Include dependency graph for cs_sles_it.h:Go to the source code of this file.
| typedef struct _cs_sles_it_t | cs_sles_it_t |
| typedef struct _cs_sles_it_convergence_t | cs_sles_it_convergence_t |
| cs_sles_convergence_state_t | cs_user_sles_it_solver (cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *restrict vx_ini, cs_real_t *restrict vx, size_t aux_size, void *aux_vectors) |
| cs_sles_it_t * | cs_sles_it_define (int f_id, const char *name, cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter) |
| Define and associate an iterative sparse linear system solver for a given field or equation name. More... | |
| cs_sles_it_t * | cs_sles_it_create (cs_sles_it_type_t solver_type, int poly_degree, int n_max_iter, bool update_stats) |
| Create iterative sparse linear system solver info and context. More... | |
| void | cs_sles_it_destroy (void **context) |
| Destroy iterative sparse linear system solver info and context. More... | |
| void * | cs_sles_it_copy (const void *context) |
| Create iterative sparse linear system solver info and context based on existing info and context. More... | |
| void | cs_sles_it_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup iterative sparse linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_it_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx, cs_real_t *vx_ini, size_t aux_size, void *aux_vectors) |
| Call iterative sparse linear equation solver. More... | |
| void | cs_sles_it_free (void *context) |
| Free iterative sparse linear equation solver setup context. More... | |
| void | cs_sles_it_log (const void *context, cs_log_t log_type) |
| cs_sles_it_type_t | cs_sles_it_get_type (const cs_sles_it_t *context) |
| Return iterative solver type. More... | |
| double | cs_sles_it_get_last_initial_residual (const cs_sles_it_t *context) |
| Return the initial residual for the previous solve operation with a solver. More... | |
| cs_sles_pc_t * | cs_sles_it_get_pc (cs_sles_it_t *context) |
| Return a preconditioner context for an iterative sparse linear equation solver. More... | |
| void | cs_sles_it_transfer_pc (cs_sles_it_t *context, cs_sles_pc_t **pc) |
| Assign a preconditioner to an iterative sparse linear equation solver, transfering its ownership to the solver context. More... | |
| void | cs_sles_it_transfer_parameters (const cs_sles_it_t *src, cs_sles_it_t *dest) |
| Copy options from one iterative sparse linear system solver info and context to another. More... | |
| void | cs_sles_it_set_shareable (cs_sles_it_t *context, const cs_sles_it_t *shareable) |
| Associate a similar info and context object with which some setup data may be shared. More... | |
| void | cs_sles_it_assign_order (cs_sles_it_t *context, cs_lnum_t **order) |
| Assign ordering to iterative solver. More... | |
| double | cs_sles_it_get_breakdown_threshold (void) |
| Retrieve the threshold value under which a breakdown happens in solvers like BiCGStab or BiCGStab2. More... | |
| void | cs_sles_it_set_breakdown_threshold (double threshold) |
| Define the threshold value under which a breakdown happens in solvers like BiCGStab or BiCGStab2. More... | |
| void | cs_sles_it_set_fallback_threshold (cs_sles_it_t *context, cs_sles_convergence_state_t threshold, int n_iter_max) |
| Define convergence level under which the fallback to another solver may be used if applicable. More... | |
| void | cs_sles_it_set_restart_interval (cs_sles_it_t *context, int interval) |
| Define the number of iterations to be done before restarting the solver. Useful only for GCR or GMRES algorithms. More... | |
| void | cs_sles_it_set_n_max_iter (cs_sles_it_t *context, int n_max_iter) |
| Define the max. number of iterations before stopping the algorithm. More... | |
| cs_lnum_t | cs_sles_it_get_pcg_single_reduction (void) |
| Query mean number of rows under which Conjugate Gradient algorithm uses the single-reduction variant. More... | |
| void | cs_sles_it_set_pcg_single_reduction (cs_lnum_t threshold) |
| Set mean number of rows under which Conjugate Gradient algorithm should use the single-reduction variant. More... | |
