7.2
cs_sles_default.h
1 #ifndef __CS_SLES_DEFAULT_H__
2 #define __CS_SLES_DEFAULT_H__
5  * Sparse Linear Equation Solvers
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_halo_perio.h"
36 #include "cs_matrix.h"
37 #include "cs_sles.h"
38
44  * Macro definitions
46
48  * Type definitions
50
52  * Global variables
54
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------
60  * Default initializations for sparse linear equation solver API.
61  *----------------------------------------------------------------------------*/
62
63 void
65
66 /*----------------------------------------------------------------------------
67  * Default definition of a sparse linear equation solver
68  *
69  * parameters:
70  * f_id <-- associated field id, or < 0
71  * name <-- associated name if f_id < 0, or NULL
72  * a <-- matrix
73  *----------------------------------------------------------------------------*/
74
75 void
76 cs_sles_default(int f_id,
77  const char *name,
78  const cs_matrix_t *a);
79
80 /*----------------------------------------------------------------------------
81  * Default setup setup for sparse linear equation solver API.
82  *
83  * This includes setup logging.
84  *----------------------------------------------------------------------------*/
85
86 void
88
89 /*----------------------------------------------------------------------------
90  * Return default verbosity associated to a field id, name couple.
91  *
92  * parameters:
93  * f_id <-- associated field id, or < 0
94  * name <-- associated name if f_id < 0, or NULL
95  *
96  * returns:
97  * verbosity associated with field or name
98  *----------------------------------------------------------------------------*/
99
100 int
102  const char *name);
103
104 /*----------------------------------------------------------------------------
105  * Default finalization for sparse linear equation solver API.
106  *
107  * This includes performance data logging output.
108  *----------------------------------------------------------------------------*/
109
110 void
112
113 /*----------------------------------------------------------------------------
114  * Call sparse linear equation solver setup for convection-diffusion
115  * systems
116  *
117  * parameters:
118  * f_id associated field id, or < 0
119  * name associated name if f_id < 0, or NULL
120  * diag_block_size block sizes for diagonal
121  * extra_diag_block_size block sizes for extra diagonal
122  * da diagonal values (NULL if zero)
123  * xa extradiagonal values (NULL if zero)
124  * conv_diff convection-diffusion mode
125  */
126 /*----------------------------------------------------------------------------*/
127
128 void
130  const char *name,
131  const cs_lnum_t diag_block_size,
132  const cs_lnum_t extra_diag_block_size,
133  const cs_real_t *da,
134  const cs_real_t *xa,
135  bool conv_diff);
136
137 /*----------------------------------------------------------------------------
138  * Call sparse linear equation solver using native matrix arrays.
139  *
140  * parameters:
141  * f_id <-- associated field id, or < 0
142  * name <-- associated name if f_id < 0, or NULL
143  * symmetric <-- indicates if matrix coefficients are symmetric
144  * diag_block_size <-- block sizes for diagonal
145  * extra_diag_block_size <-- block sizes for extra diagonal
146  * da <-- diagonal values (NULL if zero)
147  * xa <-- extradiagonal values (NULL if zero)
148  * r_epsilon <-- precision
149  * r_norm <-- residue normalization
150  * n_iter --> number of iterations
151  * residue --> residue
152  * rhs <-- right hand side
153  * vx <-> system solution
154  *
155  * returns:
156  * convergence state
157  *----------------------------------------------------------------------------*/
158
160 cs_sles_solve_native(int f_id,
161  const char *name,
162  bool symmetric,
163  cs_lnum_t diag_block_size,
164  cs_lnum_t extra_diag_block_size,
165  const cs_real_t *da,
166  const cs_real_t *xa,
167  double precision,
168  double r_norm,
169  int *n_iter,
170  double *residue,
171  const cs_real_t *rhs,
172  cs_real_t *vx);
173
174 /*----------------------------------------------------------------------------
175  * Free sparse linear equation solver setup using native matrix arrays.
176  *
177  * parameters:
178  * f_id <-- associated field id, or < 0
179  * name <-- associated name if f_id < 0, or NULL
180  *----------------------------------------------------------------------------*/
181
182 void
183 cs_sles_free_native(int f_id,
184  const char *name);
185
186 /*----------------------------------------------------------------------------
187  * Error handler attempting fallback to alternative solution procedure for
188  * sparse linear equation solver.
189  *
190  * In case of divergence with an iterative solver, this error handler
191  * switches to a default preconditioner, then resets the solution vector.
192  *
193  * The default error for the solver type handler is then set, in case
194  * the solution fails again.
195  *
196  * Note that this error handler may rebuild solver contexts, so should not
197  * be used in conjunction with shared contexts (such as multigrid
198  * ascent/descent contexts), but only for "outer" solvers.
199  *
200  * parameters:
201  * sles <-> pointer to solver object
202  * state <-- convergence status
203  * a <-- matrix
204  * rhs <-- right hand side
205  * vx <-> system solution
206  *
207  * returns:
208  * true if fallback solution is possible, false otherwise
209  *----------------------------------------------------------------------------*/
210
211 bool
214  const cs_matrix_t *a,
215  const cs_real_t rhs[],
216  cs_real_t vx[]);
217
218 /*----------------------------------------------------------------------------*/
219
221
222 #endif /* __CS_SLES_DEFAULT_H__ */
void cs_sles_default(int f_id, const char *name, const cs_matrix_t *a)
Default definition of a sparse linear equation solver.
Definition: cs_sles_default.c:477
bool cs_sles_default_error(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t rhs[], cs_real_t vx[])
Error handler attempting fallback to alternative solution procedure for sparse linear equation solver...
Definition: cs_sles_default.c:928
Definition: cs_defs.h:322
Definition: cs_matrix.h:110
Convergence status indicator.
Definition: cs_sles.h:56
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:68
void cs_sles_default_setup(void)
Default setup for sparse linear equation solver API.
Definition: cs_sles_default.c:496
void cs_sles_setup_native_conv_diff(int f_id, const char *name, const cs_lnum_t diag_block_size, const cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, bool conv_diff)
Call sparse linear equation solver setup for convection-diffusion systems.
Definition: cs_sles_default.c:620
double precision, save a
void cs_sles_default_finalize(void)
Definition: cs_sles_default.c:554
Definition: cs_defs.h:316
int cs_sles_default_get_verbosity(int f_id, const char *name)
Definition: cs_sles_default.c:574
void cs_sles_free_native(int f_id, const char *name)
Definition: cs_sles_default.c:869
cs_sles_convergence_state_t cs_sles_solve_native(int f_id, const char *name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx)
Definition: cs_sles_default.c:720
void cs_sles_default_log_setup(void)
