7.2
cs_field.h
1 #ifndef __CS_FIELD_H__
2 #define __CS_FIELD_H__
5  * Field management.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
50 /*
51  * Field property type
52  */
53
55 #define CS_FIELD_INTENSIVE (1 << 0)
56
58 #define CS_FIELD_EXTENSIVE (1 << 1)
59
60 /* Field category */
61
63 #define CS_FIELD_VARIABLE (1 << 2)
64
66 #define CS_FIELD_PROPERTY (1 << 3)
67
69 #define CS_FIELD_POSTPROCESS (1 << 4)
70
72 #define CS_FIELD_ACCUMULATOR (1 << 5)
73
75 #define CS_FIELD_USER (1 << 6)
76
78 #define CS_FIELD_CDO (1 << 7)
79
82 /*============================================================================
83  * Type definitions
84  *============================================================================*/
85
86 /* Field handling error types */
87 /*----------------------------*/
88
89 typedef enum {
90
98
100
101 /* Field boundary condition descriptor (for variables) */
102 /*-----------------------------------------------------*/
103
104 typedef struct {
105
106  int location_id; /* Id of matching location */
107
108  cs_real_t *a; /* Explicit coefficient */
109  cs_real_t *b; /* Implicit coefficient */
110  cs_real_t *af; /* Explicit coefficient for flux */
111  cs_real_t *bf; /* Implicit coefficient for flux */
112  cs_real_t *ad; /* Explicit coefficient for divergence */
113  cs_real_t *bd; /* Implicit coefficient for divergence */
114  cs_real_t *ac; /* Explicit coefficient for convection */
115  cs_real_t *bc; /* Implicit coefficient for convection */
116
117  cs_real_t *hint; /* coefficient for internal coupling */
118  cs_real_t *hext; /* coefficient for internal coupling */
119
121
122 /* Field descriptor */
123 /*------------------*/
124
125 typedef struct {
126
127  const char *name; /* Canonical name */
128
129  int id; /* Field id */
130  int type; /* Field type flag */
131
132  int dim; /* Field dimension */
133
134  int location_id; /* Id of matching location */
135
136  int n_time_vals; /* Number of time values */
137
138  cs_real_t **vals; /* For each active location, pointer
139  to matching values arrays
140  vals[0][:] = val
141  vals[1][:] = val_pre
142  vals[p][:] = p ith previous field
143  p < n_time_vals */
144
145
146  cs_real_t *val; /* For each active location, pointer
147  to matching values array */
148
149  cs_real_t *val_pre; /* For each active location, pointer
150  to matching previous values array
151  (if n_time_vals == 2) */
152
153  cs_field_bc_coeffs_t *bc_coeffs; /* Boundary condition coefficients,
154  for variable type fields */
155
156  bool is_owner; /* Ownership flag for values */
157
158 } cs_field_t;
159
160 /*----------------------------------------------------------------------------
161  * Function pointer for structure associated to field key
162  *
163  * parameters:
164  * t <-- pointer to structure
165  *----------------------------------------------------------------------------*/
166
167 typedef void
168 (cs_field_log_key_struct_t) (const void *t);
169
170 /*----------------------------------------------------------------------------
171  * Function pointer for structure associated to field key
172  *
173  * parameters:
174  * t <-- pointer to structure
175  *----------------------------------------------------------------------------*/
176
177 typedef void
179
180 /*============================================================================
181  * Global variables
182  *============================================================================*/
183
184 /* Names for components */
185
186 extern const char *cs_glob_field_comp_name_3[];
187 extern const char *cs_glob_field_comp_name_6[];
188 extern const char *cs_glob_field_comp_name_9[];
189
190 /*=============================================================================
191  * Public function prototypes
192  *============================================================================*/
193
194 /*----------------------------------------------------------------------------
195  * Return the number of defined fields.
196  *
197  * returns:
198  * number of defined fields.
199  *----------------------------------------------------------------------------*/
200
201 int
202 cs_field_n_fields(void);
203
204 /*----------------------------------------------------------------------------
205  * Create a field descriptor.
