8.2
cs_param_cdo.h File Reference
+ Include dependency graph for cs_param_cdo.h:
Macros
#define CS_CDO_KEEP_DEFAULT   -2
#define CS_CDO_OMP_CHUNK_SIZE   128
#define CS_CDO_OMP_SCHEDULE   schedule(static, CS_CDO_OMP_CHUNK_SIZE)
#define CS_CDO_OMP_SYNC_MODE
#define CS_CDO_OMP_ASSERT(e)   assert(e)
#define CS_CDO_N_MAX_REACTIONS   8
#define CS_ALL_FACES   0 /* All faces: interior + border */
#define CS_BND_FACES   1 /* Boundary faces */
#define CS_INT_FACES   2 /* Interior faces */
#define CS_N_DOFS_FACE_0TH   1
#define CS_N_DOFS_FACE_1ST   3
#define CS_N_DOFS_FACE_2ND   6
#define CS_N_DOFS_CELL_0TH   1
#define CS_N_DOFS_CELL_1ST   4
#define CS_N_DOFS_CELL_2ND   10
Enumerations
enum  cs_param_cdo_mode_t { CS_PARAM_CDO_MODE_OFF = -1 , CS_PARAM_CDO_MODE_WITH_FV = 1 , CS_PARAM_CDO_MODE_ONLY = 2 }
void cs_param_cdo_mode_set (cs_param_cdo_mode_t mode)
 Set the global variable storing the mode of activation to apply to CDO/HHO schemes. Deprecated way to set the CDO mode. More...
cs_param_cdo_mode_t cs_param_cdo_mode_get (void)
 Get the mode of activation for the CDO/HHO schemes. More...
void cs_param_cdo_log (void)
 Print a welcome message indicating what is the current CDO status. More...
void cs_param_cdo_setup_log (void)
 Print generic parameters used with CDO/HHO schemes. More...
cs_param_cdo_mode_t cs_glob_param_cdo_mode
◆ CS_ALL_FACES
◆ CS_BND_FACES
◆ CS_CDO_KEEP_DEFAULT
◆ CS_CDO_N_MAX_REACTIONS
◆ CS_CDO_OMP_ASSERT
#define CS_CDO_OMP_ASSERT (   e)    assert(e)
◆ CS_CDO_OMP_CHUNK_SIZE
◆ CS_CDO_OMP_SCHEDULE
◆ CS_CDO_OMP_SYNC_MODE
Value:
0 /* > 0 --> critical sections otherwise
* atomic sections is used */
◆ CS_INT_FACES
◆ CS_N_DOFS_CELL_0TH
◆ CS_N_DOFS_CELL_1ST
◆ CS_N_DOFS_CELL_2ND
◆ CS_N_DOFS_FACE_0TH
◆ CS_N_DOFS_FACE_1ST
◆ CS_N_DOFS_FACE_2ND
◆ cs_param_cdo_mode_t
Enumerator
◆ cs_param_cdo_log()
void cs_param_cdo_log ( void  )
◆ cs_param_cdo_mode_get()
cs_param_cdo_mode_t cs_param_cdo_mode_get ( void  )
the mode of activation for the CDO/HHO module
◆ cs_param_cdo_mode_set()
void cs_param_cdo_mode_set ( cs_param_cdo_mode_t  mode)
◆ cs_param_cdo_setup_log()
void cs_param_cdo_setup_log ( void  )
◆ cs_glob_param_cdo_mode
extern
