8.2
cs_base.h
1 #ifndef __CS_BASE_H__
2 #define __CS_BASE_H__
5  * Definitions, global variables, and base functions
30 #include "cs_defs.h"
36 #include <stdio.h>
39  * Local headers
42 /*=============================================================================
43  * Macro definitions
45
46 /* Application type name */
48 #define CS_APP_NAME "code_saturne"
49 #define CS_APP_VERSION PACKAGE_VERSION /* PACKAGE_VERSION from autoconf */
50
51 /* System type name */
52
53 #if defined(__linux__) || defined(__linux) || defined(linux)
54 #define _CS_ARCH_Linux
55
56 #endif
57
58 /* On certain architectures such as IBM Blue Gene, some operations may
59  * be better optimized on memory-aligned data (if 0 here, no alignment
60  * is leveraged). This alignment is not exploited yet in code_saturne. */
61
62 #define CS_MEM_ALIGN 0
63
64 #define CS_BASE_STRING_LEN 80
65
67
69
70 /*============================================================================
71  * Type definitions
72  *============================================================================*/
73
74 /* Function pointers for extra cleanup operations to be called when
75  entering cs_exit() or bft_error() */
76
77 typedef void (cs_base_atexit_t) (void);
78
79 /* Function pointers for SIGINT (or similar) handler */
80
81 typedef void (cs_base_sigint_handler_t) (int signum);
82
83 /*=============================================================================
84  * Global variable definitions
85  *============================================================================*/
86
87 /*=============================================================================
88  * Public function prototypes
89  *============================================================================*/
90
91 /*----------------------------------------------------------------------------*/
99 /*----------------------------------------------------------------------------*/
100
101 static inline const char *
102 cs_base_strtf(bool boolean)
103 {
104  if (boolean)
105  return "*True*";
106  else
107  return "*False*";
108 }
109
110 /*----------------------------------------------------------------------------
111  * First analysis of the command line to determine an application name.
112  *
113  * If no name is defined by the command line, a name is determined based
114  * on the working directory.
115  *
116  * The caller is responsible for freeing the returned string.
117  *
118  * parameters:
119  * argc <-- number of command line arguments
120  * argv <-- array of command line arguments
121  *
122  * returns:
123  * pointer to character string with application name
124  *----------------------------------------------------------------------------*/
125
126 char *
127 cs_base_get_app_name(int argc,
128  const char *argv[]);
129
130 /*----------------------------------------------------------------------------
131  * Print logfile header
132  *
133  * parameters:
134  * argc <-- number of command line arguments
135  * argv <-- array of command line arguments
136  *----------------------------------------------------------------------------*/
137
138 void
139 cs_base_logfile_head(int argc,
140  char *argv[]);
141
142 #if defined(HAVE_MPI)
143
144 /*----------------------------------------------------------------------------
145  * First analysis of the command line and environment variables to determine
146  * if we require MPI, and initialization if necessary.
147  *
148  * parameters:
149  * argc <-> number of command line arguments
150  * argv <-> array of command line arguments
151  *
152  * Global variables `cs_glob_n_ranks' (number of code_saturne processes)
153  * and `cs_glob_rank_id' (rank of local process) are set by this function.
154  *----------------------------------------------------------------------------*/
155
156 void
157 cs_base_mpi_init(int *argc,
158  char **argv[]);
159
160 /*----------------------------------------------------------------------------*/
169 /*----------------------------------------------------------------------------*/
170
171 MPI_Comm
172 cs_base_get_rank_step_comm(int rank_step);
173
174 /*----------------------------------------------------------------------------
175  * Return a reduced communicator matching a multiple of the total
176  * number of ranks, and given a parent communicator.
177  *
178  * Compared to \ref cs_base_get_rank_step_comm, this function is
179  * collective only on the provided communicator.
180  *
181  * This updates the number of reduced communicators if necessary.
182  *
183  * parameters:
184  * parent_comm <-- associated parent communicator (must be either
185  * cs_glob_mpi_comm or a communicator returned by a
186  * previous
187  * rank_step <-- associated multiple of ranks of parent communicator
188  *----------------------------------------------------------------------------*/
189
190 MPI_Comm
191 cs_base_get_rank_step_comm_recursive(MPI_Comm parent_comm,
192  int rank_step);
193
194 #endif /* defined(HAVE_MPI) */
195
196 /*----------------------------------------------------------------------------
197  * Exit, with handling for both normal and error cases.
