8.2
cs_cf_model.h
1 #ifndef __CS_CF_MODEL_H__
2 #define __CS_CF_MODEL_H__
5  * Thermodynamic laws for the compressible module
30 #include "cs_defs.h"
37  * Local headers
43  * Type definitions
45
46 /* compressible model general options descriptor */
47 /*-----------------------------------------------*/
48
49 typedef struct {
50
51  int ieos; /* indicator of equation of state */
52
53  int ithvar; /* indicator for thermodynamic
54  variables initialization */
55
56  int icfgrp; /* indicator for hydrostatic balance
57  in boundary conditions */
58
59  double psginf; /* stiffened gas limit pressure (zero in
60  perfect gas) (Pa) for single phase model */
61
62  double gammasg; /* stiffened gas polytropic coefficient,
63  (dimensionless) for single phase model */
64
65  int hgn_relax_eq_st; /* source term step:
66  - -1 disabled
67  - 0 enabled */
68
70
71 typedef enum {
72
79
81
82 /*============================================================================
83  * Static global variables
84  *============================================================================*/
85
86 /* pointer to main compressible model descriptor structure */
87
88 extern const cs_cf_model_t *cs_glob_cf_model;
89
90 /*=============================================================================
91  * Public function definitions
92  *============================================================================*/
93
94 /*----------------------------------------------------------------------------*/
98 /*----------------------------------------------------------------------------*/
99
102
103 /*----------------------------------------------------------------------------*/
109 /*----------------------------------------------------------------------------*/
110
111 int *
112 cs_cf_get_icvfli(void);
113
114 /*----------------------------------------------------------------------------*/
120 /*----------------------------------------------------------------------------*/
121
122 int *
123 cs_cf_get_ifbet(void);
124
125 /*----------------------------------------------------------------------------*/
130 /*----------------------------------------------------------------------------*/
131
132 void
134
135 /*----------------------------------------------------------------------------*/
139 /*----------------------------------------------------------------------------*/
140
141 void
143
144 /*----------------------------------------------------------------------------*/
145
147
148 #endif /* __CS_CF_MODEL_H__ */
const cs_cf_model_t * cs_glob_cf_model
void cs_cf_model_log_setup(void)
Print the compressible module options to setup.log.
Definition: cs_cf_model.c:335
void cs_cf_add_property_fields(void)
Property field definitions for the compressible module, according to calculation type selected by the...
Definition: cs_cf_model.c:275
int * cs_cf_get_ifbet(void)
Provide access to imposed thermal flux indicator at the boundary (some boundary contributions of the ...
Definition: cs_cf_model.c:262
cs_cf_model_eos_t
Definition: cs_cf_model.h:71
@ CS_EOS_STIFFENED_GAS
Definition: cs_cf_model.h:75
@ CS_EOS_IDEAL_GAS
Definition: cs_cf_model.h:74
@ CS_EOS_MOIST_AIR
Definition: cs_cf_model.h:78
@ CS_EOS_NONE
Definition: cs_cf_model.h:73
@ CS_EOS_GAS_MIX
Definition: cs_cf_model.h:76
@ CS_EOS_HOMOGENEOUS_TWO_PHASE
Definition: cs_cf_model.h:77
cs_cf_model_t * cs_get_glob_cf_model(void)
Provide access to compressible model global structure cs_glob_cf_model.
Definition: cs_cf_model.c:234
int * cs_cf_get_icvfli(void)
Provide access to boundary face indicator array of convection flux.
Definition: cs_cf_model.c:248
Definition: cs_defs.h:528
Definition: cs_defs.h:529
int hgn_relax_eq_st
Definition: cs_cf_model.h:65
int icfgrp
Definition: cs_cf_model.h:56
double psginf
Definition: cs_cf_model.h:59
int ieos
Definition: cs_cf_model.h:51
int ithvar
Definition: cs_cf_model.h:53
double gammasg
Definition: cs_cf_model.h:62
Compressible model general options descriptor.
Definition: cs_cf_model.h:49