206  *
207  * parameters:
208  * name <-- field name
209  * type_flag <-- mask of field property and category values
210  * location_id <-- id of associated location
211  * dim <-- field dimension (number of components)
212  * has_previous <-- maintain values at the previous time step ?
213  *
214  * returns:
215  * pointer to new field.
216  *----------------------------------------------------------------------------*/
217
218 cs_field_t *
219 cs_field_create(const char *name,
220  int type_flag,
221  int location_id,
222  int dim,
223  bool has_previous);
224
225 /*----------------------------------------------------------------------------*/
244 /*----------------------------------------------------------------------------*/
245
246 cs_field_t *
247 cs_field_find_or_create(const char *name,
248  int type_flag,
249  int location_id,
250  int dim,
251  bool has_previous);
252
253 /*----------------------------------------------------------------------------
254  * Change the number of time values managed by a field.
255  *
256  * The minimum will never be below 1, as the current time is always handled.
257  *
258  * parameters:
259  * f <-> pointer to field structure
260  * n_time_vals <-- number of time values to maintain
261  *----------------------------------------------------------------------------*/
262
263 void
265  int n_time_vals);
266
267 /*----------------------------------------------------------------------------
268  * Allocate arrays for field values.
269  *
270  * parameters:
271  * f <-- pointer to field structure
272  *----------------------------------------------------------------------------*/
273
274 void
276
277 /*----------------------------------------------------------------------------
278  * Map existing value arrays to field descriptor.
279  *
280  * parameters:
281  * f <-> pointer to field structure
282  * val <-- pointer to array of values
283  * val_pre <-- pointer to array of previous values, or NULL
284  *----------------------------------------------------------------------------*/
285
286 void
288  cs_real_t *val,
289  cs_real_t *val_pre);
290
291 /*----------------------------------------------------------------------------
292  * Allocate boundary condition coefficient arrays.
293  *
294  * For fields on location CS_MESH_LOCATION_CELLS, boundary conditions
295  * are located on CS_MESH_LOCATION_BOUNDARY_FACES.
296  *
297  * Boundary condition coefficients are not currently supported for other
298  * locations (though support could be added by mapping a boundary->location
299  * indirection array in the cs_mesh_location_t structure).
300  *
301  * For multidimensional fields with coupled components, implicit b and bf
302  * coefficient arrays are arrays of block matrices, not vectors, so the
303  * number of entries for each boundary face is dim*dim instead of dim.
304  *
305  * parameters:
306  * f <-- pointer to field structure
307  * have_flux_bc <-- if true, flux BC coefficients (af and bf) are added
308  * have_mom_bc <-- if true, div BC coefficients (ad and bd) are added
309  * have_conv_bc <-- if true, convection BC coefficients (ac and bc) are added
310  * have_exch_bc <-- if true, exchange boundary coefficients (hint and hext)
311  * are added
312  *----------------------------------------------------------------------------*/
313
314 void
316  bool have_flux_bc,
317  bool have_mom_bc,
318  bool have_conv_bc,
319  bool have_exch_bc);
320
321 /*----------------------------------------------------------------------------*/
322 /* Initialize boundary condition coefficients arrays.
323  *
324  * For fields on location CS_MESH_LOCATION_CELLS, boundary conditions
325  * are located on CS_MESH_LOCATION_BOUNDARY_FACES.
326  *
327  * Boundary condition coefficients are not currently supported for other
328  * locations (though support could be added by mapping a boundary->location
329  * indirection array in the cs_mesh_location_t structure).
330  *
331  * For multidimensional fields with coupled components, implicit b and bf
332  * coefficient arrays are arrays of block matrices, not vectors, so the
333  * number of entries for each boundary face is dim*dim instead of dim.
334  *
335  * parameters:
336  * f <-> pointer to field structure
337  *----------------------------------------------------------------------------*/
338
339 void
341
342 /*----------------------------------------------------------------------------
343  * Set current field values to the given constant.
344  *
345  * parameters:
346  * f <-> pointer to field structure
347  * c <-- assigned value
348  *----------------------------------------------------------------------------*/
349
350 void
352  cs_real_t c);
353
354 /*----------------------------------------------------------------------------
355  * Copy current field values to previous values if applicable.
356  *
357  * For fields with only one time value, or values not allocated yet,
358  * this is a no-op.
