8.2
bft_mem.h
1 #ifndef __BFT_MEM_H__
2 #define __BFT_MEM_H__
5  * Base memory allocation wrappers with optional tracing
30 #include "cs_defs.h"
34 /* BFT headers */
36 #include "bft_error.h"
38 /*-----------------------------------------------------------------------------*/
43  * Public types
45
50 typedef enum {
51
62
63 /*
64  * Structure defining an allocated memory block
65  */
66
67 typedef struct
68 {
69  void *host_ptr;
70 #if defined(HAVE_ACCEL)
71  void *device_ptr;
72 #endif
73
74  size_t size;
75 #if defined(HAVE_ACCEL)
76  cs_alloc_mode_t mode;
77 #endif
78
80
81 /*============================================================================
82  * Public macros
83  *============================================================================*/
84
85 /*
86  * Allocate memory for _ni items of type _type.
87  *
88  * This macro calls bft_mem_malloc(), automatically setting the
89  * allocated variable name and source file name and line arguments.
90  *
91  * parameters:
92  * _ptr --> pointer to allocated memory.
93  * _ni <-- number of items.
94  * _type <-- element type.
95  */
96
97 #define BFT_MALLOC(_ptr, _ni, _type) \
98 _ptr = (_type *) bft_mem_malloc(_ni, sizeof(_type), \
99  #_ptr, __FILE__, __LINE__)
100
101 /*
102  * Reallocate memory for _ni items of type _type.
103  *
104  * This macro calls bft_mem_realloc(), automatically setting the
105  * allocated variable name and source file name and line arguments.
106  *
107  * parameters:
108  * _ptr <-> pointer to allocated memory.
109  * _ni <-- number of items.
110  * _type <-- element type.
111  */
112
113 #define BFT_REALLOC(_ptr, _ni, _type) \
114 _ptr = (_type *) bft_mem_realloc(_ptr, _ni, sizeof(_type), \
115  #_ptr, __FILE__, __LINE__)
116
117 /*
118  * Free allocated memory.
119  *
120  * This macro calls bft_mem_free(), automatically setting the
121  * allocated variable name and source file name and line arguments.
122  *
123  * The freed pointer is set to NULL to avoid accidental reuse.
124  *
125  * parameters:
126  * _ptr <-> pointer to allocated memory.
127  */
128
129 #ifdef __cplusplus /* avoid casting from void for C++ */
130
131 #define BFT_FREE(_ptr) \
132 bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL
133
134 #else
135
136 #define BFT_FREE(_ptr) \
137 _ptr = bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__)
138
139 #endif /* __cplusplus */
140
141 /*
142  * Allocate aligned memory for _ni items of type _type.
143  *
144  * This macro calls bft_mem_memalign(), automatically setting the
145  * allocated variable name and source file name and line arguments.
146  *
147  * parameters:
148  * _ptr --> pointer to allocated memory.
149  * _align <-- alignment.
150  * _ni <-- number of items.
151  * _type <-- element type.
152  */
153
154 #define BFT_MEMALIGN(_ptr, _align, _ni, _type) \
155 _ptr = (_type *) bft_mem_memalign(_align, _ni, sizeof(_type), \
156  #_ptr, __FILE__, __LINE__)
157
158 /*----------------------------------------------------------------------------
159  * Function pointer types
160  *----------------------------------------------------------------------------*/
161
162 typedef size_t
163 (bft_mem_get_size_t)(void *ptr);
164
165 typedef void *
166 (bft_mem_realloc_t)(void *ptr,
167  size_t ni,
168  size_t size,
169  const char *var_name,
170  const char *file_name,
171  int line_num);
172
173 typedef void
174 (bft_mem_free_t)(void *ptr,
175  const char *var_name,
176  const char *file_name,
177  int line_num);
178
179 /*============================================================================
180  * Semi private function definitions
181  *============================================================================*/
182
184
185 #ifdef __cplusplus /* only for C++ API */
186
187 /*----------------------------------------------------------------------------*/
188
189 /*
190  * Return the cs_mem_block structure corresponding to a given
191  * allocated block.
192  *
193  * parameters:
194  * p_get: <-- allocated block's start adress.
195  *
196  * returns:
197  * corresponding cs_mem_block structure.
198  */
199
201 bft_mem_get_block_info(const void *p_get);
202
203 /*
204  * Return the cs_mem_block structure corresponding to a given
205  * allocated block if available.
206  *
207  * If no block info is available, return block with null pointers
208  * and zero size.
209  *
210  * parameters:
211  * p_get: <-- allocated block's start adress.
212  *
213  * returns:
214  * pointer tocorresponding cs_mem_block structure.
215  */
216
218 bft_mem_get_block_info_try(const void *p_get);
219
220 /*
221  * \brief Update block information map if enabled.
222  *
223  * parameters
224  * var_name <-- allocated variable name string.
225  * file_name <-- name of calling source file.
