mask to 0 for a given key for a field.
Definition: cs_field.c:3315
void cs_field_bc_coeffs_init(cs_field_bc_coeffs_t *bc_coeffs)
Definition: cs_field.c:1501
void cs_field_init_bc_coeffs(cs_field_t *f)
Initialize boundary condition coefficients arrays.
Definition: cs_field.c:2069
cs_field_t * cs_field_by_composite_name_try(const char *name_prefix, const char *name_suffix)
Return a pointer to a field based on a composite name if present.
Definition: cs_field.c:2567
int cs_field_define_key_int(const char *name, int default_value, int type_flag)
Define a key for an integer value by its name and return an associated id.
Definition: cs_field.c:2774
cs_field_t * cs_field_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Create a field descriptor.
Definition: cs_field.c:1613
Definition: cs_field.c:3213
cs_field_t * cs_field_create_by_composite_name(const char *name_prefix, const char *name_suffix, int type_flag, int location_id, int dim, bool has_previous)
Definition: cs_field.c:1650
int cs_field_key_flag(int key_id)
Get the type flag associated with a given key id.
Definition: cs_field.c:3011
void cs_field_set_n_time_vals(cs_field_t *f, int n_time_vals)
Change the number of time values managed by a field.
Definition: cs_field.c:1767
Return a pointer to a field based on its name if present.
Definition: cs_field.c:2515
int cs_field_define_key_str(const char *name, const char *default_value, int type_flag)
Define a key for a string value by its name and return an associated id.
Definition: cs_field.c:2848
void cs_field_set_values(cs_field_t *f, cs_real_t c)
Set current field values to the given constant.
Definition: cs_field.c:2288
void cs_field_destroy_all_keys(void)
Destroy all defined field keys and associated values.
Definition: cs_field.c:2979
int cs_field_n_fields(void)
Definition: cs_field.c:1593
void cs_field_log_defs(void)
Print info relative to all field definitions to log file.
Definition: cs_field.c:3846
bool cs_field_is_key_locked(const cs_field_t *f, int key_id)
Query if a given key has been locked for a field.
Definition: cs_field.c:3088
void cs_field_allocate_values(cs_field_t *f)
Allocate arrays for field values.
Definition: cs_field.c:1828
cs_field_t * cs_field_find_or_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Return a field matching a given name and attributes, creating it if necessary.
Definition: cs_field.c:1707
void cs_field_bc_coeffs_shallow_copy(const cs_field_bc_coeffs_t *ref, cs_field_bc_coeffs_t *copy)
Shallow copy of boundary condition coefficients.
Definition: cs_field.c:1533
int cs_field_set_key_str(cs_field_t *f, int key_id, const char *str)
Assign a character string for a given key to a field.
Definition: cs_field.c:3463
int cs_field_set_key_struct(cs_field_t *f, int key_id, void *s)
Assign a simple structure for a given key to a field.
Definition: cs_field.c:3584
cs_field_error_type_t
Definition: cs_field.h:89
@ CS_FIELD_INVALID_KEY_NAME
Definition: cs_field.h:92
@ CS_FIELD_INVALID_FIELD
Definition: cs_field.h:96
@ CS_FIELD_INVALID_TYPE
Definition: cs_field.h:95
@ CS_FIELD_INVALID_CATEGORY
Definition: cs_field.h:94
@ CS_FIELD_LOCKED
Definition: cs_field.h:97
@ CS_FIELD_OK
Definition: cs_field.h:91
@ CS_FIELD_INVALID_KEY_ID
Definition: cs_field.h:93
void() cs_field_clear_key_struct_t(void *t)
Definition: cs_field.h:188
bool cs_field_is_key_set(const cs_field_t *f, int key_id)
Query if a given key has been set for a field.
Definition: cs_field.c:3057
int cs_field_set_key_int_bits(cs_field_t *f, int key_id, int mask)
Set integer bits matching a mask to 1 for a given key for a field.
Definition: cs_field.c:3284
void cs_field_key_disable_setup_log(int key_id)
Disable logging setup values associated with a given key.
Definition: cs_field.c:3035
void * cs_field_get_key_struct_ptr(cs_field_t *f, int key_id)
Return a pointer to a simple structure for a given key to a field.
Definition: cs_field.c:3709
int cs_field_define_sub_key(const char *name, int parent_id)
Define a sub key.
Definition: cs_field.c:2953
void cs_field_allocate_or_map_all(void)
Allocate arrays for all defined fields based on their location.
Definition: cs_field.c:2434
const void * cs_field_get_key_struct(const cs_field_t *f, int key_id, void *s)
Return a structure for a given key associated with a field.
Definition: cs_field.c:3636
void cs_field_bc_coeffs_free_copy(const cs_field_bc_coeffs_t *ref, cs_field_bc_coeffs_t *copy)
Free copy of boundary condition coefficients.
Definition: cs_field.c:1556
void cs_field_destroy_all(void)
Destroy all defined fields.
