typedef void() | cs_sles_petsc_setup_hook_t(void *context, void *ksp) |
Function pointer for user settings of a PETSc KSP solver setup. More... | |
typedef struct _cs_sles_petsc_t | cs_sles_petsc_t |
void | cs_user_sles_petsc_hook (void *context, void *ksp) |
void | cs_sles_petsc_init (void) |
cs_sles_petsc_t * | cs_sles_petsc_define (int f_id, const char *name, const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context) |
Define and associate a PETSc linear system solver for a given field or equation name. More... | |
cs_sles_petsc_t * | cs_sles_petsc_create (const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context) |
Create PETSc linear system solver info and context. More... | |
void * | cs_sles_petsc_copy (const void *context) |
Create PETSc linear system solver info and context based on existing info and context. More... | |
void | cs_sles_petsc_destroy (void **context) |
Destroy PETSc linear system solver info and context. More... | |
void | cs_sles_petsc_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
Setup PETSc linear equation solver. More... | |
cs_sles_convergence_state_t | cs_sles_petsc_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
Call PETSc linear equation solver. More... | |
void | cs_sles_petsc_free (void *context) |
Free PETSc linear equation solver setup context. More... | |
bool | cs_sles_petsc_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
Error handler for PETSc solver. More... | |
void | cs_sles_petsc_log (const void *context, cs_log_t log_type) |
Log sparse linear equation solver info. More... | |
void | cs_sles_petsc_log_setup (void *ksp) |
void | cs_sles_petsc_set_cvg_criteria (const void *context, double rtol, int max_iter) |
Set some of the convergence criteria for the associated KSP structure. More... | |
const char * | cs_sles_petsc_get_mat_type (void *context) |
Return matrix type associated with PETSc linear system solver info and context. More... | |
void | cs_sles_petsc_library_info (cs_log_t log_type) |
Print information on PETSc library. More... | |
cs_sles_petsc_setup_hook_t |
This function is called the end of the setup stage for a KSP solver.
Note that using the advanced KSPSetPostSolve and KSPSetPreSolve functions, this also allows setting further function pointers for pre and post-solve operations (see the PETSc documentation).
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
[in,out] | context | pointer to optional (untyped) value or structure |
[in,out] | ksp | pointer to PETSc KSP context |
typedef struct _cs_sles_petsc_t cs_sles_petsc_t |
void* cs_sles_petsc_copy | ( | const void * | context | ) |
[in] | context | pointer to reference info and context (actual type: cs_sles_petsc_t *) |
cs_sles_petsc_t* cs_sles_petsc_create | ( | const char * | matrix_type, |
cs_sles_petsc_setup_hook_t * | setup_hook, | ||
void * | context | ||
[in] | matrix_type | PETSc matrix type |
[in] | setup_hook | pointer to optional setup epilogue function |
[in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
cs_sles_petsc_t* cs_sles_petsc_define | ( | int | f_id, |
const char * | name, | ||
const char * | matrix_type, | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in] | f_id | associated field id, or < 0 |
[in] | name | associated name if f_id < 0, or NULL |
void cs_sles_petsc_destroy | ( | void ** | context | ) |
[in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t **) |
bool cs_sles_petsc_error_post_and_abort | ( | cs_sles_t * | sles, |
cs_sles_convergence_state_t | state, | ||
const cs_matrix_t * | a, | ||
const cs_real_t * | rhs, | ||
cs_real_t * | vx | ||
In case of divergence or breakdown, this error handler outputs an error message It does nothing in case the maximum iteration count is reached.
[in,out] | sles | pointer to solver object |
[in] | state | convergence state |
[in] | a | matrix |
[in] | rhs | right hand side |
[in,out] | vx | system solution |
void cs_sles_petsc_free | ( | void * | context | ) |
[in,out] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t *) |
const char* cs_sles_petsc_get_mat_type | ( | void * | context | ) |
void cs_sles_petsc_init | ( | void | ) |
void cs_sles_petsc_library_info | ( | cs_log_t | log_type | ) |
[in] | log_type | log type |
void cs_sles_petsc_log | ( | const void * | context, |
cs_log_t | log_type | ||
[in] | context | pointer to iterative solver info and context (actual type: cs_sles_petsc_t *) |
void cs_sles_petsc_log_setup | ( | void * | ksp | ) |
void cs_sles_petsc_set_cvg_criteria | ( | const void * | context, |
double | rtol, | ||
int | max_iter | ||
[in] | rtol | relative tolerance value |
[in] | max_iter | max. number of iterations |
void cs_sles_petsc_setup | ( | void * | context, |
int | verbosity | ||
[in] | name | pointer to system name |
[in] | a | associated matrix |
[in] | verbosity | associated verbosity |
cs_sles_convergence_state_t cs_sles_petsc_solve | ( | void * | context, |
int | verbosity, | ||
double | precision, | ||
double | r_norm, | ||
int * | n_iter, | ||
double * | residue, | ||
cs_real_t * | vx, | ||
size_t | aux_size, | ||
void * | aux_vectors | ||
[in] | a | matrix |
[in] | precision | solver precision |
[in] | r_norm | residue normalization |
[out] | n_iter | number of "equivalent" iterations |
[out] | residue | residue |
[in] | aux_size | number of elements in aux_vectors (in bytes) |
aux_vectors | optional working area (internal allocation if NULL) |
void cs_user_sles_petsc_hook | ( | void * | context, |
void * | ksp | ||
