7.2
alge Directory Reference
Files
file
cs_alge_headers.h
[code]
file
cs_bad_cells_regularisation.c
file
cs_bad_cells_regularisation.h
[code]
file
cs_balance.c
Wrapper to the function which adds the explicit part of the convection/diffusion terms of a transport equation of a field.
file
cs_balance.h
[code]
file
cs_balance_by_zone.c
file
cs_balance_by_zone.h
[code]
file
cs_benchmark.c
file
cs_benchmark.h
[code]
file
cs_benchmark_cuda.h
[code]
file
cs_benchmark_matrix.c
file
cs_benchmark_matrix.h
[code]
file
cs_blas.c
file
cs_blas.h
[code]
file
cs_blas_cuda.h
[code]
file
cs_bw_time_diff.c
file
cs_cell_to_vertex.c
Cell to vertex interpolation..
file
cs_cell_to_vertex.h
[code]
file
cs_convection_diffusion.c
Convection-diffusion operators.
file
cs_convection_diffusion.h
[code]
file
cs_divergence.c
file
cs_divergence.h
[code]
file
cs_face_viscosity.c
Face viscosity.
file
cs_face_viscosity.h
[code]
file
cs_gradient.c
file
cs_gradient.h
[code]
file
cs_gradient_priv.h
[code]
file
cs_grid.c
file
cs_grid.h
[code]
file
cs_matrix.c
Sparse Matrix Representation and Operations.
file
cs_matrix.h
[code]
file
cs_matrix_assembler.c
Incremental or general construction of matrix structure.
file
cs_matrix_assembler.h
[code]
file
cs_matrix_assembler_priv.h
[code]
file
cs_matrix_building.c
file
cs_matrix_building.h
[code]
file
cs_matrix_default.c
file
cs_matrix_default.h
[code]
file
cs_matrix_hypre.c
Sparse Matrix Representation and Operations using HYPRE.
file
cs_matrix_hypre.h
[code]
file
cs_matrix_hypre_priv.h
[code]
file
cs_matrix_petsc.c
Sparse Matrix Representation and Operations using PETSc.
file
cs_matrix_petsc.h
[code]
file
cs_matrix_petsc_priv.h
[code]
file
cs_matrix_priv.h
[code]
file
cs_matrix_spmv.c
Sparse Matrix SpMV kernels.
file
cs_matrix_spmv.h
[code]
file
cs_matrix_spmv_cuda.h
[code]
Sparse Matrix SpMV operations with CUDA.
file
cs_matrix_tuning.c
file
cs_matrix_tuning.h
[code]
file
cs_matrix_util.c
file
cs_matrix_util.h
[code]
file
cs_multigrid.c
file
cs_multigrid.h
[code]
file
cs_multigrid_smoother.c
file
cs_multigrid_smoother.h
[code]
file
cs_param_sles.c
file
cs_param_sles.h
[code]
Structure and routines handling the SLES settings stored inside a
cs_param_sles_t
structure.
file
cs_sles.c
Sparse linear equation solver driver.
file
cs_sles.h
[code]
file
cs_sles_amgx.c
handling of AmgX-based linear solvers
file
cs_sles_amgx.h
[code]
file
cs_sles_default.c
file
cs_sles_default.h
[code]
file
cs_sles_hypre.c
handling of HYPRE-based linear solvers
file
cs_sles_hypre.h
[code]
file
cs_sles_it.c
file
cs_sles_it.h
[code]
file
cs_sles_it_cuda.h
[code]
file
cs_sles_it_priv.c
file
cs_sles_it_priv.h
[code]
file
cs_sles_mumps.c
Set of functions to handle the interface with the MUMPS library to solve sparse linear system with a direct approach.
file
cs_sles_mumps.h
[code]
file
cs_sles_pc.c
Sparse linear equation solver preconditioner driver and simple preconditioners.
file
cs_sles_pc.h
[code]
file
cs_sles_pc_cuda.h
[code]
file
cs_sles_pc_priv.h
[code]
file
cs_sles_petsc.c
handling of PETSc-based linear solvers
file
cs_sles_petsc.h
[code]
src
alge
Generated on Thu Jun 30 2022 18:12:52 for code_saturne by
