8.2
cs_multigrid.h
1 #ifndef __CS_MULTIGRID_H__
2 #define __CS_MULTIGRID_H__
5  * Multigrid solver.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_grid.h"
36 #include "cs_sles.h"
37 #include "cs_sles_it.h"
38 #include "cs_sles_pc.h"
39 #include "cs_time_plot.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /*----------------------------------------------------------------------------
54  * Multigrid types
55  *----------------------------------------------------------------------------*/
56
57 typedef enum {
58
65
66 /* Multigrid linear solver context (opaque) */
67
68 typedef struct _cs_multigrid_t cs_multigrid_t;
69
70 /*============================================================================
71  * Global variables
72  *============================================================================*/
73
74 /* Names for multigrid types */
75
76 extern const char *cs_multigrid_type_name[];
77
78 /*=============================================================================
79  * Public function prototypes
80  *============================================================================*/
81
82 /*----------------------------------------------------------------------------
83  * Initialize multigrid solver API.
84  *----------------------------------------------------------------------------*/
85
86 void
88
89 /*----------------------------------------------------------------------------
90  * Finalize multigrid solver API.
91  *----------------------------------------------------------------------------*/
92
93 void
95
96 /*----------------------------------------------------------------------------*
97  * Set maximum grid level which should run on device (i.e. GPU).
98  *----------------------------------------------------------------------------*/
99
100 void
102
103 /*----------------------------------------------------------------------------
104  * Define and associate a multigrid sparse linear system solver
105  * for a given field or equation name.
106  *
107  * If this system did not previously exist, it is added to the list of
108  * "known" systems. Otherwise, its definition is replaced by the one
109  * defined here.
110  *
111  * This is a utility function: if finer control is needed, see
112  * cs_sles_define() and cs_multigrid_create().
113  *
114  * Note that this function returns a pointer directly to the multigrid solver
115  * management structure. This may be used to set further options, for
116  * example calling cs_multigrid_set_coarsening_options() and
117  * cs_multigrid_set_solver_options().
118  * If needed, cs_sles_find() may be used to obtain a pointer to the
119  * matching cs_sles_t container.
120  *
121  * \param[in] f_id associated field id, or < 0
122  * \param[in] name associated name if f_id < 0, or NULL
123  * \param[in] mg_type type of multigrid algorithm to use
124  *
125  * \return pointer to new multigrid info and context
126  */
128
130 cs_multigrid_define(int f_id,
131  const char *name,
132  cs_multigrid_type_t mg_type);
133
144 /*----------------------------------------------------------------------------*/
145
148
149 /*----------------------------------------------------------------------------
150  * Destroy multigrid linear system solver info and context.
151  *
152  * parameters:
153  * context <-> pointer to multigrid linear solver info
154  * (actual type: cs_multigrid_t **)
155  *----------------------------------------------------------------------------*/
156
157 void
158 cs_multigrid_destroy(void **context);
159
160 /*----------------------------------------------------------------------------
161  * Create multigrid sparse linear system solver info and context
162  * based on existing info and context.
163  *
164  * parameters:
165  * context <-- pointer to reference info and context
166  * (actual type: cs_multigrid_t *)
167  *
168  * returns:
169  * pointer to newly created solver info object
170  * (actual type: cs_multigrid_t *)
171  *----------------------------------------------------------------------------*/
172
173 void *
174 cs_multigrid_copy(const void *context);
175
176 /*----------------------------------------------------------------------------
177  * Set multigrid coarsening parameters.
178  *
179  * parameters:
180  * mg <-> pointer to multigrid info and context
181  * aggregation_limit <-- maximum allowed fine rows per coarse cell
182  * coarsening_type <-- coarsening type; see cs_grid_coarsening_t
183  * n_max_levels <-- maximum number of grid levels
184  * min_g_rows <-- global number of rows on coarse grids
185  * under which no coarsening occurs
186  * p0p1_relax <-- p0/p1 relaxation_parameter
187  * postprocess_block_size <-- if > 0, postprocess coarsening
188  * (using coarse cell numbers modulo this value)
189  *----------------------------------------------------------------------------*/
190
191 void
193  (cs_multigrid_t *mg,
194  int aggregation_limit,
195  cs_grid_coarsening_t coarsening_type,
196  int n_max_levels,
197  cs_gnum_t min_g_rows,
198  double p0p1_relax,
199  int postprocess_block_size);
200
201 /*----------------------------------------------------------------------------
202  * Set multigrid parameters for associated iterative solvers.