359  *
360  * parameters:
361  * f <-> pointer to field structure
362  *----------------------------------------------------------------------------*/
363
364 void
366
367 /*----------------------------------------------------------------------------
368  * Destroy all defined fields.
369  *----------------------------------------------------------------------------*/
370
371 void
373
374 /*----------------------------------------------------------------------------
375  * Allocate arrays for all defined fields based on their location.
376  *
377  * Location sized must thus be known.
378  *
379  * Fields that do not own their data should all have been mapped at this
380  * stage, and are checked.
381  *----------------------------------------------------------------------------*/
382
383 void
385
386 /*----------------------------------------------------------------------------
387  * Return a pointer to a field based on its id.
388  *
389  * This function requires that a field of the given id is defined.
390  *
391  * parameters:
392  * id <-- field id
393  *
394  * returns:
395  * pointer to the field structure
396  *----------------------------------------------------------------------------*/
397
398 cs_field_t *
399 cs_field_by_id(int id);
400
401 /*----------------------------------------------------------------------------
402  * Return a pointer to a field based on its name.
403  *
404  * This function requires that a field of the given name is defined.
405  *
406  * parameters:
407  * name <-- field name
408  *
409  * returns:
410  * pointer to the field structure
411  *----------------------------------------------------------------------------*/
412
413 cs_field_t *
414 cs_field_by_name(const char *name);
415
416 /*----------------------------------------------------------------------------
417  * Return a pointer to a field based on its name if present.
418  *
419  * If no field of the given name is defined, NULL is returned.
420  *
421  * parameters:
422  * name <-- field name
423  *
424  * returns:
425  * pointer to the field structure, or NULL
426  *----------------------------------------------------------------------------*/
427
428 cs_field_t *
429 cs_field_by_name_try(const char *name);
430
431 /*----------------------------------------------------------------------------
432  * Return the id of a defined field based on its name.
433  *
434  * If no field with the given name exists, -1 is returned.
435  *
436  * parameters:
437  * name <-- field name
438  *
439  * returns:
440  * id the field, or -1 if not found
441  *----------------------------------------------------------------------------*/
442
443 int
444 cs_field_id_by_name(const char *name);
445
446 /*----------------------------------------------------------------------------
447  * Return the id of a defined field and an associated component
448  * based on a component name.
449  *
450  * If no field with the given name exists, -1 is returned.
451  *
452  * parameters:
453  * name <-- field or field+component name
454  * f_id --> field id, or -1 if no match was found
455  * c_id --> component id, or -1 for all components
456  *----------------------------------------------------------------------------*/
457
458 void
459 cs_field_component_id_by_name(const char *name,
460  int *f_id,
461  int *c_id);
462
463 /*----------------------------------------------------------------------------
464  * Return an id associated with a given key name.
465  *
466  * The key must have been defined previously.
467  *
468  * parameters:
469  * name <-- key name
470  *
471  * returns:
472  * id associated with key
473  *----------------------------------------------------------------------------*/
474
475 int
476 cs_field_key_id(const char *name);
477
478 /*----------------------------------------------------------------------------
479  * Return an id associated with a given key name if present.
480  *
481  * If the key has not been defined previously, -1 is returned.
482  *
483  * parameters:
484  * name <-- key name
485  *
486  * returns:
487  * id associated with key, or -1
488  *----------------------------------------------------------------------------*/
489
490 int
491 cs_field_key_id_try(const char *name);
492
493 /*----------------------------------------------------------------------------
494  * Define a key for an integer value by its name and return an associated id.
495  *
496  * If the key has already been defined, its previous default value is replaced
497  * by the current value, and its id is returned.
498  *
499  * parameters:
500  * name <-- key name
501  * default_value <-- default value associated with key
502  * type flag <-- mask associated with field types with which the
503  * key may be associated, or 0
504  *
505  * returns:
506  * id associated with key
507  *----------------------------------------------------------------------------*/
508
509 int
510 cs_field_define_key_int(const char *name,
511  int default_value,
512  int type_flag);
513
514 /*----------------------------------------------------------------------------
515  * Define a key for an floating point value by its name and return an
516  * associated id.