226  * line_num <-- line number in calling source file.
227  * old_block <-- pointer to old block info, if present
228  * new_block <-- pointer to new block info, if present
229  */
230
231 void
232 bft_mem_update_block_info(const char *var_name,
233  const char *file_name,
234  int line_num,
235  const cs_mem_block_t *old_block,
236  const cs_mem_block_t *new_block);
237
238 /*----------------------------------------------------------------------------*/
239
240 #endif // __cplusplus
241
243
244 /*============================================================================
245  * Public function prototypes
246  *============================================================================*/
247
248 /*
249  * Initialize memory handling.
250  *
251  * This function should be called before any other bft_mem_...()
252  * function. To activate memory allocation logging, a logfile
253  * name should be given as an argument. The resulting file will
254  * be a regular, local file. If this file cannot be opened for
255  * some reason, logging is silently de-activated.
256  *
257  * parameter:
258  * log_file_name <-- name of optional log_file (if NULL, no log).
259  */
260
261 void
262 bft_mem_init(const char *log_file_name);
263
264 /*
265  * End memory handling.
266  *
267  * This function should be called after all other bft_mem_...()
268  * functions. In case of memory allocation logging, it
269  * writes final information to the log file and closes is.
270  */
271
272 void
273 bft_mem_end(void);
274
275 /*
276  * Initialize memory handling.
277  *
278  * This function should be called before any other bft_mem_...()
279  * function. To activate memory allocation logging, a logfile
280  * name should be given as an argument. The resulting file will
281  * be a regular, local file. If this file cannot be opened for
282  * some reason, logging is silently de-activated.
283  *
284  * parameter:
285  * log_file_name <-- name of optional log_file (if NULL, no log).
286  */
287
288 /*
289  * Indicates if bft_mem_...() functions are initialized.
290  *
291  * returns:
292  * 1 if bft_mem_init has been called, 0 otherwise.
293  */
294
295 int
296 bft_mem_initialized(void);
297
298 /*
299  * Allocate memory for ni items of size bytes.
300  *
301  * This function calls malloc(), but adds tracing capabilities, and
302  * automatically calls the bft_error() errorhandler if it fails to
303  * allocate the required memory.
304  *
305  * Allocation couting and logging to trace file will be done if
306  * both required by the bft_mem_init options and if file_name != nullptr.
307  * If required but file_name == nullptr, it must be handled by the caller,
308  * using `bft_mem_log_mem_op`.
309  *
310  * parameters:
311  * ni <-- number of items.
312  * size <-- element size.
313  * var_name <-- allocated variable name string.
314  * file_name <-- name of calling source file.
315  * line_num <-- line number in calling source file.
316  *
317  * returns:
318  * pointer to allocated memory.
319  */
320
321 void *
322 bft_mem_malloc(size_t ni,
323  size_t size,
324  const char *var_name,
325  const char *file_name,
326  int line_num);
327
328 /*
329  * Reallocate memory for ni items of size bytes.
330  *
331  * This function calls realloc(), but adds tracing capabilities, and
332  * automatically calls the bft_error() errorhandler if it fails to
333  * allocate the required memory.
334  *
335  * parameters:
336  * ptr <-> pointer to previous memory location
337  * (if NULL, bft_alloc() called).
338  * ni <-- number of items.
339  * size <-- element size.
340  * var_name <-- allocated variable name string.
341  * file_name <-- name of calling source file.
342  * line_num -> line number in calling source file
343  *
344  * returns:
345  * pointer to allocated memory.
346  */
347
348 void *
349 bft_mem_realloc(void *ptr,
350  size_t ni,
351  size_t size,
352  const char *var_name,
353  const char *file_name,
354  int line_num);
355
356 /*
357  * Free allocated memory.
358  *
359  * This function calls free(), but adds tracing capabilities, and
360  * automatically calls the bft_error() errorhandler if it fails to
361  * free the corresponding memory. In case of a NULL pointer argument,
362  * the function simply returns.
363  *
364  * parameters:
365  * ptr <-> pointer to previous memory location
366  * (if NULL, bft_alloc() called).
367  * var_name <-- allocated variable name string.
368  * file_name <-- name of calling source file.
369  * line_num <-- line number in calling source file.
370  *
371  * returns:
372  * NULL pointer.
373  */
374
375 void *
376 bft_mem_free(void *ptr,
377  const char *var_name,
378  const char *file_name,
379  int line_num);
380
381 /*
382  * Allocate aligned memory for ni elements of size bytes.
383  *
384  * This function calls posix_memalign() if available, but adds tracing
385  * capabilities, and automatically calls the bft_error() errorhandler if
386  * it fails to allocate the required memory.
387  *
388  * The associated function bft_mem_have_memalign() indicates if this
389  * type of allocation may be used on this system.
390  *
391  * parameters:
392  * alignment <-- alignent.
393  * ni <-- number of items.
394  * size <-- element size.