| void | cs_sles_it_log_parallel_options (void) |
| Log the current global settings relative to parallelism. More... | |
| bool | cs_sles_it_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| Error handler for iterative sparse linear equation solver. More... | |
| void | cs_sles_it_set_plot_options (cs_sles_it_t *context, const char *base_name, bool use_iteration) |
| Set plotting options for an iterative sparse linear equation solver. More... | |
| cs_sles_convergence_state_t | cs_sles_it_convergence_test (cs_sles_it_t *c, unsigned n_iter, double residual, cs_sles_it_convergence_t *convergence) |
| const char * | cs_sles_it_type_name [] |
| typedef struct _cs_sles_it_convergence_t cs_sles_it_convergence_t |
| typedef struct _cs_sles_it_t cs_sles_it_t |
| enum cs_sles_it_type_t |
| Enumerator | |
| CS_SLES_PCG | Preconditioned conjugate gradient |
| CS_SLES_FCG | Preconditions flexible conjugate gradient, described in [16] |
| CS_SLES_IPCG | Preconditions inexact conjugate gradient |
| CS_SLES_JACOBI | Jacobi |
| CS_SLES_BICGSTAB | Preconditioned BiCGstab (biconjugate gradient stabilized) |
| CS_SLES_BICGSTAB2 | Preconditioned BiCGstab2 |
| CS_SLES_GCR | Generalized conjugate residual |
| CS_SLES_GMRES | Preconditioned GMRES (generalized minimal residual) |
| CS_SLES_P_GAUSS_SEIDEL | Process-local Gauss-Seidel |
| CS_SLES_P_SYM_GAUSS_SEIDEL | Process-local symmetric Gauss-Seidel |
| CS_SLES_PCR3 | 3-layer conjugate residual |
| CS_SLES_USER_DEFINED | User-defined iterative solver |
| CS_SLES_N_IT_TYPES | Number of resolution algorithms excluding smoother only |
| CS_SLES_TS_F_GAUSS_SEIDEL | Truncated forward Gauss-Seidel smoother |
| CS_SLES_TS_B_GAUSS_SEIDEL | Truncated backward Gauss-Seidel smoother |
| CS_SLES_N_SMOOTHER_TYPES | Number of resolution algorithms including smoother only |
| void cs_sles_it_assign_order | ( | cs_sles_it_t * | context, |
| cs_lnum_t ** | order | ||
The solver context takes ownership of the order array (i.e. it will handle its later deallocation).
This is useful only for Process-local Gauss-Seidel.
| [in,out] | context | pointer to iterative solver info and context |
| [in,out] | order | pointer to ordering array |
| cs_sles_convergence_state_t cs_sles_it_convergence_test | ( | cs_sles_it_t * | c, |
| unsigned | n_iter, | ||
| double | residual, | ||
| cs_sles_it_convergence_t * | convergence | ||
| void* cs_sles_it_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_sles_it_t *) |
| cs_sles_it_t* cs_sles_it_create | ( | cs_sles_it_type_t | solver_type, |
| int | poly_degree, | ||
| int | n_max_iter, | ||
| bool | update_stats | ||
| [in] | solver_type | type of solver (PCG, Jacobi, ...) |
| [in] | poly_degree | preconditioning polynomial degree (0: diagonal; -1: non-preconditioned; see Iterative linear solvers. for details) |
| [in] | n_max_iter | maximum number of iterations |
| [in] | update_stats | automatic solver statistics indicator |
| cs_sles_it_t* cs_sles_it_define | ( | int | f_id, |
| const char * | name, | ||
| cs_sles_it_type_t | solver_type, | ||
| int | n_max_iter | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_it_create.
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options, for example using cs_sles_it_set_plot_options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
| [in] | poly_degree | preconditioning polynomial degree (0: diagonal; -1: non-preconditioned) |
| void cs_sles_it_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_it_t **) |
| bool cs_sles_it_error_post_and_abort | ( | cs_sles_t * | sles, |
| cs_real_t * | vx | ||
In case of divergence or breakdown, this error handler outputs postprocessing data to assist debugging, then aborts the run. It does nothing in case the maximum iteration count is reached.
| [in] | a | matrix |
| void cs_sles_it_free | ( | void * | context | ) |
| [in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_it_t *) |
| double cs_sles_it_get_breakdown_threshold | ( | void | ) |
| double cs_sles_it_get_last_initial_residual | ( | const cs_sles_it_t * | context | ) |
This is useful for convergence tests when this solver is used as a preconditioning smoother.