517  *
518  * If the key has already been defined, its previous default value is replaced
519  * by the current value, and its id is returned.
520  *
521  * parameters:
522  * name <-- key name
523  * default_value <-- default value associated with key
524  * type flag <-- mask associated with field types with which the
525  * key may be associated, or 0
526  *
527  * returns:
528  * id associated with key
529  *----------------------------------------------------------------------------*/
530
531 int
532 cs_field_define_key_double(const char *name,
533  double default_value,
534  int type_flag);
535
536 /*----------------------------------------------------------------------------
537  * Define a key for an string point value by its name and return an
538  * associated id.
539  *
540  * If the key has already been defined, its previous default value is replaced
541  * by the current value, and its id is returned.
542  *
543  * parameters:
544  * name <-- key name
545  * default_value <-- default value associated with key
546  * type flag <-- mask associated with field types with which the
547  * key may be associated, or 0
548  *
549  * returns:
550  * id associated with key
551  *----------------------------------------------------------------------------*/
552
553 int
554 cs_field_define_key_str(const char *name,
555  const char *default_value,
556  int type_flag);
557
558 /*----------------------------------------------------------------------------
559  * Define a key for a structure value by its name and return an
560  * associated id.
561  *
562  * If the key has already been defined, its previous default value is replaced
563  * by the current value, and its id is returned.
564  *
565  * parameters:
566  * name <-- key name
567  * default_value <-- pointer to default value associated with key
568  * log_funct <-- pointer to logging function
569  * log_func_default <-- pointer to default logging function
570  * clear_func <-- pointer to substructures free function
571  * size <-- sizeof structure
572  * type_flag <-- mask associated with field types with which
573  * the key may be associated, or 0
574  *
575  * returns:
576  * id associated with key
577  *----------------------------------------------------------------------------*/
578
579 int
580 cs_field_define_key_struct(const char *name,
581  const void *default_value,
582  cs_field_log_key_struct_t *log_func,
583  cs_field_log_key_struct_t *log_func_default,
584  cs_field_clear_key_struct_t *clear_func,
585  size_t size,
586  int type_flag);
587
588 /*----------------------------------------------------------------------------
589  * Define a sub key.
590  *
591  * The sub key is the same type as the parent key.
592  *
593  * For a given field, when querying a sub key's value and that value has not
594  * been set, the query will return the value of the parent key.
595  *
596  * parameters:
597  * name <-- key name
598  * parent_id <-- parent key id
599  *
600  * returns:
601  * id associated with key
602  *----------------------------------------------------------------------------*/
603
604 int
605 cs_field_define_sub_key(const char *name,
606  int parent_id);
607
608 /*----------------------------------------------------------------------------
609  * Destroy all defined field keys and associated values.
610  *----------------------------------------------------------------------------*/
611
612 void
614
615 /*----------------------------------------------------------------------------
616  * Get the type flag associated with a given key id.
617  *
618  * If the key has not been defined previously, -1 is returned.
619  *
620  * parameters:
621  * key_id <-- id of associated key
622  *
623  * returns:
624  * type flag associated with key, or -1
625  *----------------------------------------------------------------------------*/
626
627 int
628 cs_field_key_flag(int key_id);
629
630 /*----------------------------------------------------------------------------
631  * Disable logging setup values associated with a given key.
632  *
633  * This is useful when a key is used not for setup purposes, but to track
634  * values associated with a field, such as convergence or performance data.
635  *
636  * parameters:
637  * key_id <-- id of associated key
638  *----------------------------------------------------------------------------*/
639
640 void
642
643 /*----------------------------------------------------------------------------
644  * Query if a given key has been set for a field.
645  *
646  * If the key id is not valid, or the field category is not
647  * compatible, a fatal error is provoked.
648  *
649  * parameters:
650  * f <-- pointer to field structure
651  * key_id <-- id of associated key
652  *
653  * returns:
654  * true if the key has been set for this field, false otherwise
655  *----------------------------------------------------------------------------*/
656
657 bool
659  int key_id);
660
661 /*----------------------------------------------------------------------------
662  * Query if a given key has been locked for a field.