395  * var_name <-- allocated variable name string.
396  * file_name <-- name of calling source file.
397  * line_num <-- line number in calling source file.
398  *
399  * returns:
400  * pointer to allocated memory.
401  */
402
403 void *
404 bft_mem_memalign(size_t alignment,
405  size_t ni,
406  size_t size,
407  const char *var_name,
408  const char *file_name,
409  int line_num);
410
417 size_t
419
426 size_t
427 bft_mem_size_max(void);
428
429 /*
430  * Indicate if a memory aligned allocation variant is available.
431  *
432  * If no such function is available, bft_mem_memalign() will always fail.
433  *
434  * returns:
435  * 1 if memory aligned allocation is possible, 0 otherwise.
436  */
437
438 int
440
441 /* Returns the error handler associated with the bft_mem_...() functions.
442  *
443  * returns:
444  * pointer to the error handler function.
445  */
446
449
450 /*
451  * Associates an error handler with the bft_mem_...() functions.
452  *
453  * With the default error handler, an error message is output to stderr,
454  * (after bft_print_flush() is called), and the general error handler used
455  * by bft_error() is then called (which results in the termination of the
456  * current process or process group).
457  *
458  * parameter:
459  * handler <-- pointer to the error handler function.
460  */
461
462 void
464
465 /*
466  * Associates alternative functions with the bft_mem_...() functions.
467  *
468  * When memory allocated with another mechanism is reallocated or
469  * freed using a bft_mem_... function, this allows trying the
470  * matching alternative function rather than throwing an error.
471  *
472  * Though using matching methods is recommended, this allows handling
473  * compatibility between methods which might be used in different parts
474  * of the code.
475  *
476  * parameter:
477  * realloc_func <-- pointer to alternative reallocation function.
478  * free_func <-- pointer to alternative free function.
479  */
480
481 void
483  bft_mem_free_t *free_func);
484
485 /*----------------------------------------------------------------------------*/
486
488
489 #endif /* __BFT_MEM_H__ */
void() bft_error_handler_t(const char *const file_name, const int line_num, const int sys_error_code, const char *const format, va_list arg_ptr)
Function pointer to opaque error handler.
Definition: bft_error.h:52
void bft_mem_update_block_info(const char *var_name, const char *file_name, int line_num, const cs_mem_block_t *old_block, const cs_mem_block_t *new_block)
Log matching memory operation if logging is enabled.
Definition: bft_mem.cpp:514
cs_mem_block_t bft_mem_get_block_info(const void *p_get)
Return the cs_mem_block structure corresponding to a given allocated block.
Definition: bft_mem.cpp:459
cs_mem_block_t bft_mem_get_block_info_try(const void *p_get)
Return the cs_mem_block structure corresponding to a given allocated block if available.
Definition: bft_mem.cpp:482
void bft_mem_alternative_set(bft_mem_realloc_t *realloc_func, bft_mem_free_t *free_func)
Definition: bft_mem.cpp:1187
void * bft_mem_malloc(size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory for ni elements of size bytes.
Definition: bft_mem.cpp:829
size_t bft_mem_size_current(void)
Return current theoretical dynamic memory allocated.
Definition: bft_mem.cpp:1106
int bft_mem_initialized(void)
Definition: bft_mem.cpp:802
void bft_mem_end(void)
Definition: bft_mem.cpp:741
size_t() bft_mem_get_size_t(void *ptr)
Definition: bft_mem.h:163
size_t bft_mem_size_max(void)
Return maximum theoretical dynamic memory allocated.
Definition: bft_mem.cpp:1118
void bft_mem_init(const char *log_file_name)
Definition: bft_mem.cpp:658
void() bft_mem_free_t(void *ptr, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.h:174
bft_error_handler_t * bft_mem_error_handler_get(void)
Definition: bft_mem.cpp:1148
void *() bft_mem_realloc_t(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.h:166
void bft_mem_error_handler_set(bft_error_handler_t *handler)
Definition: bft_mem.cpp:1165
void * bft_mem_memalign(size_t alignment, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.cpp:1037
int bft_mem_have_memalign(void)
Definition: bft_mem.cpp:1132
void * bft_mem_realloc(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory for ni elements of size bytes.
Definition: bft_mem.cpp:886
cs_alloc_mode_t
Definition: bft_mem.h:50
@ CS_ALLOC_HOST
Definition: bft_mem.h:52
@ CS_ALLOC_HOST_DEVICE_PINNED
Definition: bft_mem.h:54
@ CS_ALLOC_HOST_DEVICE_SHARED
Definition: bft_mem.h:57
Definition: bft_mem.h:53
@ CS_ALLOC_DEVICE
Definition: bft_mem.h:59
void * bft_mem_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.cpp:977
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: bft_mem.h:68
size_t size
Definition: bft_mem.h:74
void * host_ptr
host pointer
Definition: bft_mem.h:69