Definition: cs_field.c:2373
void cs_field_map_values(cs_field_t *f, cs_real_t *val, cs_real_t *val_pre)
Map existing value arrays to field descriptor.
Definition: cs_field.c:1859
void cs_field_log_info(const cs_field_t *f, int log_keywords)
Print info relative to a given field to log file.
Definition: cs_field.c:3984
void cs_field_log_key_defs(void)
Print info relative to all key definitions to log file.
Definition: cs_field.c:4179
double cs_field_get_key_double(const cs_field_t *f, int key_id)
Return a floating point value for a given key associated with a field.
Definition: cs_field.c:3393
const char * cs_glob_field_comp_name_9[]
const char * cs_glob_field_comp_name_6[]
int cs_field_define_key_struct(const char *name, const void *default_value, cs_field_log_key_struct_t *log_func, cs_field_log_key_struct_t *log_func_default, cs_field_clear_key_struct_t *clear_func, size_t size, int type_flag)
Define a key for a structure value by its name and return an associated id.
Definition: cs_field.c:2900
Definition: cs_field.c:2719
int cs_field_define_key_double(const char *name, double default_value, int type_flag)
Define a key for an floating point value by its name and return an associated id.
Definition: cs_field.c:2811
void cs_field_define_keys_base(void)
Define base keys.
Definition: cs_field.c:4488
int cs_field_key_id_try(const char *name)
Return an id associated with a given key name if present.
Definition: cs_field.c:2746
void cs_field_log_fields(int log_keywords)
Print info relative to all defined fields to log file.
Definition: cs_field.c:4118
cs_field_t * cs_field_by_composite_name(const char *name_prefix, const char *name_suffix)
Return a pointer to a field based on a composite name.
Definition: cs_field.c:2539
void cs_field_current_to_previous(cs_field_t *f)
Copy current field values to previous values if applicable.
Definition: cs_field.c:2315
void cs_field_log_all_key_vals(bool log_defaults)
Print info relative to all given field keys to log file.
Definition: cs_field.c:4457
int cs_field_lock_key(cs_field_t *f, int key_id)
Lock a field relative to a given key.
Definition: cs_field.c:3120
void cs_field_allocate_bc_coeffs(cs_field_t *f, bool have_flux_bc, bool have_mom_bc, bool have_conv_bc, bool have_exch_bc)
Allocate boundary condition coefficients arrays.
Definition: cs_field.c:1912
void cs_field_component_id_by_name(const char *name, int *f_id, int *c_id)
Return the id of a defined field and an associated component based on a component name.
Definition: cs_field.c:2630
int cs_field_set_key_double(cs_field_t *f, int key_id, double value)
Assign a floating point value for a given key to a field.
Definition: cs_field.c:3345
int cs_field_id_by_name(const char *name)
Return the id of a defined field based on its name.
Definition: cs_field.c:2609
void() cs_field_log_key_struct_t(const void *t)
Definition: cs_field.h:178
Definition: cs_field.c:2489
const char * cs_glob_field_comp_name_3[]
void cs_field_allocate_gradient(cs_field_t *f)
Allocate arrays for field gradient.
Definition: cs_field.c:2264
void cs_field_log_key_vals(int key_id, bool log_defaults)
Print info relative to a given field key to log file.
Definition: cs_field.c:4333
@ t
Field boundary condition descriptor (for variables)
Definition: cs_field.h:104
cs_real_t * rcodcl2
Definition: cs_field.h:110
cs_real_t * af
Definition: cs_field.h:115
int location_id
Definition: cs_field.h:106
cs_real_t * bc
Definition: cs_field.h:120
cs_real_t * rcodcl3
Definition: cs_field.h:111
cs_real_t * b
Definition: cs_field.h:114
cs_real_t * a
Definition: cs_field.h:113
cs_real_t * ad
Definition: cs_field.h:117
cs_real_t * hint
Definition: cs_field.h:122
cs_real_t * ac
Definition: cs_field.h:119
cs_real_t * rcodcl1
Definition: cs_field.h:109
cs_real_t * bf
Definition: cs_field.h:116
cs_real_t * bd
Definition: cs_field.h:118
int * icodcl
Definition: cs_field.h:108
cs_real_t * _hext
Definition: cs_field.h:123
Definition: cs_field.h:131
int location_id
Definition: cs_field.h:140
cs_real_t * grad
Definition: cs_field.h:159
cs_real_t ** vals
Definition: cs_field.h:144
int type
Definition: cs_field.h:136
int n_time_vals
Definition: cs_field.h:142
cs_real_t * val_pre
Definition: cs_field.h:155
const char * name
Definition: cs_field.h:133
bool is_owner
Definition: cs_field.h:166
cs_real_t * val
Definition: cs_field.h:152
int id
Definition: cs_field.h:135
Definition: cs_field.h:163
int dim
Definition: cs_field.h:138
