8.2
cs_param_sles.h
1 #ifndef __CS_PARAM_SLES_H__
2 #define __CS_PARAM_SLES_H__
5  * Routines to handle the SLES (Sparse Linear Equation Solver) settings
31  * Local headers
34 #include "cs_param_amg.h"
35 #include "cs_param_mumps.h"
36 #include "cs_param_types.h"
51  * Macro definitions
53
55  * Type definitions
57
64 typedef struct {
65
66  char *name;
67  int field_id;
69  int verbosity;
74  bool flexible;
75  int restart;
83
89
96
103
110
112
113 /*============================================================================
114  * Global variables
115  *============================================================================*/
116
117 /*============================================================================
118  * Public function prototypes
119  *============================================================================*/
120
121 /*----------------------------------------------------------------------------*/
131 /*----------------------------------------------------------------------------*/
132
134 cs_param_sles_create(int field_id,
135  const char *system_name);
136
137 /*----------------------------------------------------------------------------*/
143 /*----------------------------------------------------------------------------*/
144
145 void
147
148 /*----------------------------------------------------------------------------*/
155 /*----------------------------------------------------------------------------*/
156
157 void
159
160 /*----------------------------------------------------------------------------*/
167 /*----------------------------------------------------------------------------*/
168
169 void
171  cs_param_sles_t *dst);
172
173 /*----------------------------------------------------------------------------*/
182 /*----------------------------------------------------------------------------*/
183
184 int
185 cs_param_sles_set_solver(const char *keyval,
186  cs_param_sles_t *slesp);
187
188 /*----------------------------------------------------------------------------*/
197 /*----------------------------------------------------------------------------*/
198
199 int
200 cs_param_sles_set_precond(const char *keyval,
201  cs_param_sles_t *slesp);
202
203 /*----------------------------------------------------------------------------*/
213 /*----------------------------------------------------------------------------*/
214
215 int
216 cs_param_sles_set_solver_class(const char *keyval,
217  cs_param_sles_t *slesp);
218
219 /*----------------------------------------------------------------------------*/
229 /*----------------------------------------------------------------------------*/
230
231 int
232 cs_param_sles_set_amg_type(const char *keyval,
233  cs_param_sles_t *slesp);
234
235 /*----------------------------------------------------------------------------*/
245 /*----------------------------------------------------------------------------*/
246
247 int
248 cs_param_sles_set_precond_block_type(const char *keyval,
249  cs_param_sles_t *slesp);
250
251 /*----------------------------------------------------------------------------*/
263 /*----------------------------------------------------------------------------*/
264
265 void
267  double rtol,
268  double atol,
269  double dtol,
270  int max_iter);
271
272 /*----------------------------------------------------------------------------*/
281 /*----------------------------------------------------------------------------*/
282
283 void
285  bool used_as_solver,
286  bool used_as_k_cycle);
287
288 /*----------------------------------------------------------------------------*/
306 /*----------------------------------------------------------------------------*/
307
308 void
310  int n_down_iter,
311  cs_param_amg_inhouse_solver_t down_smoother,
312  int down_poly_deg,
313  int n_up_iter,
314  cs_param_amg_inhouse_solver_t up_smoother,
315  int up_poly_deg,
316  cs_param_amg_inhouse_solver_t coarse_solver,
317  int coarse_poly_deg,
318  cs_param_amg_inhouse_coarsen_t coarsen_algo,
319  int aggreg_limit);
320
321 /*----------------------------------------------------------------------------*/
334 /*----------------------------------------------------------------------------*/
335
336 void
338  int max_levels,
339  cs_gnum_t min_n_g_rows,
340  double p0p1_relax,
341  int coarse_max_iter,
342  double coarse_rtol_mult);
343
344 /*----------------------------------------------------------------------------*/
351 /*----------------------------------------------------------------------------*/
352
353 void
355
356 /*----------------------------------------------------------------------------*/
371 /*----------------------------------------------------------------------------*/
372
373 void
375  int n_down_iter,
376  cs_param_amg_boomer_smoother_t down_smoother,
377  int n_up_iter,
378  cs_param_amg_boomer_smoother_t up_smoother,
379  cs_param_amg_boomer_smoother_t coarse_solver,
381
382 /*----------------------------------------------------------------------------*/
396 /*----------------------------------------------------------------------------*/
397
398 void
400  double strong_thr,
402  int p_max,
403  int n_agg_lv,
404  int n_agg_paths);
405
406 /*----------------------------------------------------------------------------*/
413 /*----------------------------------------------------------------------------*/
414
415 void
417
418 /*----------------------------------------------------------------------------*/
429 /*----------------------------------------------------------------------------*/
430
431 void
433  bool is_single,
434  cs_param_mumps_facto_type_t facto_type);
435
436 /*----------------------------------------------------------------------------*/
452 /*----------------------------------------------------------------------------*/
453
454 void
456  cs_param_mumps_analysis_algo_t analysis_algo,
457  int block_analysis,
458  double mem_coef,
459  double blr_threshold,
460  int ir_steps,
462  bool advanced_optim);
463
464 /*----------------------------------------------------------------------------*/
470 /*----------------------------------------------------------------------------*/
471
472 bool
474
475 /*----------------------------------------------------------------------------*/
485 /*----------------------------------------------------------------------------*/
486
489
490 /*----------------------------------------------------------------------------*/
491
493
494 #endif /* __CS_PARAM_SLES_H__ */
Definition: cs_defs.h:528
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:310
Definition: cs_defs.h:529
Routines to handle the set of parameters for algebraic multigrids (AMG) like boomerAMG of the HYPRE l...
