8.2
cs_fan.h
1 #ifndef __CS_FAN_H__
2 #define __CS_FAN_H__
5  * Fan modeling through velocity source terms.
35  * Local headers
38 #include "cs_base.h"
40 #include "cs_mesh.h"
41 #include "cs_mesh_quantities.h"
46
48  * Structure definition
50
51 typedef struct _cs_fan_t cs_fan_t;
52
54  * Public function prototypes for Fortran API
56
58  * Compute the flows through the fans
59  *
60  * Fortran interface:
61  *
62  * subroutine debvtl
63  * *****************
64  *
65  * double precision flumas(*) : <-- : interior faces mass flux
66  * double precision flumab(*) : <-- : boundary faces mass flux
67  * double precision rhofac(*) : <-- : density at cells
68  * double precision rhofab(*) : <-- : density at boundary faces
69  *----------------------------------------------------------------------------*/
70
71 void CS_PROCF (debvtl, DEBVTL)
72 (
73  cs_real_t flumas[],
74  cs_real_t flumab[],
75  cs_real_t rhofac[],
76  cs_real_t rhofab[]
77 );
78
79 /*============================================================================
80  * Public function prototypes
81  *============================================================================*/
82
83 /*----------------------------------------------------------------------------
84  * Fan definition (added to the ones previously defined)
85  *
86  * Fans are handled as explicit momentum source terms at the given location,
87  * based on the fan's axis and diameter.
88  * The fan's pressure characteristic curve is defined by 3 coefficients,
89  * such that:
90  * delta P = C_0 + C_1.flow + C_2.flow^2
91  * An axial torque may also be defined for the 3D model.
92  *
93  * parameters:
94  * fan_dim <-- fan dimension:
95  * 2: pseudo-2D (extruded mesh)
96  * 3: 3D (standard)
97  * mode <-- mode:
98  * 0: fan
99  * 1: wind turbine
100  * inlet_axis_coords <-- intersection coords. of axis and inlet face
101  * outlet_axis_coords <-- intersection coords. od axis and outlet face
102  * fan_radius <-- fan radius
103  * blades_radius <-- blades radius
104  * hub_radius <-- hub radius
105  * curve_coeffs <-- coefficients of degre 0, 1 and 2 of
106  * the pressure drop/flow rate
107  * characteristic curve
108  * axial_torque <-- fan axial torque
109  *----------------------------------------------------------------------------*/
110
111 void
112 cs_fan_define(int fan_dim,
113  int mode,
114  const cs_real_t inlet_axis_coords[3],
115  const cs_real_t outlet_axis_coords[3],
116  cs_real_t fan_radius,
117  cs_real_t blades_radius,
118  cs_real_t hub_radius,
119  const cs_real_t curve_coeffs[3],
120  cs_real_t axial_torque);
121
122 /*----------------------------------------------------------------------------
123  * Destroy the structures associated with fans.
124  *----------------------------------------------------------------------------*/
125
126 void
127 cs_fan_destroy_all(void);
128
129 /*----------------------------------------------------------------------------
130  * Return number of fans.
131  *
132  * returns:
133  * number of defined fans
134  *----------------------------------------------------------------------------*/
135
136 int
137 cs_fan_n_fans(void);
138
139 /*----------------------------------------------------------------------------
140  * Log fans definition setup information.
141  *----------------------------------------------------------------------------*/
142
143 void
144 cs_fan_log_setup(void);
145
146 /*----------------------------------------------------------------------------
147  * Log fan information for a given iteration.
148  *----------------------------------------------------------------------------*/
149
150 void
152
153 /*----------------------------------------------------------------------------
154  * Define the cells belonging to the different fans.
155  *
156  * parameters:
157  * mesh <-- associated mesh structure
158  * mesh_quantities <-- mesh quantities
159  *----------------------------------------------------------------------------*/
160
161 void
163  const cs_mesh_quantities_t *mesh_quantities);
164
165 /*----------------------------------------------------------------------------
166  * Compute the flows through the fans.