198  *
199  * Finalize MPI if necessary.
200  *
201  * parameters:
202  * status <-- value to be returned to the parent:
203  * EXIT_SUCCESS / 0 for the normal case,
204  * EXIT_FAILURE or other nonzero code for error cases.
205  *----------------------------------------------------------------------------*/
206
207 void
208 cs_exit(int status);
209
210 /*----------------------------------------------------------------------------
211  * Initialize error and signal handlers.
212  *
213  * parameters:
214  * signal_defaults <-- leave default signal handlers in place if true.
215  *----------------------------------------------------------------------------*/
216
217 void
218 cs_base_error_init(bool signal_defaults);
219
220 /*----------------------------------------------------------------------------
221  * Initialize management of memory allocated through BFT.
222  *----------------------------------------------------------------------------*/
223
224 void
225 cs_base_mem_init(void);
226
227 /*----------------------------------------------------------------------------
228  * Finalize management of memory allocated through BFT.
229  *
230  * A summary of the consumed memory is given.
231  *----------------------------------------------------------------------------*/
232
233 void
235
236 /*----------------------------------------------------------------------------
237  * Restore signal handlers in case they were modified by another application.
238  *----------------------------------------------------------------------------*/
239
240 void
242
243 /*----------------------------------------------------------------------------
244  * Print summary of running time, including CPU and elapsed times.
245  *----------------------------------------------------------------------------*/
246
247 void
249
250 /*----------------------------------------------------------------------------*/
259 /*----------------------------------------------------------------------------*/
260
261 void
262 cs_base_update_status(const char *format,
263  ...);
264
265 /*----------------------------------------------------------------------------
266  * Set tracing of progress on or off.
267  *
268  * parameters:
269  * trace <-- trace progress to stdout
270  *----------------------------------------------------------------------------*/
271
272 void
273 cs_base_trace_set(bool trace);
274
275
276 /*----------------------------------------------------------------------------
277  * Set output file name and suppression flag for bft_printf().
278  *
279  * This allows redirecting or suppressing logging for different ranks.
280  *
281  * parameters:
282  * log_name <-- base file name for log
283  * rn_log_flag <-- redirection for ranks > 0 log:
284  * rn_log_flag <-- redirection for ranks > 0 log:
285  * false: to "/dev/null" (suppressed)
286  * true: to <log_name>_r*.log" file;
287  *----------------------------------------------------------------------------*/
288
289 void
290 cs_base_bft_printf_init(const char *log_name,
291  bool rn_log_flag);
292
293 /*----------------------------------------------------------------------------
294  * Replace default bft_printf() mechanism with internal mechanism.
295  *
296  * This allows redirecting or suppressing logging for different ranks.
297  *
298  * parameters:
299  * log_name <-- base file name for log
300  *----------------------------------------------------------------------------*/
301
302 void
303 cs_base_bft_printf_set(const char *log_name,
304  bool rn_log_flag);
305
306 /*----------------------------------------------------------------------------
307  * Return name of default log file.
308  *
309  * cs_base_bft_printf_set or cs_base_c_bft_printf_set() must have
310  * been called before this.
311  *
312  * returns:
313  * name of default log file
314  *----------------------------------------------------------------------------*/
315
316 const char *
318
319 /*----------------------------------------------------------------------------
320  * Return flag indicating if the default log file output is suppressed.
321  *
322  * cs_base_bft_printf_set or cs_base_c_bft_printf_set() must have
323  * been called before this.
324  *
325  * returns:
326  * output suppression flag
327  *----------------------------------------------------------------------------*/
328
329 bool
331
332 /*----------------------------------------------------------------------------
333  * Print a warning message header.
334  *
335  * parameters:
336  * file_name <-- name of source file
337  * line_nume <-- line number in source file
338  *----------------------------------------------------------------------------*/
339
340 void
341 cs_base_warn(const char *file_name,
342  int line_num);
343
344 /*----------------------------------------------------------------------------
345  * Define a function to be called when entering cs_exit() or bft_error().
346  *
347  * Compared to the C atexit(), only one function may be called (latest
348  * setting wins), but the function is called slightly before exit,
349  * so it is well adapted to cleanup such as flushing of non-C API logging.