663  *
664  * If the key id is not valid, or the field category is not
665  * compatible, a fatal error is provoked.
666  *
667  * parameters:
668  * f <-- pointer to field structure
669  * key_id <-- id of associated key
670  *
671  * returns:
672  * true if the key has been locked for this field, false otherwise
673  *----------------------------------------------------------------------------*/
674
675 bool
677  int key_id);
678
679 /*----------------------------------------------------------------------------
680  * Lock a field relative to a given key.
681  *
682  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
683  * If the field category is not compatible with the key (as defined
684  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
685  *
686  * parameters:
687  * f <-- pointer to field structure
688  * key_id <-- id of associated key
689  * value <-- value associated with key
690  *
691  * returns:
692  * 0 in case of success, > 1 in case of error
693  *----------------------------------------------------------------------------*/
694
695 int
697  int key_id);
698
699 /*----------------------------------------------------------------------------
700  * Assign a integer value for a given key to a field.
701  *
702  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
703  * If the field category is not compatible with the key (as defined
704  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
705  * If the data type does not match, CS_FIELD_INVALID_TYPE is returned.
706  * If the key value has been locked, CS_FIELD_LOCKED is returned.
707  *
708  * parameters:
709  * f <-- pointer to field structure
710  * key_id <-- id of associated key
711  * value <-- value associated with key
712  *
713  * returns:
714  * 0 in case of success, > 1 in case of error
715  *----------------------------------------------------------------------------*/
716
717 int
719  int key_id,
720  int value);
721
722 /*----------------------------------------------------------------------------
723  * Return a integer value for a given key associated with a field.
724  *
725  * If the key id is not valid, or the value type or field category is not
726  * compatible, a fatal error is provoked.
727  *
728  * parameters:
729  * f <-- pointer to field structure
730  * key_id <-- id of associated key
731  *
732  * returns:
733  * integer value associated with the key id for this field
734  *----------------------------------------------------------------------------*/
735
736 int
738  int key_id);
739
740 /*----------------------------------------------------------------------------
741  * Set integer bits matching a mask to 1 for a given key for a field.
742  *
743  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
744  * If the field category is not compatible with the key (as defined
745  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
746  * If the data type does not match, CS_FIELD_INVALID_TYPE is returned.
747  * If the key value has been locked, CS_FIELD_LOCKED is returned.
748  *
749  * parameters:
750  * f <-- pointer to field structure
751  * key_id <-- id of associated key
752  * mask <-- mask associated with key
753  *
754  * returns:
755  * 0 in case of success, > 1 in case of error
756  *----------------------------------------------------------------------------*/
757
758 int
760  int key_id,
761  int mask);
762
763 /*----------------------------------------------------------------------------
764  * Set integer bits matching a mask to 0 for a given key for a field.
765  *
766  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
767  * If the field category is not compatible with the key (as defined
768  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
769  * If the data type does not match, CS_FIELD_INVALID_TYPE is returned.
770  * If the key value has been locked, CS_FIELD_LOCKED is returned.
771  *
772  * parameters:
773  * f <-- pointer to field structure
774  * key_id <-- id of associated key
775  * mask <-- mask associated with key
776  *
777  * returns:
778  * 0 in case of success, > 1 in case of error
779  *----------------------------------------------------------------------------*/
780
781 int
783  int key_id,
784  int mask);
785
786 /*----------------------------------------------------------------------------
787  * Assign a floating point value for a given key to a field.
788  *
789  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
790  * If the field category is not compatible with the key (as defined
791  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
792  * If the data type does not match, CS_FIELD_INVALID_TYPE is returned.
793  * If the key value has been locked, CS_FIELD_LOCKED is returned.
794  *
795  * parameters:
796  * f <-- pointer to field structure
797  * key_id <-- id of associated key
798  * value <-- value associated with key
799  *
800  * returns:
801  * 0 in case of success, > 1 in case of error
802  *----------------------------------------------------------------------------*/
803
804 int
806  int key_id,
807  double value);
808
809 /*----------------------------------------------------------------------------
810  * Return a floating point value for a given key associated with a field.
811  *
812  * If the key id is not valid, or the value type or field category is not
813  * compatible, a fatal error is provoked.
