Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs_param_sles_t structure. More...
Include dependency graph for cs_param_sles.h:Go to the source code of this file.
| struct | cs_param_sles_t |
| Structure storing all metadata related to the resolution of a linear system with an iterative solver. More... | |
| cs_param_sles_t * | cs_param_sles_create (int field_id, const char *system_name) |
| Create a cs_param_sles_t structure and assign a default settings. More... | |
| void | cs_param_sles_free (cs_param_sles_t **p_slesp) |
| Free a cs_param_sles_t structure. More... | |
| void | cs_param_sles_log (cs_param_sles_t *slesp) |
| Log information related to the linear settings stored in the structure. More... | |
| void | cs_param_sles_copy_from (const cs_param_sles_t *src, cs_param_sles_t *dst) |
| Copy a cs_param_sles_t structure from src to dst. More... | |
| int | cs_param_sles_set_solver (const char *keyval, cs_param_sles_t *slesp) |
| Set the solver associated to this SLES from its keyval. More... | |
| int | cs_param_sles_set_precond (const char *keyval, cs_param_sles_t *slesp) |
| Set the preconditioner associated to this SLES from its keyval. More... | |
| int | cs_param_sles_set_solver_class (const char *keyval, cs_param_sles_t *slesp) |
| Set the class of solvers associated to this SLES from its keyval Common choices are "petsc", "hypre" or "mumps". More... | |
| int | cs_param_sles_set_amg_type (const char *keyval, cs_param_sles_t *slesp) |
| Set the type of algebraic multigrid (AMG) associated to this SLES from its keyval. More... | |
| int | cs_param_sles_set_precond_block_type (const char *keyval, cs_param_sles_t *slesp) |
| Set the type of block preconditioner associated to this SLES from its keyval. More... | |
| void | cs_param_sles_set_cvg_param (cs_param_sles_t *slesp, double rtol, double atol, double dtol, int max_iter) |
| Set the convergence criteria for the given SLES parameters. One can use the parameter value CS_CDO_KEEP_DEFAULT to let unchange the settings. More... | |
| void | cs_param_sles_amg_inhouse_reset (cs_param_sles_t *slesp, bool used_as_solver, bool used_as_k_cycle) |
| Allocate and initialize a new context structure for the in-house AMG settings. More... | |
| void | cs_param_sles_amg_inhouse (cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_inhouse_solver_t down_smoother, int down_poly_deg, int n_up_iter, cs_param_amg_inhouse_solver_t up_smoother, int up_poly_deg, cs_param_amg_inhouse_solver_t coarse_solver, int coarse_poly_deg, cs_param_amg_inhouse_coarsen_t coarsen_algo, int aggreg_limit) |
| Set the main members of a cs_param_amg_inhouse_t structure. This structure is not reset before applying the given parameter. Please call cs_param_sles_amg_inhouse_reset to do so. More... | |
| void | cs_param_sles_amg_inhouse_advanced (cs_param_sles_t *slesp, int max_levels, cs_gnum_t min_n_g_rows, double p0p1_relax, int coarse_max_iter, double coarse_rtol_mult) |
| Set the members of a cs_param_amg_inhouse_t structure used in advanced settings. CS_CDO_KEEP_DEFAULT can be used to let unchange the parameter value. More... | |
| void | cs_param_sles_boomeramg_reset (cs_param_sles_t *slesp) |
| Allocate and initialize a new context structure for the boomerAMG settings. More... | |
| void | cs_param_sles_boomeramg (cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_boomer_smoother_t down_smoother, int n_up_iter, cs_param_amg_boomer_smoother_t up_smoother, cs_param_amg_boomer_smoother_t coarse_solver, cs_param_amg_boomer_coarsen_algo_t coarsen_algo) |
| Set the main members of a cs_param_amg_boomer_t structure. This structure is allocated and initialized and then one sets the main given parameters. Please refer to the HYPRE user guide for more details about the following options. More... | |
