7.2
cs_sles_pc.c File Reference
Sparse linear equation solver preconditioner driver and simple preconditioners. More...
#include <stdarg.h>
#include "cs_blas.h"
#include "cs_halo.h"
#include "cs_matrix.h"
#include "cs_matrix_util.h"
#include "cs_sles_pc.h"
#include "cs_sles_pc_priv.h"
+ Include dependency graph for cs_sles_pc.c:
cs_sles_pc_tcs_sles_pc_define (void *context, cs_sles_pc_get_type_t *get_type_func, cs_sles_pc_setup_t *setup_func, cs_sles_pc_tolerance_t *tolerance_func, cs_sles_pc_apply_t *apply_func, cs_sles_pc_free_t *free_func, cs_sles_pc_log_t *log_func, cs_sles_pc_clone_t *clone_func, cs_sles_pc_destroy_t *destroy_func)
 Define sparse linear equation preconditioner. More...
void cs_sles_pc_destroy (cs_sles_pc_t **pc)
 Destroy a sparse linear equation preconditioner. More...
cs_sles_pc_tcs_sles_pc_clone (const cs_sles_pc_t *src)
 Create a new preconditioner context based on the copy of another. More...
const char * cs_sles_pc_get_type (cs_sles_pc_t *pc)
 Return type name of preconditioner context. More...
const char * cs_sles_pc_get_type_name (cs_sles_pc_t *pc)
void * cs_sles_pc_get_context (cs_sles_pc_t *pc)
 Return pointer to preconditioner context structure pointer. More...
cs_sles_pc_apply_tcs_sles_pc_get_apply_func (const cs_sles_pc_t *pc)
 Return a pointer to the function used to apply a preconditioner. More...
void cs_sles_pc_set_tolerance (cs_sles_pc_t *pc, double precision, double r_norm)
 Set the required tolerance for preconditioners involving an iterative solver. More...
void cs_sles_pc_setup (cs_sles_pc_t *pc, const char *name, const cs_matrix_t *a, bool accel, int verbosity)
 Setup sparse linear equation preconditioner. More...
cs_sles_pc_state_t cs_sles_pc_apply (cs_sles_pc_t *pc, cs_real_t *x_in, cs_real_t *x_out)
 Apply a preconditioner. More...
void cs_sles_pc_free (cs_sles_pc_t *pc)
 Free preconditioner setup. More...
void cs_sles_pc_log (cs_sles_pc_t *pc, cs_log_t log_type)
 Log preconditioner setup, history and performance data. More...
cs_sles_pc_tcs_sles_pc_none_create (void)
 Create an "identity" (or null) preconditioner. More...
cs_sles_pc_tcs_sles_pc_jacobi_create (void)
 Create a Jacobi preconditioner. More...
cs_sles_pc_tcs_sles_pc_poly_1_create (void)
 Create a Polynomial preconditioner of degree 1. More...
cs_sles_pc_tcs_sles_pc_poly_2_create (void)
 Create a Polynomial preconditioner of degree 2. More...
As the options associated with different preconditioners may be very varied, this subsystem is based on the use of a series of callback functions which may be associated with a given preconditioner.
To summarize, the functions here define a preconditioner driver, with the real work being done by functions bound to this model. The main intent is to help manage passing varied user options to the preconditioners, and handling consistency of logging.
◆ cs_sles_pc_apply()
cs_sles_pc_state_t cs_sles_pc_apply ( cs_sles_pc_t pc,
cs_real_t x_in,
cs_real_t x_out
If no options were previously provided for the matching system, default options will be used.
In cases where it is desired that the preconditioner modify a vector "in place", x_in should be set to NULL, and x_out contain the vector to be modified ( $x_{out} \leftarrow M^{-1}x_{out})$).
[in,out]pcpointer to preconditioner object
[in]x_ininput vector
[in,out]x_outinput/output vector
preconditioner application status
◆ cs_sles_pc_clone()
cs_sles_pc_t* cs_sles_pc_clone ( const cs_sles_pc_t src)
The intended use of this function is to allow associating different preconditioners to related systems, so as to allow simultaneous setups and differentiate logging, while using the same settings by default.
If no preconditioner (i.e. NULL) is passed, it will return NULL.