814  *
815  * parameters:
816  * f <-- pointer to field structure
817  * key_id <-- id of associated key
818  *
819  * returns:
820  * floating point value associated with the key id for this field
821  *----------------------------------------------------------------------------*/
822
823 double
825  int key_id);
826
827 /*----------------------------------------------------------------------------
828  * Assign a character string value for a given key to a field.
829  *
830  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
831  * If the field category is not compatible with the key (as defined
832  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
833  * If the data type does not match, CS_FIELD_INVALID_TYPE is returned.
834  * If the key value has been locked, CS_FIELD_LOCKED is returned.
835  *
836  * parameters:
837  * f <-- pointer to field structure
838  * key_id <-- id of associated key
839  * str <-- string associated with key
840  *
841  * returns:
842  * 0 in case of success, > 1 in case of error
843  *----------------------------------------------------------------------------*/
844
845 int
847  int key_id,
848  const char *str);
849
850 /*----------------------------------------------------------------------------
851  * Return a string for a given key associated with a field.
852  *
853  * If the key id is not valid, or the value type or field category is not
854  * compatible, a fatal error is provoked.
855  *
856  * parameters:
857  * f <-- pointer to field structure
858  * key_id <-- id of associated key
859  *
860  * returns:
861  * pointer to character string associated with the key id for this field
862  *----------------------------------------------------------------------------*/
863
864 const char *
866  int key_id);
867
868
869 /*----------------------------------------------------------------------------
870  * Assign a simple structure for a given key to a field.
871  *
872  * If the key id is not valid, CS_FIELD_INVALID_KEY_ID is returned.
873  * If the field category is not compatible with the key (as defined
874  * by its type flag), CS_FIELD_INVALID_CATEGORY is returned.
875  * If the key value has been locked, CS_FIELD_LOCKED is returned.
876  *
877  * parameters:
878  * f <-- pointer to field structure
879  * key_id <-- id of associated key
880  * s <-- structure associated with key
881  *
882  * returns:
883  * 0 in case of success, > 1 in case of error
884  *----------------------------------------------------------------------------*/
885
886 int
888  int key_id,
889  void *s);
890
891 /*----------------------------------------------------------------------------
892  * Return a structure for a given key associated with a field.
893  *
894  * If the key id is not valid, or the value type or field category is not
895  * compatible, a fatal error is provoked.
896  *
897  * parameters:
898  * f <-- pointer to field structure
899  * key_id <-- id of associated key
900  * s <-- structure associated with key
901  *
902  * returns:
903  * pointer to structure associated with the key id for this field
904  * (same as s)
905  *----------------------------------------------------------------------------*/
906
907 const void *
909  int key_id,
910  void *s);
911
912 /*----------------------------------------------------------------------------*/
928 /*----------------------------------------------------------------------------*/
929
930 void *
932  int key_id);
933
934 /*----------------------------------------------------------------------------*/
947 /*----------------------------------------------------------------------------*/
948
949 const void *
951  int key_id);
952
953 /*----------------------------------------------------------------------------
954  * Print info relative to all field definitions to log file.
955  *----------------------------------------------------------------------------*/
956
957 void
958 cs_field_log_defs(void);
959
960 /*----------------------------------------------------------------------------
961  * Print info relative to a given field to log file.
962  *
963  * parameters:
964  * f <-- pointer to field structure
965  * log_keywords <-- log level for keywords (0: do not log,
966  * 1: log non-default values, 2: log all)
967  *----------------------------------------------------------------------------*/
968
969 void
971  int log_keywords);
972
973 /*----------------------------------------------------------------------------
974  * Print info relative to all defined fields to log file.
975  *
976  * parameters:
977  * log_keywords <-- log level for keywords (0: do not log,
978  * 1: log non-default values, 2: log all)
979  *----------------------------------------------------------------------------*/
980
981 void
982 cs_field_log_fields(int log_keywords);
983
984 /*----------------------------------------------------------------------------
985  * Print info relative to all key definitions to log file.
986  *----------------------------------------------------------------------------*/
987
988 void
990
991 /*----------------------------------------------------------------------------
992  * Print info relative to a given field key to log file.