350  *
351  * parameters:
352  * fct <-- pointer tu function to be called
353  *----------------------------------------------------------------------------*/
354
355 void
357
358 /*----------------------------------------------------------------------------
359  * Set handler function for SIGINT or similar.
360  *
361  * When first encountered, SIGINT will call that handler if present,
362  * then revert to the general handler if encountered again.
363  *
364  * parameters:
365  * h <-- pointer to function to be called
366  *----------------------------------------------------------------------------*/
367
368 void
370
371 /*----------------------------------------------------------------------------
372  * Clean a string representing options.
373  *
374  * Characters are converted to lowercase, leading and trailing whitespace
375  * is removed, and multiple whitespaces or tabs are replaced by single
376  * spaces.
377  *
378  * parameters:
379  * s <-> string to be cleaned
380  *----------------------------------------------------------------------------*/
381
382 void
384
385 /*----------------------------------------------------------------------------
386  * Return a string providing locale path information.
387  *
388  * This is normally the path determined upon configuration, but may be
389  * adapted for movable installs using the CS_ROOT_DIR environment variable.
390  *
391  * returns:
392  * locale path
393  *----------------------------------------------------------------------------*/
394
395 const char *
397
398 /*----------------------------------------------------------------------------
399  * Return a string providing package data path information.
400  *
401  * This is normally the path determined upon configuration, but may be
402  * adapted for movable installs using the CS_ROOT_DIR environment variable.
403  *
404  * returns:
405  * package data path
406  *----------------------------------------------------------------------------*/
407
408 const char *
410
411 /*----------------------------------------------------------------------------
412  * Return a string providing loadable library path information.
413  *
414  * This is normally the path determined upon configuration, but may be
415  * adapted for movable installs using the CS_ROOT_DIR environment variable.
416  *
417  * returns:
418  * package loadable library (plugin) path
419  *----------------------------------------------------------------------------*/
420
421 const char *
423
424 /*----------------------------------------------------------------------------
425  * Ensure bool argument has value 0 or 1.
426  *
427  * This allows working around issues with Intel compiler C bindings,
428  * which seem to pass incorrect values in some cases.
429  *
430  * parameters:
431  * b <-> pointer to bool
432  *----------------------------------------------------------------------------*/
433
434 void
435 cs_base_check_bool(bool *b);
436
437 /*----------------------------------------------------------------------------
438  * Open a data file in read mode.
439  *
440  * If a file of the given name in the working directory is found, it
441  * will be opened. Otherwise, it will be searched for in the "data/thch"
442  * subdirectory of pkgdatadir.
443  *
444  * parameters:
445  * base_name <-- base file name
446  *
447  * returns:
448  * pointer to opened file
449  *----------------------------------------------------------------------------*/
450
451 FILE *
452 cs_base_open_properties_data_file(const char *base_name);
453
454 #if defined(HAVE_DLOPEN)
455
456 /*----------------------------------------------------------------------------*/
464 /*----------------------------------------------------------------------------*/
465
466 void*
467 cs_base_dlopen(const char *filename);
468
469 /*----------------------------------------------------------------------------*/
481 /*----------------------------------------------------------------------------*/
482
483 void*
484 cs_base_dlopen_plugin(const char *name);
485
486 /*----------------------------------------------------------------------------*/
492 /*----------------------------------------------------------------------------*/
493
494 int
496
497 /*----------------------------------------------------------------------------*/
503 /*----------------------------------------------------------------------------*/
504
505 void
506 cs_base_dlopen_set_flags(int flags);
507
508 /*----------------------------------------------------------------------------*/
520 /*----------------------------------------------------------------------------*/
521
522 void
523 cs_base_dlclose(const char *filename,
524  void *handle);
525
526 /*----------------------------------------------------------------------------*/
536 /*----------------------------------------------------------------------------*/
537
538 void *
540  const char *name,
541  bool errors_are_fatal);
542
543
544 #endif /* defined(HAVE_DLOPEN) */
545
546 /*----------------------------------------------------------------------------*/
553 /*----------------------------------------------------------------------------*/
554
555 void
556 cs_base_backtrace_dump(FILE *f,
557  int lv_start);
558
559 /*----------------------------------------------------------------------------*/
568 /*----------------------------------------------------------------------------*/
569
570 void
572
573 /*----------------------------------------------------------------------------*/
580 /*----------------------------------------------------------------------------*/
581
582 void
584
585 /*----------------------------------------------------------------------------*/
605 /*----------------------------------------------------------------------------*/
606
607 void
608 cs_base_get_run_identity(char **run_id,
609  char **case_name,
610  char **study_name);
611
612 /*----------------------------------------------------------------------------*/
613
615
616 #endif /* __CS_BASE_H__ */
void cs_base_option_string_clean(char *s)
Definition: cs_base.c:2296
const char * cs_base_get_localedir(void)
Definition: cs_base.c:2326
void cs_base_mpi_init(int *argc, char **argv[])
Definition: cs_base.c:1247
void cs_base_dlclose(const char *filename, void *handle)
Unload a dynamic library.