203  *
204  * parameters:
205  * mg <-> pointer to multigrid info and context
206  * descent_smoother_type <-- type of smoother for descent
207  * ascent_smoother_type <-- type of smoother for ascent
208  * coarse_solver_type <-- type of solver
209  * n_max_cycles <-- maximum number of cycles
210  * n_max_iter_descent <-- maximum iterations per descent phase
211  * n_max_iter_ascent <-- maximum iterations per descent phase
212  * n_max_iter_coarse <-- maximum iterations per coarsest solution
213  * poly_degree_descent <-- preconditioning polynomial degree
214  * for descent phases (0: diagonal)
215  * poly_degree_ascent <-- preconditioning polynomial degree
216  * for ascent phases (0: diagonal)
217  * poly_degree_coarse <-- preconditioning polynomial degree
218  * for coarse solver (0: diagonal)
219  * precision_mult_descent <-- precision multiplier for descent phases
220  * (levels >= 1)
221  * precision_mult_ascent <-- precision multiplier for ascent phases
222  * precision_mult_coarse <-- precision multiplier for coarsest grid
223  *----------------------------------------------------------------------------*/
224
225 void
227  cs_sles_it_type_t descent_smoother_type,
228  cs_sles_it_type_t ascent_smoother_type,
229  cs_sles_it_type_t coarse_solver_type,
230  int n_max_cycles,
231  int n_max_iter_descent,
232  int n_max_iter_ascent,
233  int n_max_iter_coarse,
234  int poly_degree_descent,
235  int poly_degree_ascent,
236  int poly_degree_coarse,
237  double precision_mult_descent,
238  double precision_mult_ascent,
239  double precision_mult_coarse);
240
241 /*----------------------------------------------------------------------------*/
248 /*----------------------------------------------------------------------------*/
249
250 void
252  int n_max_cycles);
253
254 /*----------------------------------------------------------------------------
255  * Return solver type used on fine mesh.
256  *
257  * parameters:
258  * mg <-- pointer to multigrid info and context
259  *
260  * returns:
261  * type of smoother for descent (used for fine mesh)
262  *----------------------------------------------------------------------------*/
263
266
267 /*----------------------------------------------------------------------------
268  * Setup multigrid sparse linear equation solver.
269  *
270  * parameters:
271  * context <-> pointer to multigrid info and context
272  * (actual type: cs_multigrid_t *)
273  * name <-- pointer to name of linear system
274  * a <-- associated matrix
275  * verbosity <-- associated verbosity
276  *----------------------------------------------------------------------------*/
277
278 void
279 cs_multigrid_setup(void *context,
280  const char *name,
281  const cs_matrix_t *a,
282  int verbosity);
283
284 /*----------------------------------------------------------------------------
285  * Setup multigrid sparse linear equation solver with separate
286  * convection-diffusion matrixes
287  *
288  * parameters:
289  * context <-> pointer to multigrid info and context
290  * (actual type: cs_multigrid_t *)
291  * name <-- pointer to name of linear system
292  * a <-- associated matrix
293  * conv_diff <-- convection-diffusion mode
294  * verbosity <-- associated verbosity
295  *----------------------------------------------------------------------------*/
296
297 void
298 cs_multigrid_setup_conv_diff(void *context,
299  const char *name,
300  const cs_matrix_t *a,
301  bool conv_diff,
302  int verbosity);
303
304 /*----------------------------------------------------------------------------
305  * Call multigrid sparse linear equation solver.