993  *
994  * parameters:
995  * int key_id <-- id of associated key
996  * log_defaults <-- if true, log default field values in addition to
997  * defined field values
998  *----------------------------------------------------------------------------*/
999
1000 void
1001 cs_field_log_key_vals(int key_id,
1002  bool log_defaults);
1003
1004 /*----------------------------------------------------------------------------
1005  * Print info relative to all given field keys to log file.
1006  *
1007  * parameters:
1008  * log_defaults <-- if true, log default field values in addition to
1009  * defined field values
1010  *----------------------------------------------------------------------------*/
1011
1012 void
1013 cs_field_log_all_key_vals(bool log_defaults);
1014
1015 /*----------------------------------------------------------------------------
1016  * Define base keys.
1017  *
1018  * Keys defined by this function are:
1019  * "label" (string)
1020  * "log" (integer)
1021  * "post_vis" (integer)
1022  * "coupled" (integer, restricted to CS_FIELD_VARIABLE)
1023  * "moment_id" (integer, restricted to
1024  * CS_FIELD_ACCUMULATOR | CS_FIELD_POSTPROCESS);
1025  *
1026  * A recommened practice for different submodules would be to use
1027  * "cs_<module>_key_init() functions to define keys specific to those modules.
1028  *----------------------------------------------------------------------------*/
1029
1030 void
1032
1033 /*----------------------------------------------------------------------------
1034  * Return a label associated with a field.
1035  *
1036  * If the "label" key has been set for this field, its associated string
1037  * is returned. Otherwise, the field's name is returned.
1038  *
1039  * parameters:
1040  * f <-- pointer to field structure
1041  *
1042  * returns:
1043  * pointer to character string associated with label for this field
1044  *----------------------------------------------------------------------------*/
1045
1046 const char *
1047 cs_field_get_label(const cs_field_t *f);
1048
1049 /*----------------------------------------------------------------------------*/
1050
1052
1053 #endif /* __CS_FIELD_H__ */
Definition: cs_field.c:2991
const char * cs_field_get_key_str(const cs_field_t *f, int key_id)
Definition: cs_field.c:3293
int cs_field_set_key_int(cs_field_t *f, int key_id, int value)
Definition: cs_field.c:2943
Definition: cs_field.h:153
Definition: cs_field.c:2497
void cs_field_init_bc_coeffs(cs_field_t *f)
Definition: cs_field.c:1945
cs_real_t * b
Definition: cs_field.h:109
int location_id
Definition: cs_field.h:134
Definition: cs_field.h:125
const char * cs_glob_field_comp_name_6[]
void cs_field_log_defs(void)
Definition: cs_field.c:3624
int cs_field_define_key_str(const char *name, const char *default_value, int type_flag)
Define a key for a string value by its name and return an associated id.
Definition: cs_field.c:2626
int cs_field_key_flag(int key_id)
Definition: cs_field.c:2789
int dim
Definition: cs_field.h:132
const char * cs_glob_field_comp_name_3[]
void cs_field_map_values(cs_field_t *f, cs_real_t *val, cs_real_t *val_pre)
Definition: cs_field.c:1744
const void * cs_field_get_key_struct(const cs_field_t *f, int key_id, void *s)
Definition: cs_field.c:3414
bool cs_field_is_key_set(const cs_field_t *f, int key_id)
Definition: cs_field.c:2835
cs_real_t * val_pre
Definition: cs_field.h:149
void cs_field_allocate_values(cs_field_t *f)
Definition: cs_field.c:1713
Definition: cs_field.h:91
void cs_field_log_all_key_vals(bool log_defaults)
Definition: cs_field.c:4234
int cs_field_lock_key(cs_field_t *f, int key_id)
Definition: cs_field.c:2898
int cs_field_define_sub_key(const char *name, int parent_id)
Define a sub key.
Definition: cs_field.c:2731
void cs_field_allocate_or_map_all(void)
Definition: cs_field.c:2283
int cs_field_key_id_try(const char *name)
Definition: cs_field.c:2524
cs_real_t * val
Definition: cs_field.h:146
const char * cs_glob_field_comp_name_9[]
void cs_field_define_keys_base(void)
Define base keys.
