8.2
cs_param_mumps.h
1 #ifndef __CS_PARAM_MUMPS_H__
2 #define __CS_PARAM_MUMPS_H__
5  * Routines and structure to handle the MUMPS settings
31  * Local headers
34 /*----------------------------------------------------------------------------*/
46  * Macro definitions
48
50  * Type definitions
52
71 typedef enum {
72
76
78
80
81
119 typedef enum {
120
128
130
132
134
135
149 typedef enum {
150
154
156
158
159
166 typedef struct {
167
168  /* \var analysis_algo
169  * Choice of the algorithm used to perform the analysis step
170  *
171  * \var facto_type
172  * Type of factorization to consider. This choice depends on the type of
173  * matrix to handle
174  *
175  * \var mem_usage
176  * Type of strategy to consider for the memory usage.
177  */
178
182
183  bool is_single;
188  double blr_threshold;
195  double mem_coef;
202  int ir_steps;
205
206 /*============================================================================
207  * Global variables
208  *============================================================================*/
209
210 /*============================================================================
211  * Public function prototypes
212  *============================================================================*/
213
214 /*----------------------------------------------------------------------------*/
221 /*----------------------------------------------------------------------------*/
222
225
226 /*----------------------------------------------------------------------------*/
235 /*----------------------------------------------------------------------------*/
236
239
240 /*----------------------------------------------------------------------------*/
247 /*----------------------------------------------------------------------------*/
248
249 void
250 cs_param_mumps_log(const char *name,
251  const cs_param_mumps_t *mumpsp);
252
253 /*----------------------------------------------------------------------------*/
254
256
257 #endif /* __CS_PARAM_MUMPS_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
cs_param_mumps_facto_type_t
type of factorization to consider when using the MUMPS solver to solve a linear system
Definition: cs_param_mumps.h:71
@ CS_PARAM_MUMPS_FACTO_LDLT_SPD
This factorization is devoted to SPD matrices and corresponds to a Cholesky factorization....
Definition: cs_param_mumps.h:75
@ CS_PARAM_MUMPS_FACTO_LU
LU factorization is the most generic factorization available with MUMPS. It can handle general matric...
Definition: cs_param_mumps.h:73
@ CS_PARAM_MUMPS_N_FACTO_TYPES
Definition: cs_param_mumps.h:77
@ CS_PARAM_MUMPS_FACTO_LDLT_SYM
This factorization is a Cholesky factorization (L.D.Lt) for general symmetric matrices.
Definition: cs_param_mumps.h:74
cs_param_mumps_memory_usage_t
Strategy for the memory usage inside MUMPS.
Definition: cs_param_mumps.h:149
@ CS_PARAM_MUMPS_MEMORY_CONSTRAINED
Definition: cs_param_mumps.h:151
@ CS_PARAM_MUMPS_MEMORY_CPU_DRIVEN
Definition: cs_param_mumps.h:153
@ CS_PARAM_MUMPS_N_MEMORY_USAGES
Definition: cs_param_mumps.h:155
@ CS_PARAM_MUMPS_MEMORY_AUTO
Definition: cs_param_mumps.h:152
cs_param_mumps_analysis_algo_t
Type of algorithm to consider when using the MUMPS solver to perform the analysis step (renumbering a...
Definition: cs_param_mumps.h:119
@ CS_PARAM_MUMPS_ANALYSIS_QAMD
Definition: cs_param_mumps.h:122
@ CS_PARAM_MUMPS_ANALYSIS_PORD
Definition: cs_param_mumps.h:123
@ CS_PARAM_MUMPS_ANALYSIS_SCOTCH
Definition: cs_param_mumps.h:124
@ CS_PARAM_MUMPS_N_ANALYSIS_ALGOS
Definition: cs_param_mumps.h:131
@ CS_PARAM_MUMPS_ANALYSIS_AUTO
Definition: cs_param_mumps.h:129
@ CS_PARAM_MUMPS_ANALYSIS_METIS
Definition: cs_param_mumps.h:126
@ CS_PARAM_MUMPS_ANALYSIS_PARMETIS
Definition: cs_param_mumps.h:127
@ CS_PARAM_MUMPS_ANALYSIS_AMD
Definition: cs_param_mumps.h:121
@ CS_PARAM_MUMPS_ANALYSIS_PTSCOTCH
Definition: cs_param_mumps.h:125
cs_param_mumps_t * cs_param_mumps_create(void)
Create and initialize with the default settings a new structure storing a set of parameters used when...
Definition: cs_param_mumps.c:87
cs_param_mumps_t * cs_param_mumps_copy(const cs_param_mumps_t *mumpsp)
Copy into a new structure the given set of parameters used when calling MUMPS.
Definition: cs_param_mumps.c:122
void cs_param_mumps_log(const char *name, const cs_param_mumps_t *mumpsp)
Log the structure storing the set of parameters used with MUMPS.
Definition: cs_param_mumps.c:150
Set of parameters to specify additional options to MUMPS For more advanced settings,...
Definition: cs_param_mumps.h:166
cs_param_mumps_facto_type_t facto_type
Definition: cs_param_mumps.h:180
Definition: cs_param_mumps.h:188
double mem_coef
Definition: cs_param_mumps.h:195
int ir_steps
Definition: cs_param_mumps.h:202
int block_analysis
Definition: cs_param_mumps.h:199
cs_param_mumps_memory_usage_t mem_usage
Definition: cs_param_mumps.h:181
bool is_single
Definition: cs_param_mumps.h:183
cs_param_mumps_analysis_algo_t analysis_algo
Definition: cs_param_mumps.h:179
bool advanced_optim
Definition: cs_param_mumps.h:185