306  *
307  * parameters:
308  * context <-> pointer to iterative sparse linear solver info
309  * (actual type: cs_multigrid_t *)
310  * name <-- pointer to name of linear system
311  * a <-- matrix
312  * verbosity <-- associated verbosity
313  * precision <-- solver precision
314  * r_norm <-- residual normalization
315  * n_iter --> number of iterations
316  * residual --> residual
317  * rhs <-- right hand side
318  * vx_ini <-- initial solution (vx if nonzero, nullptr if zero)
319  * vx <-> system solution
320  * aux_size <-- number of elements in aux_vectors
321  * aux_vectors --- optional working area (internal allocation if NULL)
322  *
323  * returns:
324  * convergence state
325  *----------------------------------------------------------------------------*/
326
328 cs_multigrid_solve(void *context,
329  const char *name,
330  const cs_matrix_t *a,
331  int verbosity,
332  double precision,
333  double r_norm,
334  int *n_iter,
335  double *residual,
336  const cs_real_t *rhs,
337  cs_real_t *vx_ini,
338  cs_real_t *vx,
339  size_t aux_size,
340  void *aux_vectors);
341
342 /*----------------------------------------------------------------------------
343  * Free iterative sparse linear equation solver setup context.
344  *
345  * Note that this function should free resolution-related data, such as
346  * buffers and preconditioning but does not free the whole context,
347  * as info used for logging (especially performance data) is maintained.
348
349  * parameters:
350  * context <-> pointer to iterative sparse linear solver info
351  * (actual type: cs_multigrid_t *)
352  *----------------------------------------------------------------------------*/
353
354 void
355 cs_multigrid_free(void *context);
356
357 /*----------------------------------------------------------------------------
358  * Log sparse linear equation solver info.
359  *
360  * parameters:
361  * context <-> pointer to iterative sparse linear solver info
362  * (actual type: cs_multigrid_t *)
363  * log_type <-- log type
364  *----------------------------------------------------------------------------*/
365
366 void
367 cs_multigrid_log(const void *context,
368  cs_log_t log_type);
369
370 /*----------------------------------------------------------------------------*/
378 /*----------------------------------------------------------------------------*/
379
380 cs_sles_pc_t *
382
383 /*----------------------------------------------------------------------------
384  * Error handler for multigrid sparse linear equation solver.
385  *
386  * In case of divergence or breakdown, this error handler outputs
387  * postprocessing data to assist debugging, then aborts the run.
388  * It does nothing in case the maximum iteration count is reached.
389  *
390  * parameters:
391  * sles <-> pointer to solver object
392  * state <-- convergence status
393  * a <-- matrix
394  * rhs <-- right hand side
395  * vx <-> system solution
396  *
397  * returns:
398  * false (do not attempt new solve)
399  *----------------------------------------------------------------------------*/
400
401 bool
404  const cs_matrix_t *a,
405  const cs_real_t *rhs,
406  cs_real_t *vx);
407
408 /*----------------------------------------------------------------------------
409  * Set plotting options for multigrid.
410  *
411  * parameters:
412  * mg <-> pointer to multigrid info and context
413  * base_name <-- base plot name to activate, NULL otherwise
414  * use_iteration <-- if true, use iteration as time stamp
415  * otherwise, use wall clock time
416  *----------------------------------------------------------------------------*/
417
418 void
420  const char *base_name,
421  bool use_iteration);
422
423 /*----------------------------------------------------------------------------*/
435 /*----------------------------------------------------------------------------*/
436
437 void
439  int *rank_stride,
440  int *rows_mean_threshold,
441  cs_gnum_t *rows_glob_threshold);
442
443 /*----------------------------------------------------------------------------*/
455 /*----------------------------------------------------------------------------*/
456
457 void
459  int rank_stride,
460  int rows_mean_threshold,
461  cs_gnum_t rows_glob_threshold);
462
463 /*----------------------------------------------------------------------------*/
476 /*----------------------------------------------------------------------------*/
477
478 const cs_grid_t *
480  int level);
481
482 /*----------------------------------------------------------------------------*/
483
485
486 #endif /* __CS_MULTIGRID_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:310
Definition: cs_defs.h:529
Definition: cs_grid.h:55
struct _cs_grid_t cs_grid_t
Definition: cs_grid.h:68
cs_log_t
Definition: cs_log.h:48
Definition: cs_matrix.h:110
void cs_multigrid_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Definition: cs_multigrid.cpp:4775
void cs_multigrid_setup_conv_diff(void *context, const char *name, const cs_matrix_t *a, bool conv_diff, int verbosity)
Definition: cs_multigrid.cpp:4801
cs_sles_it_type_t cs_multigrid_get_fine_solver_type(const cs_multigrid_t *mg)
Definition: cs_multigrid.cpp:4752
Definition: cs_multigrid.h:68
void * cs_multigrid_copy(const void *context)
Create multigrid sparse linear system solver info and context based on existing info and context.
