7.2
cs_matrix_petsc_priv.h
1 #ifndef __CS_MATRIX_PETSC_PRIV_H__
2 #define __CS_MATRIX_PETSC_PRIV_H__
5  * Private types for sparse matrix representation and operations using PETSc.
31  * PETSc headers
34 #include <petscvec.h>
35 #include <petscmat.h>
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_defs.h"
43 #include "cs_matrix_petsc.h"
45 /*----------------------------------------------------------------------------*/
46
48
52  * Macro definitions
54
55 /*============================================================================
56  * Type definitions
58
59 /* Note that most types are declared in cs_matrix_priv.h.
60  only those only handled here are declared here. */
61
62 /* Adapter coefficients stucture for PETSc */
63
64 typedef struct _cs_matrix_coeffs_petsc_t {
65
66  PetscInt l_range[2]; /* Local rows range
67  (block range if block size > 1) */
68
69  Mat hm; /* PETSc matrix */
70  Vec hx; /* x (input) vector */
71  Vec hy; /* y (output) vector */
72
73  int matrix_state; /* Matrix state:
74  0: not created
75  1: created and assembled */
76
77  char *matype_r; /* requested PETSc matrix type */
78  MatType matype; /* actual PETSc matrix type */
79
80 } cs_matrix_coeffs_petsc_t;
81
82 /*=============================================================================
83  * Semi-private function prototypes
84  *============================================================================*/
85
86 /*----------------------------------------------------------------------------*/
94 /*----------------------------------------------------------------------------*/
95
96 cs_matrix_coeffs_petsc_t *
97 cs_matrix_petsc_get_coeffs(const cs_matrix_t *matrix);
98
101 /*----------------------------------------------------------------------------*/
102
104
105 #endif /* __CS_MATRIX_PETSC_PRIV_H__ */
Definition: cs_matrix.h:110