This operation is only valid between calls to cs_sles_it_setup (or cs_sles_it_solve) and cs_sles_it_free. It returns -1 otherwise.
| [in] | context | pointer to iterative solver info and context |
| cs_sles_pc_t* cs_sles_it_get_pc | ( | cs_sles_it_t * | context | ) |
This allows modifying parameters of a non default (Jacobi or polynomial) preconditioner.
| cs_lnum_t cs_sles_it_get_pcg_single_reduction | ( | void | ) |
The single-reduction variant requires only one parallel sum per iteration (instead of 2), at the cost of additional vector operations, so it tends to be more expensive when the number of matrix rows per MPI rank is high, then becomes cheaper when the MPI latency cost becomes more significant.
This option is ignored for non-parallel runs, so 0 is returned.
| cs_sles_it_type_t cs_sles_it_get_type | ( | const cs_sles_it_t * | context | ) |
| void cs_sles_it_log | ( | const void * | context, |
| cs_log_t | log_type | ||
| [in] | context | pointer to iterative solver info and context (actual type: cs_sles_it_t *) |
| void cs_sles_it_log_parallel_options | ( | void | ) |
| void cs_sles_it_set_breakdown_threshold | ( | double | threshold | ) |
| [in] | threshold | value of the threshold |
| void cs_sles_it_set_fallback_threshold | ( | cs_sles_it_t * | context, |
| cs_sles_convergence_state_t | threshold, | ||
| int | n_iter_max | ||
Currently, this mechanism is used by default for solvers which may exhibit breakdown, such as BiCGstab and 3-layer conjugate residual solvers, which may fall back to a more robust preconditioned GMRES solver.
For those solvers, the default threshold is CS_SLES_MAX_ITERATION, meaning that reaching breakdown will lead to the use of the fallback mechanism.
| [in] | threshold | convergence level under which fallback is used |
| [in] | n_iter_max | maximum number of iterations fo fallback solver |
| void cs_sles_it_set_n_max_iter | ( | cs_sles_it_t * | context, |
| [in] | n_max_iter | max. number of iterations |
| void cs_sles_it_set_pcg_single_reduction | ( | cs_lnum_t | threshold | ) |
This option is ignored for non-parallel runs.
| [in] | threshold | mean number of rows per active rank under which the single-reduction variant will be used |
| void cs_sles_it_set_plot_options | ( | cs_sles_it_t * | context, |
| const char * | base_name, | ||
| bool | use_iteration | ||
| [in] | base_name | base plot name to activate, NULL otherwise |
| [in] | use_iteration | if true, use iteration as time stamp otherwise, use wall clock time |
| void cs_sles_it_set_restart_interval | ( | cs_sles_it_t * | context, |
| int | interval | ||
| [in] | interval | convergence level under which fallback is used |
| void cs_sles_it_set_shareable | ( | cs_sles_it_t * | context, |
| const cs_sles_it_t * | shareable | ||
This is especially useful for sharing preconditioning data between similar solver contexts (for example ascending and descending multigrid smoothers based on the same matrix).
For preconditioning data to be effectively shared, cs_sles_it_setup (or cs_sles_it_solve) must be called on shareable before being called on context (without cs_sles_it_free being called in between, of course).
It is the caller's responsibility to ensure the context is not used for a cs_sles_it_setup or cs_sles_it_solve operation after the shareable object has been destroyed (normally by cs_sles_it_destroy).
| [in] | shareable | pointer to iterative solver info and context whose context may be shared |
| void cs_sles_it_setup | ( | void * | context, |
| int | verbosity | ||
| cs_sles_convergence_state_t cs_sles_it_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx_ini, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
| [in] | a | matrix |
| void cs_sles_it_transfer_parameters | ( | const cs_sles_it_t * | src, |
| cs_sles_it_t * | dest | ||
Optional plotting contexts are shared between the source and destination contexts.
Preconditioner settings are to be handled separately.
| [in] | src | pointer to source info and context |
| [in,out] | dest | pointer to destination info and context |
| void cs_sles_it_transfer_pc | ( | cs_sles_it_t * | context, |
| cs_sles_pc_t ** | pc | ||
This allows assigning a non default (Jacobi or polynomial) preconditioner.
The input pointer is set to NULL to make it clear the caller does not own the preconditioner anymore, though the context can be accessed using cs_sles_it_get_pc.
| [in,out] | pc | pointer to preconditoner context |
| cs_sles_convergence_state_t cs_user_sles_it_solver | ( | cs_sles_it_t * | c, |
| cs_sles_it_convergence_t * | convergence, | ||
| cs_real_t *restrict | vx_ini, | ||
| cs_real_t *restrict | vx, | ||
extern |
