54 #define CS_ARRAY_SUBSET_NULL -1
55 #define CS_ARRAY_SUBSET_IN 0
56 #define CS_ARRAY_SUBSET_OUT 1
57 #define CS_ARRAY_SUBSET_INOUT 2
void cs_array_real_fill_zero(cs_lnum_t size, cs_real_t a[])
Assign zero to all elements of an array.
Definition: cs_array.c:952
void cs_array_real_scale(cs_lnum_t n_elts, int stride, const cs_lnum_t *elt_ids, cs_real_t scaling_factor, cs_real_t dest[restrict])
Multiply each value by a scaling factor s.t. dest *= scaling_factor If elt_ids is not NULL,...
Definition: cs_array.c:451
void cs_array_real_set_scalar_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, cs_real_t a[restrict])
Assign a constant scalar value to an array on a selected subset of elements. If elt_ids = NULL,...
Definition: cs_array.c:700
void cs_array_set_value_real(cs_lnum_t n_elts, cs_lnum_t dim, cs_real_t v, cs_real_t a[])
Assign a constant value to an array (deprecated function).
Definition: cs_array.c:978
void cs_array_real_set_tensor(cs_lnum_t n_elts, const cs_real_t ref_tens[3][3], cs_real_t *a)
Assign a constant 3x3 tensor to an array (of stride 9) which is interlaced.
Definition: cs_array.c:883
void cs_array_lnum_fill_zero(cs_lnum_t size, cs_lnum_t a[restrict])
Assign zero to all elements of an array. Case of a cs_lnum_t array.
Definition: cs_array.c:146
void cs_array_real_copy_subset(cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], int mode, const cs_real_t ref[], cs_real_t dest[])
Copy an array ("ref") into another array ("dest") on possibly only a part of the array(s)....
Definition: cs_array.c:306
void cs_array_real_set_value(cs_lnum_t n_elts, int stride, const cs_real_t ref_val[], cs_real_t *a)
Assign a constant value of dim "stride" to an interlaced array sharing the same stride.
Definition: cs_array.c:501
void cs_array_real_set_wvalue(cs_lnum_t n_elts, int stride, const cs_real_t ref_val[], const cs_real_t weight[], cs_real_t *a)
Assign a weighted constant value of dim "stride" to an interlaced array sharing the same stride....
Definition: cs_array.c:536
void cs_array_real_set_value_on_subset(cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], const cs_real_t ref_val[], cs_real_t *a)
Assign a constant value of dim "stride" to an interlaced array sharing the same stride....
Definition: cs_array.c:575
void cs_array_real_set_wvalue_on_subset(cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], const cs_real_t ref_val[], const cs_real_t weight[], cs_real_t *a)
Definition: cs_array.c:616
void cs_array_real_set_vector_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], cs_real_t a[])
Assign a constant vector to an interlaced array (of stride 3) on a selected subset of elements....
Definition: cs_array.c:814
void cs_array_lnum_set_value(cs_lnum_t size, cs_lnum_t num, cs_lnum_t a[restrict])
Assign the value "num" to all elements of an array. Case of a cs_lnum_t array.
Definition: cs_array.c:170
void cs_array_flag_fill_zero(cs_lnum_t size, cs_flag_t a[restrict])
Assign zero to all elements of an array. Case of a cs_flag_t array.
Definition: cs_array.c:124
void cs_array_bool_fill_true(cs_lnum_t size, bool a[restrict])
Assign true to all elements of an array. Case of an array of booleans.
void cs_array_real_copy(cs_lnum_t size, const cs_real_t src[], cs_real_t dest[restrict])
Copy real values from an array to another of the same dimensions.
Definition: cs_array.c:421
void cs_array_bool_fill_false(cs_lnum_t size, bool a[restrict])
Assign false to all elements of an array. Case of an array of booleans.
Definition: cs_array.c:106
void cs_array_real_set_vector(cs_lnum_t n_elts, const cs_real_t ref_val[3], cs_real_t *a)
Assign a constant vector to an array of stride 3 which is interlaced.
Definition: cs_array.c:763
void cs_array_int_set_value(cs_lnum_t size, int num, int a[restrict])
Assign the value "num" to all elements of an array. Case of a int array.
Definition: cs_array.c:242
void cs_array_int_set_value_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int num, int a[restrict])
Assign the value "num" to an array on a selected subset of elements. if elt_ids = NULL,...
Definition: cs_array.c:265
void cs_array_real_set_wvector(cs_lnum_t n_elts, const cs_real_t ref_val[3], const cs_real_t weight[], cs_real_t *a)
Assign a weighted constant vector value to an interlaced array (of stride 3). The array of weights ha...
Definition: cs_array.c:787
void cs_array_real_set_wvector_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], const cs_real_t weight[], cs_real_t *a)
Assign a weighted constant vector value to an interlaced array (of stride 3). The subset selection is...
Definition: cs_array.c:849
void cs_array_real_set_scalar(cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[restrict])
Assign a constant scalar value to an array.
Definition: cs_array.c:654
void cs_array_lnum_set_value_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_lnum_t num, cs_lnum_t a[restrict])
Definition: cs_array.c:193
void cs_array_real_set_tensor_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_tens[3][3], cs_real_t *a)
Assign a constant 3x3 tensor to an interlaced array (of stride 9) on a subset of elements....
Definition: cs_array.c:918
void cs_array_real_set_wscalar(cs_lnum_t n_elts, cs_real_t ref_val, const cs_real_t weight[], cs_real_t a[restrict])
Assign a weighted constant scalar value to an array. The weight array has the same size as the array ...
Definition: cs_array.c:676
void cs_array_int_fill_zero(cs_lnum_t size, int a[restrict])
Assign zero to all elements of an array. Case of a int array.
Definition: cs_array.c:218
void cs_array_real_set_wscalar_on_subset(cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, const cs_real_t weight[], cs_real_t a[restrict])
Assign a weighted constant scalar value to an array on a selected subset of elements....
Definition: cs_array.c:732
#define restrict
Definition: cs_defs.h:141
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
unsigned short int cs_flag_t
Definition: cs_defs.h:334
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:113