167  *
168  * parameters:
169  * mesh <-- mesh structure
170  * mesh_quantities <-- mesh quantities
171  * i_mass_flux <-- interior faces mass flux
172  * b_mass_flux <-- boundary faces mass flux
173  * c_rho <-- density at cells
174  * b_rho <-- density at boundary faces
175  *----------------------------------------------------------------------------*/
176
177 void
179  const cs_mesh_quantities_t *mesh_quantities,
180  const cs_real_t i_mass_flux[],
181  const cs_real_t b_mass_flux[],
182  const cs_real_t c_rho[],
183  const cs_real_t b_rho[]);
184
185 /*----------------------------------------------------------------------------
186  * Compute the force induced by the fans (needs a previous calculation
187  * of the flows through each fan).
188  *
189  * The induced force is added to the array CRVXEP (which can have other
190  * other contributions).
191  *
192  * parameters:
193  * mesh_quantities <-- mesh quantities
194  * source_t <-> explicit source term for the velocity
195  *----------------------------------------------------------------------------*/
196
197 void
198 cs_fan_compute_force(const cs_mesh_quantities_t *mesh_quantities,
199  cs_real_3_t source_t[]);
200
201 /*----------------------------------------------------------------------------
202  * Flag the cells belonging to the different fans
203  * (by the fan id, -1 otherwise)
204  *
205  * parameters:
206  * mesh <-- associated mesh structure
207  * cell_fan_id --> indicator by cell
208  *----------------------------------------------------------------------------*/
209
210 void
212  int cell_fan_id[]);
213
214 /*----------------------------------------------------------------------------
215  * Selection function for cells belonging to fans.
216  *
217  * This function may be used for the definition of postprocessing meshes.
218  *
219  * param
220  * \param[in, out] input pointer to input (unused here)
221  * \param[out] n_cells number of selected cells
222  * \param[out] cell_ids array of selected cell ids (0 to n-1 numbering)
223  */
224 /*----------------------------------------------------------------------------*/
225
226 void
227 cs_fan_cells_select(void *input,
228  cs_lnum_t *n_cells,
229  cs_lnum_t **cell_ids);
230
231 /*----------------------------------------------------------------------------*/
232
234
235 #endif /* __CS_FAN_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
#define CS_PROCF(x, y)
Definition: cs_defs.h:560
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void cs_fan_compute_force(const cs_mesh_quantities_t *mesh_quantities, cs_real_3_t source_t[])
Compute the force induced by the fans (needs a previous calculation of the flows through each fan).
Definition: cs_fan.c:734
void debvtl(cs_real_t flumas[], cs_real_t flumab[], cs_real_t rhofac[], cs_real_t rhofab[])
Definition: cs_fan.c:157
void cs_fan_log_setup(void)
Definition: cs_fan.c:323
Definition: cs_fan.h:51
void cs_fan_cells_select(void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids)
Definition: cs_fan.c:941
void cs_fan_build_all(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Definition: cs_fan.c:405
int cs_fan_n_fans(void)
Definition: cs_fan.c:311
void cs_fan_compute_flows(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, const cs_real_t i_mass_flux[], const cs_real_t b_mass_flux[], const cs_real_t c_rho[], const cs_real_t b_rho[])
Definition: cs_fan.c:600
void cs_fan_destroy_all(void)
Definition: cs_fan.c:289
void cs_fan_define(int fan_dim, int mode, const cs_real_t inlet_axis_coords[3], const cs_real_t outlet_axis_coords[3], cs_real_t fan_radius, cs_real_t blades_radius, cs_real_t hub_radius, const cs_real_t curve_coeffs[3], cs_real_t axial_torque)
Definition: cs_fan.c:206
void cs_fan_log_iteration(void)
Definition: cs_fan.c:369
void cs_fan_flag_cells(const cs_mesh_t *mesh, int cell_fan_id[])
Flag the cells belonging to the different fans (by the fan id, -1 otherwise)
Definition: cs_fan.c:893
Definition: mesh.f90:26
Definition: cs_mesh.h:85
