375 const char *property_name,
#define restrict
Definition: cs_defs.h:141
Definition: cs_defs.h:528
Definition: cs_defs.h:332
#define CS_PROCF(x, y)
Definition: cs_defs.h:560
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:347
Definition: cs_defs.h:529
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:356
@ vel
void cs_gui_porous_model(void)
Definition: cs_gui.c:4290
cs_equation_param_t * cs_gui_get_equation_param(const char *name)
Definition: cs_gui.c:2435
void cs_gui_initial_conditions(void)
Apply initial conditions based on GUI-defined settings.
Definition: cs_gui.c:2933
void uiporo(void)
Definition: cs_gui.c:2028
void cs_gui_equation_parameters(void)
Definition: cs_gui.c:2313
void cs_gui_time_tables(void)
Read GUI defined time tables.
Definition: cs_gui.c:5666
void cs_gui_pressure_drop_by_zone(void)
Definition: cs_gui.c:5232
void cs_gui_checkpoint_parameters(void)
Read GUi-defined Checkpoint parameters.
Definition: cs_gui.c:2277
void cs_gui_parallel_io(void)
Definition: cs_gui.c:3905
void cs_gui_finalize(void)
Definition: cs_gui.c:2412
void uiexop(void)
Definition: cs_gui.c:2260
void cs_gui_internal_coupling(void)
Definition: cs_gui.c:5372
void cs_gui_properties_value(const char *property_name, double *value)
Definition: cs_gui.c:4326
void cs_gui_turb_model(void)
Definition: cs_gui.c:4744
void csiphy(void)
Definition: cs_gui.c:1895
void cstime(void)
Definition: cs_gui.c:1948
void cs_gui_time_moments(void)
Definition: cs_gui.c:4538
void csnum2(double *relaxp, int *imrgra)
void cs_gui_properties_value_by_fluid_id(const int fluid_id, const char *property_name, double *value)
Definition: cs_gui.c:4352
void cs_gui_physical_properties(void)
Definition: cs_gui.c:4132
void cs_gui_user_variables(void)
Definition: cs_gui.c:4923
void cs_gui_scalar_source_terms(cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:5502
void cs_gui_linear_solvers(void)
Definition: cs_gui.c:3498
void cs_gui_scalar_model_settings(void)
Definition: cs_gui.c:4387
void cs_gui_fluid_properties_value(const char *param, double *value)
Definition: cs_gui.c:2458
void cs_gui_calculator_functions(void)
Definition: cs_gui.c:5011
void csidtv(void)
Definition: cs_gui.c:1871
void uiphyv(void)
Definition: cs_gui.c:2108
void cs_gui_turbomachinery(void)
Definition: cs_gui.c:4638
void csfpva(void)
Definition: cs_gui.c:1771
void cs_gui_numerical_options(void)
Definition: cs_gui.c:3780
void cs_gui_user_arrays(void)
Definition: cs_gui.c:4983
int cs_gui_thermal_model_code(void)
Definition: cs_gui.c:4501
void cs_gui_thermal_source_terms(cs_field_t *f, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:5586
void cs_gui_zones(void)
Definition: cs_gui.c:5058
void cs_gui_define_fans(void)
Definition: cs_gui.c:5254
void cs_gui_balance_by_zone(void)
Definition: cs_gui.c:5203
void cs_gui_error_estimator(void)
Definition: cs_gui.c:5320
void cs_gui_usage_log(void)
Definition: cs_gui.c:4895
void cscfgp(void)
Definition: cs_gui.c:1921
void csivis(void)
Definition: cs_gui.c:1798
const cs_gui_volume_meg_context_t * cs_gui_add_volume_meg_context(const cs_zone_t *zone, const cs_field_t *fields[], const int n_fields)
Add new volume MEG function context info.
Definition: cs_gui.c:5457
void cs_gui_turb_ref_values(void)
Definition: cs_gui.c:4856
void cs_gui_turbomachinery_rotor(void)
Definition: cs_gui.c:4653
void cs_gui_partition(void)
Definition: cs_gui.c:3972
void cs_gui_momentum_source_terms(const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp)
Definition: cs_gui.c:3669
void cs_gui_head_losses(const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
Compute GUI-defined head losses for a given volume zone.
Definition: cs_gui.c:2862
void cs_gui_mpi_algorithms(void)
Definition: cs_gui.c:4068
void cs_gui_physical_constants(void)
Definition: cs_gui.c:4093
void cs_gui_thermal_model(void)
Definition: cs_gui.c:4457
void cs_gui_groundwater_property_laws(int permeability, int diffusion, int unsaturated)
Definition: cs_gui.c:2478
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:137
Definition: cs_equation_param.h:193
Definition: cs_field.h:131
const cs_zone_t * zone
Definition: cs_gui.h:51
const cs_field_t ** fields
Definition: cs_gui.h:52