cs_param_amg_boomer_interp_algo_t
Type of algorithm used in boomerAMG to coarsen a level. Only a selection of algorithms is available h...
Definition: cs_param_amg.h:102
cs_param_amg_boomer_coarsen_algo_t
Definition: cs_param_amg.h:85
Type of algorithm used in the in-house algorithm for smoothing each level or solving the coarse level...
Definition: cs_param_amg.h:181
cs_param_amg_type_t
Definition: cs_param_amg.h:64
Type of algorithm used in boomerAMG to smooth a level. Only a selection of algorithms is available he...
Definition: cs_param_amg.h:121
Type of algorithm used in the in-house algorithm to coarsen each level. This enum avoids using the as...
Definition: cs_param_amg.h:205
Routines and structure to handle the MUMPS setup. The structure is used as a context structure of a c...
type of factorization to consider when using the MUMPS solver to solve a linear system
Definition: cs_param_mumps.h:71
cs_param_mumps_memory_usage_t
Strategy for the memory usage inside MUMPS.
Definition: cs_param_mumps.h:149
Type of algorithm to consider when using the MUMPS solver to perform the analysis step (renumbering a...
Definition: cs_param_mumps.h:119
void cs_param_sles_amg_inhouse(cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_inhouse_solver_t down_smoother, int down_poly_deg, int n_up_iter, cs_param_amg_inhouse_solver_t up_smoother, int up_poly_deg, cs_param_amg_inhouse_solver_t coarse_solver, int coarse_poly_deg, cs_param_amg_inhouse_coarsen_t coarsen_algo, int aggreg_limit)
Set the main members of a cs_param_amg_inhouse_t structure. This structure is not reset before applyi...
Definition: cs_param_sles.c:1360
void cs_param_sles_mumps(cs_param_sles_t *slesp, bool is_single, cs_param_mumps_facto_type_t facto_type)
Set the main members of a cs_param_mumps_t structure. This structure is allocated and initialized wit...
Definition: cs_param_sles.c:1591
bool cs_param_sles_hypre_from_petsc(void)
Check the availability of Hypre solvers from the PETSc library.
Definition: cs_param_sles.c:1662
void cs_param_sles_copy_from(const cs_param_sles_t *src, cs_param_sles_t *dst)
Copy a cs_param_sles_t structure from src to dst.
Definition: cs_param_sles.c:435
void cs_param_sles_boomeramg_advanced(cs_param_sles_t *slesp, double strong_thr, cs_param_amg_boomer_interp_algo_t interp_algo, int p_max, int n_agg_lv, int n_agg_paths)
Set the members of a cs_param_amg_boomer_t structure used in advanced settings. This structure is all...
Definition: cs_param_sles.c:1529
void cs_param_sles_amg_inhouse_advanced(cs_param_sles_t *slesp, int max_levels, cs_gnum_t min_n_g_rows, double p0p1_relax, int coarse_max_iter, double coarse_rtol_mult)
Set the members of a cs_param_amg_inhouse_t structure used in advanced settings. CS_CDO_KEEP_DEFAULT ...
Definition: cs_param_sles.c:1419
void cs_param_sles_amg_inhouse_reset(cs_param_sles_t *slesp, bool used_as_solver, bool used_as_k_cycle)
Allocate and initialize a new context structure for the in-house AMG settings.
