48 #define CS_APP_NAME "Code_Saturne" 49 #define CS_APP_VERSION PACKAGE_VERSION 53 #if defined(__linux__) || defined(__linux) || defined(linux) 54 #define _CS_ARCH_Linux 62 #define CS_MEM_ALIGN 0 64 #define CS_BASE_STRING_LEN 80 97 static inline const char *
138 #if defined(HAVE_MPI) 430 #if defined(HAVE_DLOPEN) 517 bool errors_are_fatal);
void cs_base_trace_set(bool trace)
Definition: cs_base.c:1957
void cs_base_mem_finalize(void)
Definition: cs_base.c:1654
void() cs_base_atexit_t(void)
Definition: cs_base.h:77
void * cs_base_dlopen_plugin(const char *name)
Load a plugin's dynamic library.
Definition: cs_base.c:2377
MPI_Comm cs_base_get_rank_step_comm_recursive(MPI_Comm parent_comm, int rank_step)
Definition: cs_base.c:1413
void * cs_base_dlopen(const char *filename)
Load a dynamic library.
Definition: cs_base.c:2337
const char * cs_base_get_localedir(void)
Definition: cs_base.c:2213
const char * cs_base_get_pkglibdir(void)
Definition: cs_base.c:2246
void cs_base_warn(const char *file_name, int line_num)
Definition: cs_base.c:2147
void cs_base_option_string_clean(char *s)
Definition: cs_base.c:2183
void cs_base_mem_init(void)
Definition: cs_base.c:1583
void cs_base_mpi_init(int *argc, char **argv[])
Definition: cs_base.c:1225
void cs_base_bft_printf_init(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:1976
bool cs_base_bft_printf_suppressed(void)
Definition: cs_base.c:2133
int cs_base_dlopen_get_flags(void)
Get flags for dlopen.
Definition: cs_base.c:2408
void cs_exit(int status)
Definition: cs_base.c:1498
void cs_base_logfile_head(int argc, char *argv[])
Definition: cs_base.c:1129
void * cs_base_get_dl_function_pointer(void *handle, const char *name, bool errors_are_fatal)
Get a shared library function pointer.
Definition: cs_base.c:2475
char * cs_base_get_app_name(int argc, const char *argv[])
Definition: cs_base.c:1070
void cs_base_backtrace_dump(FILE *f, int lv_start)
Dump a stack trace to a file.
Definition: cs_base.c:2506
void cs_base_check_bool(bool *b)
Definition: cs_base.c:2264
void cs_base_update_status(const char *format,...)
Update status file.
Definition: cs_base.c:1880
void cs_base_dlopen_set_flags(int flags)
Set flags for dlopen.
Definition: cs_base.c:2422
static const char * cs_base_strtf(bool boolean)
Return a string "true" or "false" according to the boolean.
Definition: cs_base.h:98
FILE * cs_base_open_properties_data_file(const char *base_name)
Definition: cs_base.c:2294
void cs_base_get_run_identity(char **run_id, char **case_name, char **study_name)
Query run-time directory info, using working directory names.
Definition: cs_base.c:2583
MPI_Comm cs_base_get_rank_step_comm(int rank_step)
Return a reduced communicator matching a multiple of the total number of ranks.
Definition: cs_base.c:1332
const char * cs_base_get_pkgdatadir(void)
Definition: cs_base.c:2228
void cs_base_bft_printf_set(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:2054
void cs_base_error_init(bool signal_defaults)
Definition: cs_base.c:1540
void cs_base_time_summary(void)
Definition: cs_base.c:1800
void cs_base_dlclose(const char *filename, void *handle)
Unload a dynamic library.
Definition: cs_base.c:2442
void cs_base_atexit_set(cs_base_atexit_t *const fct)
Definition: cs_base.c:2166
double precision, save b
const char * cs_base_bft_printf_name(void)
Definition: cs_base.c:2117