| void | cs_param_sles_boomeramg_advanced (cs_param_sles_t *slesp, double strong_thr, cs_param_amg_boomer_interp_algo_t interp_algo, int p_max, int n_agg_lv, int n_agg_paths) |
| Set the members of a cs_param_amg_boomer_t structure used in advanced settings. This structure is allocated if needed. Other members are kept to their values. Please refer to the HYPRE user guide for more details about the following options. More... | |
| void | cs_param_sles_mumps_reset (cs_param_sles_t *slesp) |
| Allocate and initialize a new context structure for the MUMPS settings. More... | |
| void | cs_param_sles_mumps (cs_param_sles_t *slesp, bool is_single, cs_param_mumps_facto_type_t facto_type) |
| Set the main members of a cs_param_mumps_t structure. This structure is allocated and initialized with default settings if needed. If the structure exists already, then advanced members are kept to their values. More... | |
| void | cs_param_sles_mumps_advanced (cs_param_sles_t *slesp, cs_param_mumps_analysis_algo_t analysis_algo, int block_analysis, double mem_coef, double blr_threshold, int ir_steps, cs_param_mumps_memory_usage_t mem_usage, bool advanced_optim) |
| Set the members related to an advanced settings of a cs_param_mumps_t structure. This structure is allocated and initialized if needed. Please refer to the MUMPS user guide for more details about the following advanced options. More... | |
| bool | cs_param_sles_hypre_from_petsc (void) |
| Check the availability of Hypre solvers from the PETSc library. More... | |
| cs_param_solver_class_t | cs_param_sles_check_class (cs_param_solver_class_t wanted_class) |
| Check the availability of a solver library and return the requested one if this is possible or an alternative or CS_PARAM_N_SOLVER_CLASSES if no alternative is available. More... | |
| void cs_param_sles_amg_inhouse | ( | cs_param_sles_t * | slesp, |
| int | n_down_iter, | ||
| cs_param_amg_inhouse_solver_t | down_smoother, | ||
| int | down_poly_deg, | ||
| int | n_up_iter, | ||
| cs_param_amg_inhouse_solver_t | up_smoother, | ||
| int | up_poly_deg, | ||
| cs_param_amg_inhouse_solver_t | coarse_solver, | ||
| int | coarse_poly_deg, | ||
| cs_param_amg_inhouse_coarsen_t | coarsen_algo, | ||
| int | aggreg_limit | ||
| [in,out] | slesp | pointer to a cs_param_sles_t structure |
| [in] | n_down_iter | number of smoothing steps for the down cycle |
| [in] | down_smoother | type of smoother for the down cycle |
| [in] | down_poly_deg | poly. degree for the down smoother |
| [in] | n_up_iter | number of smoothing steps for the up cycle |
| [in] | up_smoother | type of smoother for the up cycle |
| [in] | up_poly_deg | poly. degree for the up smoother |
| [in] | coarse_solver | solver at the coarsest level |
| [in] | coarse_poly_deg | poly. degree for the coarse solver |
| [in] | coarsen_algo | type of algorithm to coarsen grids |
| [in] | aggreg_limit | limit for the aggregation process |
| void cs_param_sles_amg_inhouse_advanced | ( | cs_param_sles_t * | slesp, |
| int | max_levels, | ||
| cs_gnum_t | min_n_g_rows, | ||
| double | p0p1_relax, | ||
| int | coarse_max_iter, | ||
| double | coarse_rtol_mult | ||
| [in] | max_levels | max. number of levels |
| [in] | min_n_g_rows | do not coarsen anymore below this number |
| [in] | p0p1_relax | p0/p1 relaxation parameter |
| [in] | coarse_max_iter | max. number of iter. for the coarse solver |
| [in] | coarse_rtol_mult | max. number of iter. for the coarse solver |
| void cs_param_sles_amg_inhouse_reset | ( | cs_param_sles_t * | slesp, |
| bool | used_as_solver, | ||
| bool | used_as_k_cycle | ||