Definition: cs_param_sles.c:1325
int cs_param_sles_set_solver_class(const char *keyval, cs_param_sles_t *slesp)
Set the class of solvers associated to this SLES from its keyval Common choices are "petsc",...
Definition: cs_param_sles.c:976
int cs_param_sles_set_solver(const char *keyval, cs_param_sles_t *slesp)
Set the solver associated to this SLES from its keyval.
Definition: cs_param_sles.c:488
int cs_param_sles_set_precond(const char *keyval, cs_param_sles_t *slesp)
Set the preconditioner associated to this SLES from its keyval.
Definition: cs_param_sles.c:679
void cs_param_sles_mumps_reset(cs_param_sles_t *slesp)
Allocate and initialize a new context structure for the MUMPS settings.
Definition: cs_param_sles.c:1563
void cs_param_sles_free(cs_param_sles_t **p_slesp)
Free a cs_param_sles_t structure.
Definition: cs_param_sles.c:284
cs_param_solver_class_t cs_param_sles_check_class(cs_param_solver_class_t wanted_class)
Check the availability of a solver library and return the requested one if this is possible or an alt...
Definition: cs_param_sles.c:1688
void cs_param_sles_set_cvg_param(cs_param_sles_t *slesp, double rtol, double atol, double dtol, int max_iter)
Set the convergence criteria for the given SLES parameters. One can use the parameter value CS_CDO_KE...
Definition: cs_param_sles.c:1283
void cs_param_sles_boomeramg_reset(cs_param_sles_t *slesp)
Allocate and initialize a new context structure for the boomerAMG settings.
Definition: cs_param_sles.c:1458
cs_param_sles_t * cs_param_sles_create(int field_id, const char *system_name)
Create a cs_param_sles_t structure and assign a default settings.
Definition: cs_param_sles.c:236
int cs_param_sles_set_precond_block_type(const char *keyval, cs_param_sles_t *slesp)
Set the type of block preconditioner associated to this SLES from its keyval.
Definition: cs_param_sles.c:1218
int cs_param_sles_set_amg_type(const char *keyval, cs_param_sles_t *slesp)
Set the type of algebraic multigrid (AMG) associated to this SLES from its keyval.
Definition: cs_param_sles.c:1076
void cs_param_sles_mumps_advanced(cs_param_sles_t *slesp, cs_param_mumps_analysis_algo_t analysis_algo, int block_analysis, double mem_coef, double blr_threshold, int ir_steps, cs_param_mumps_memory_usage_t mem_usage, bool advanced_optim)
Set the members related to an advanced settings of a cs_param_mumps_t structure. This structure is al...
Definition: cs_param_sles.c:1625
void cs_param_sles_boomeramg(cs_param_sles_t *slesp, int n_down_iter, cs_param_amg_boomer_smoother_t down_smoother, int n_up_iter, cs_param_amg_boomer_smoother_t up_smoother, cs_param_amg_boomer_smoother_t coarse_solver, cs_param_amg_boomer_coarsen_algo_t coarsen_algo)
Set the main members of a cs_param_amg_boomer_t structure. This structure is allocated and initialize...
Definition: cs_param_sles.c:1487
void cs_param_sles_log(cs_param_sles_t *slesp)
Log information related to the linear settings stored in the structure.
Definition: cs_param_sles.c:315
cs_param_resnorm_type_t
Definition: cs_param_types.h:835
Definition: cs_param_types.h:617
cs_param_precond_type_t
Definition: cs_param_types.h:726
cs_param_precond_block_t
Definition: cs_param_types.h:652
cs_param_solver_type_t
Definition: cs_param_types.h:806
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_types.h:537
Definition: cs_param_sles.h:64
cs_param_convergence_t cvg_param
Definition: cs_param_sles.h:102
cs_param_precond_block_t precond_block_type
Definition: cs_param_sles.h:82
bool allow_no_op
Definition: cs_param_sles.h:95
int field_id
Definition: cs_param_sles.h:67
int verbosity
Definition: cs_param_sles.h:69
void * context_param
Definition: cs_param_sles.h:109
char * name
Definition: cs_param_sles.h:66
cs_param_resnorm_type_t resnorm_type
Definition: cs_param_sles.h:88
cs_param_precond_type_t precond
Definition: cs_param_sles.h:72
cs_param_solver_class_t solver_class
Definition: cs_param_sles.h:71
int restart
Definition: cs_param_sles.h:75
cs_param_amg_type_t amg_type
Definition: cs_param_sles.h:76
bool flexible
Definition: cs_param_sles.h:74
cs_param_solver_type_t solver
Definition: cs_param_sles.h:73