[in]srcpointer to source preconditioner object
pointer to new preconditioner object, or NULL
◆ cs_sles_pc_define()
cs_sles_pc_t* cs_sles_pc_define ( void *  context,
cs_sles_pc_get_type_t get_type_func,
cs_sles_pc_setup_t setup_func,
cs_sles_pc_tolerance_t tolerance_func,
cs_sles_pc_apply_t apply_func,
cs_sles_pc_free_t free_func,
cs_sles_pc_log_t log_func,
cs_sles_pc_clone_t clone_func,
cs_sles_pc_destroy_t destroy_func
The context pointer is used to point to a structure adapted to the function pointers given here, and combined with those functions, allows using both built-in, external, or user-defined preconditioners.
[in,out]contextpointer to preconditioner context structure (cs_sles_pc subsystem becomes owner)
[in]get_type_funcpointer to function returning type name
[in]setup_funcpointer to preconditioner setup function
[in]tolerance_funcpointer to tolerance setting functio
[in]apply_funcpointer to preconditioner application function (also calls setup_func if not done yet or free_func called since last apply)
[in]free_funcpointer function freeing system setup
[in]log_funcpointer to system info logging function (optional, but recommended)
[in]clone_funcpointer to settings clone function
[in]destroy_funcpointer to function destroying preconditioner context
pointer to associated preconditioner object
◆ cs_sles_pc_destroy()
void cs_sles_pc_destroy ( cs_sles_pc_t **  pc)
[in,out]pcpointer to preconditioner context structure
◆ cs_sles_pc_free()
void cs_sles_pc_free ( cs_sles_pc_t pc)
This function frees resolution-related data, such as multigrid hierarchy, preconditioning, and any other temporary arrays or objects required for resolution, but maintains context information such as that used for logging (especially performance data).
◆ cs_sles_pc_get_apply_func()
cs_sles_pc_apply_t* cs_sles_pc_get_apply_func ( const cs_sles_pc_t pc)
This allows calling the preconditioner with one less level of indirection.
[in]pcpointer to preconditioner object
preconditioner apply function
◆ cs_sles_pc_get_context()
void* cs_sles_pc_get_context ( cs_sles_pc_t pc)
The context structure depends on the type of preconditioner used, which may in turn be determined by the string returned by cs_sles_pc_get_type(). If may be used by appropriate functions specific to that type.
pointer to preconditioner-specific info and context
◆ cs_sles_pc_get_type()
const char* cs_sles_pc_get_type ( cs_sles_pc_t pc)
The returned string is intended to help determine which type is associated with the void * pointer returned by cs_sles_pc_get_context for a given preconditioner definition, so as to be able to call additional specific functions beyond the generic functions assigned to a cs_sles_pc_t object.
pointer to linear system preconditioner specific type name
◆ cs_sles_pc_get_type_name()
const char* cs_sles_pc_get_type_name ( cs_sles_pc_t pc)
The returned string is intended mainly for logging.
◆ cs_sles_pc_jacobi_create()
cs_sles_pc_t* cs_sles_pc_jacobi_create ( void  )
pointer to newly created preconditioner object.
◆ cs_sles_pc_log()
void cs_sles_pc_log ( cs_sles_pc_t pc,
cs_log_t  log_type
[in]log_typelog type
◆ cs_sles_pc_none_create()
cs_sles_pc_t* cs_sles_pc_none_create ( void  )
◆ cs_sles_pc_poly_1_create()
cs_sles_pc_t* cs_sles_pc_poly_1_create ( void  )
Create a polynomial preconditioner of degree 1.
◆ cs_sles_pc_poly_2_create()
cs_sles_pc_t* cs_sles_pc_poly_2_create ( void  )
Create a polynomial preconditioner of degree 2.
◆ cs_sles_pc_set_tolerance()
void cs_sles_pc_set_tolerance ( cs_sles_pc_t pc,
double  precision,
double  r_norm
This will usually not be relevant to non-iterative preconditioners, in which case this is a no-op.
The system is considered to have converged when residue/r_norm <= precision, residue being the L2 norm of a.vx-rhs.
[in]precisionpreconditioner precision
[in]r_normresidue normalization
◆ cs_sles_pc_setup()
void cs_sles_pc_setup ( cs_sles_pc_t pc,
const char *  name,
const cs_matrix_t a,
bool  accel,
int  verbosity
Use of this function is optional: if a cs_sles_solve is called for the same system before this function is called, the latter will be called automatically.
[in]namelinear system name
[in]amatrix
[in]acceluse accelerator version ?
[in]verbosityverbosity level