Definition: cs_multigrid.cpp:4551
cs_multigrid_type_t
Definition: cs_multigrid.h:57
@ CS_MULTIGRID_K_CYCLE
Definition: cs_multigrid.h:60
@ CS_MULTIGRID_N_TYPES
Definition: cs_multigrid.h:62
@ CS_MULTIGRID_K_CYCLE_HPC
Definition: cs_multigrid.h:61
@ CS_MULTIGRID_V_CYCLE
Definition: cs_multigrid.h:59
void cs_multigrid_get_merge_options(const cs_multigrid_t *mg, int *rank_stride, int *rows_mean_threshold, cs_gnum_t *rows_glob_threshold)
Query the global multigrid parameters for parallel grid merging.
Definition: cs_multigrid.cpp:5483
void cs_multigrid_set_max_grid_level_for_device(int level)
Definition: cs_multigrid.cpp:4313
cs_sles_pc_t * cs_multigrid_pc_create(cs_multigrid_type_t mg_type)
Create a multigrid preconditioner.
Definition: cs_multigrid.cpp:5195
cs_multigrid_t * cs_multigrid_define(int f_id, const char *name, cs_multigrid_type_t mg_type)
Define and associate a multigrid sparse linear system solver for a given field or equation name.
Definition: cs_multigrid.cpp:4346
cs_multigrid_t * cs_multigrid_create(cs_multigrid_type_t mg_type)
Create multigrid linear system solver info and context.
Definition: cs_multigrid.cpp:4383
void cs_multigrid_set_coarsening_options(cs_multigrid_t *mg, int aggregation_limit, cs_grid_coarsening_t coarsening_type, int n_max_levels, cs_gnum_t min_g_rows, double p0p1_relax, int postprocess_block_size)
Definition: cs_multigrid.cpp:4616
cs_sles_convergence_state_t cs_multigrid_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Definition: cs_multigrid.cpp:4886
const cs_grid_t * cs_multigrid_get_grid(const cs_multigrid_t *mg, int level)
Return a pointer to a grid associated with a given multigrid setup and level.
Definition: cs_multigrid.cpp:5550
void cs_multigrid_set_merge_options(cs_multigrid_t *mg, int rank_stride, int rows_mean_threshold, cs_gnum_t rows_glob_threshold)
Set global multigrid parameters for parallel grid merging behavior.
Definition: cs_multigrid.cpp:5520
void cs_multigrid_set_plot_options(cs_multigrid_t *mg, const char *base_name, bool use_iteration)
Definition: cs_multigrid.cpp:5437
bool cs_multigrid_error_post_and_abort(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
void cs_multigrid_set_solver_options(cs_multigrid_t *mg, cs_sles_it_type_t descent_smoother_type, cs_sles_it_type_t ascent_smoother_type, cs_sles_it_type_t coarse_solver_type, int n_max_cycles, int n_max_iter_descent, int n_max_iter_ascent, int n_max_iter_coarse, int poly_degree_descent, int poly_degree_ascent, int poly_degree_coarse, double precision_mult_descent, double precision_mult_ascent, double precision_mult_coarse)
Definition: cs_multigrid.cpp:4669
void cs_multigrid_free(void *context)
Free multigrid sparse linear equation solver setup context.
Definition: cs_multigrid.cpp:5125
void cs_multigrid_initialize(void)
Definition: cs_multigrid.cpp:4290
void cs_multigrid_log(const void *context, cs_log_t log_type)
Log multigrid solver info.
Definition: cs_multigrid.cpp:4583
void cs_multigrid_set_max_cycles(cs_multigrid_t *mg, int n_max_cycles)
Set the max. number of cycles for a multigrid.
Definition: cs_multigrid.cpp:4730
void cs_multigrid_finalize(void)
Definition: cs_multigrid.cpp:4301
const char * cs_multigrid_type_name[]
void cs_multigrid_destroy(void **context)
Definition: cs_multigrid.cpp:4498
Definition: cs_sles.h:56
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
cs_sles_it_type_t
Definition: cs_sles_it.h:55
Definition: cs_sles_pc.h:66