| [in] | used_as_solver | true or false |
| [in] | used_as_k_cycle | true or false |
| void cs_param_sles_boomeramg | ( | cs_param_sles_t * | slesp, |
| cs_param_amg_boomer_smoother_t | down_smoother, | ||
| cs_param_amg_boomer_smoother_t | up_smoother, | ||
| cs_param_amg_boomer_smoother_t | coarse_solver, | ||
| cs_param_amg_boomer_coarsen_algo_t | coarsen_algo | ||
| void cs_param_sles_boomeramg_advanced | ( | cs_param_sles_t * | slesp, |
| double | strong_thr, | ||
| cs_param_amg_boomer_interp_algo_t | interp_algo, | ||
| int | p_max, | ||
| int | n_agg_lv, | ||
| int | n_agg_paths | ||
| [in] | strong_thr | value of the strong threshold (coarsening) |
| [in] | interp_algo | algorithm used for the interpolation |
| [in] | p_max | max number of elements per row (interp) |
| [in] | n_agg_lv | aggressive coarsening (number of levels) |
| [in] | n_agg_paths | aggressive coarsening (number of paths) |
| void cs_param_sles_boomeramg_reset | ( | cs_param_sles_t * | slesp | ) |
| cs_param_solver_class_t cs_param_sles_check_class | ( | cs_param_solver_class_t | wanted_class | ) |
| [in] | wanted_class | requested class of solvers |
| void cs_param_sles_copy_from | ( | const cs_param_sles_t * | src, |
| cs_param_sles_t * | dst | ||
| [in] | src | reference cs_param_sles_t structure to copy |
| [in,out] | dst | copy of the reference at exit |
| cs_param_sles_t* cs_param_sles_create | ( | int | field_id, |
| const char * | system_name | ||
| [in] | field_id | id related to to the variable field or -1 |
| [in] | system_name | name of the system to solve or NULL |
| void cs_param_sles_free | ( | cs_param_sles_t ** | p_slesp | ) |
| [in,out] | p_slesp | pointer to a cs_param_sles_t structure to free |
| bool cs_param_sles_hypre_from_petsc | ( | void | ) |
| void cs_param_sles_log | ( | cs_param_sles_t * | slesp | ) |
| [in] | slesp | pointer to a cs_param_sles_log |
| void cs_param_sles_mumps | ( | cs_param_sles_t * | slesp, |
| bool | is_single, | ||
| cs_param_mumps_facto_type_t | facto_type | ||
| [in] | is_single | single-precision or double-precision |
| [in] | facto_type | type of factorization to consider |
| void cs_param_sles_mumps_advanced | ( | cs_param_sles_t * | slesp, |
| cs_param_mumps_analysis_algo_t | analysis_algo, | ||
| int | block_analysis, | ||
| double | mem_coef, | ||
| double | blr_threshold, | ||
| int | ir_steps, | ||
| cs_param_mumps_memory_usage_t | mem_usage, | ||
| bool | advanced_optim | ||
| [in] | analysis_algo | algorithm used for the analysis step |
| [in] | block_analysis | > 1: fixed block size; otherwise do nothing |
| [in] | mem_coef | percentage increase in the memory workspace |
| [in] | blr_threshold | Accuracy in BLR compression (0: not used) |
| [in] | ir_steps | 0: No, otherwise the number of iterations |
| [in] | mem_usage | strategy to adopt for the memory usage |
| [in] | advanced_optim | activate advanced optimization (MPI/openMP) |
| void cs_param_sles_mumps_reset | ( | cs_param_sles_t * | slesp | ) |
| int cs_param_sles_set_amg_type | ( | const char * | keyval, |
| cs_param_sles_t * | slesp | ||
| [in] | keyval | value of the key |
| void cs_param_sles_set_cvg_param | ( | cs_param_sles_t * | slesp, |
| double | rtol, | ||
| double | atol, | ||
| double | dtol, | ||
| int | max_iter | ||
| [in] | rtol | relative tolerance |
| [in] | atol | absolute tolerance |
| [in] | dtol | divergence tolerance |
| [in] | max_iter | max. number of iterations |
| int cs_param_sles_set_precond | ( | const char * | keyval, |
| int cs_param_sles_set_precond_block_type | ( | const char * | keyval, |
| int cs_param_sles_set_solver | ( | const char * | keyval, |
| int cs_param_sles_set_solver_class | ( | const char * | keyval, |