Definition: cs_base.c:2555
void cs_base_sigint_handler_set(cs_base_sigint_handler_t *const h)
Definition: cs_base.c:2279
int cs_base_dlopen_get_flags(void)
Get flags for dlopen.
Definition: cs_base.c:2521
void cs_base_time_summary(void)
Definition: cs_base.c:1897
const char * cs_base_bft_printf_name(void)
Definition: cs_base.c:2214
void cs_exit(int status)
Definition: cs_base.c:1519
void cs_base_check_bool(bool *b)
Definition: cs_base.c:2377
void cs_base_error_init(bool signal_defaults)
Definition: cs_base.c:1561
void cs_base_mem_finalize(void)
Definition: cs_base.c:1680
void * cs_base_dlopen_plugin(const char *name)
Load a plugin's dynamic library.
Definition: cs_base.c:2490
const char * cs_base_get_pkgdatadir(void)
Definition: cs_base.c:2341
void cs_base_signal_restore(void)
Definition: cs_base.c:1861
void cs_base_at_finalize(cs_base_atexit_t *func)
Register a function to be called at the finalization stage.
Definition: cs_base.c:2685
char * cs_base_get_app_name(int argc, const char *argv[])
Definition: cs_base.c:1092
void * cs_base_dlopen(const char *filename)
Load a dynamic library.
Definition: cs_base.c:2450
void cs_base_logfile_head(int argc, char *argv[])
Definition: cs_base.c:1151
MPI_Comm cs_base_get_rank_step_comm_recursive(MPI_Comm parent_comm, int rank_step)
Definition: cs_base.c:1438
void() cs_base_sigint_handler_t(int signum)
Definition: cs_base.h:81
void cs_base_finalize_sequence(void)
Call sequence of finalization functions.
Definition: cs_base.c:2705
void cs_base_update_status(const char *format,...)
Update status file.
Definition: cs_base.c:1977
static const char * cs_base_strtf(bool boolean)
Return a string "true" or "false" according to the boolean.
Definition: cs_base.h:102
void cs_base_trace_set(bool trace)
Definition: cs_base.c:2054
void cs_base_backtrace_dump(FILE *f, int lv_start)
Dump a stack trace to a file.
Definition: cs_base.c:2619
void cs_base_warn(const char *file_name, int line_num)
Definition: cs_base.c:2244
void cs_base_mem_init(void)
Definition: cs_base.c:1609
const char * cs_base_get_pkglibdir(void)
Definition: cs_base.c:2359
void cs_base_atexit_set(cs_base_atexit_t *const fct)
Definition: cs_base.c:2263
MPI_Comm cs_base_get_rank_step_comm(int rank_step)
Return a reduced communicator matching a multiple of the total number of ranks.
Definition: cs_base.c:1357
void cs_base_get_run_identity(char **run_id, char **case_name, char **study_name)
Query run-time directory info, using working directory names.
Definition: cs_base.c:2738
bool cs_base_bft_printf_suppressed(void)
Definition: cs_base.c:2230
void cs_base_dlopen_set_flags(int flags)
Set flags for dlopen.
Definition: cs_base.c:2535
void cs_base_bft_printf_set(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:2151
void cs_base_bft_printf_init(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:2073
FILE * cs_base_open_properties_data_file(const char *base_name)
Definition: cs_base.c:2407
void() cs_base_atexit_t(void)
Definition: cs_base.h:77
void * cs_base_get_dl_function_pointer(void *handle, const char *name, bool errors_are_fatal)
Get a shared library function pointer.
Definition: cs_base.c:2588
Definition: cs_defs.h:528
Definition: cs_defs.h:529
@ h
Definition: cs_field_pointer.h:91