Definition: cs_field.c:4265
cs_real_t * hext
Definition: cs_field.h:118
Definition: cs_defs.h:322
int cs_field_set_key_double(cs_field_t *f, int key_id, double value)
Definition: cs_field.c:3123
Definition: cs_field.h:104
void cs_field_component_id_by_name(const char *name, int *f_id, int *c_id)
Return the id of a defined field and an associated component based on a component name...
Definition: cs_field.c:2408
void cs_field_destroy_all(void)
Definition: cs_field.c:2226
const char * name
Definition: cs_field.h:127
Definition: cs_field.h:95
void cs_field_key_disable_setup_log(int key_id)
Definition: cs_field.c:2813
void cs_field_log_key_vals(int key_id, bool log_defaults)
Definition: cs_field.c:4110
cs_real_t * bd
Definition: cs_field.h:113
cs_real_t ** vals
Definition: cs_field.h:138
Definition: cs_field.h:92
Definition: cs_field.h:97
cs_real_t * bf
Definition: cs_field.h:111
int type
Definition: cs_field.h:130
int cs_field_set_key_str(cs_field_t *f, int key_id, const char *str)
Assign a character string for a given key to a field.
Definition: cs_field.c:3241
bool cs_field_is_key_locked(const cs_field_t *f, int key_id)
Definition: cs_field.c:2866
Definition: cs_field.h:93
void cs_field_allocate_bc_coeffs(cs_field_t *f, bool have_flux_bc, bool have_mom_bc, bool have_conv_bc, bool have_exch_bc)
Allocate boundary condition coefficients arrays.
Definition: cs_field.c:1797
cs_field_t * cs_field_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Definition: cs_field.c:1548
int cs_field_set_key_int_bits(cs_field_t *f, int key_id, int mask)
Definition: cs_field.c:3062
int cs_field_clear_key_int_bits(cs_field_t *f, int key_id, int mask)
Definition: cs_field.c:3093
int cs_field_id_by_name(const char *name)
Definition: cs_field.c:2387
int id
Definition: cs_field.h:129
cs_real_t * ad
Definition: cs_field.h:112
void cs_field_destroy_all_keys(void)
Definition: cs_field.c:2757
void * cs_field_get_key_struct_ptr(cs_field_t *f, int key_id)
Return a pointer to a simple structure for a given key to a field.
Definition: cs_field.c:3487
void cs_field_set_values(cs_field_t *f, cs_real_t c)
Definition: cs_field.c:2141
int cs_field_define_key_double(const char *name, double default_value, int type_flag)
Define a key for an floating point value by its name and return an associated id. ...
Definition: cs_field.c:2589
cs_real_t * bc
Definition: cs_field.h:115
Definition: cs_field.c:2338
int n_time_vals
Definition: cs_field.h:136
int cs_field_n_fields(void)
Definition: cs_field.c:1528
const char * cs_field_get_label(const cs_field_t *f)
Definition: cs_field.c:4291
cs_real_t * ac
Definition: cs_field.h:114
Definition: cs_field.h:96
int cs_field_set_key_struct(cs_field_t *f, int key_id, void *s)
Definition: cs_field.c:3362
void cs_field_set_n_time_vals(cs_field_t *f, int n_time_vals)
Definition: cs_field.c:1652
cs_field_t * cs_field_find_or_create(const char *name, int type_flag, int location_id, int dim, bool has_previous)
Return a field matching a given name and attributes, creating it if necessary.
Definition: cs_field.c:1592
void cs_field_log_key_defs(void)
Definition: cs_field.c:3957
cs_real_t * af
Definition: cs_field.h:110
int location_id
Definition: cs_field.h:106
cs_real_t * hint
Definition: cs_field.h:117
void cs_field_log_fields(int log_keywords)
Definition: cs_field.c:3896
void cs_field_log_info(const cs_field_t *f, int log_keywords)
Definition: cs_field.c:3762
void cs_field_current_to_previous(cs_field_t *f)
Definition: cs_field.c:2168
Definition: cs_field.c:2364
void() cs_field_clear_key_struct_t(void *t)
Definition: cs_field.h:178
Definition: cs_field.h:94
int cs_field_define_key_struct(const char *name, const void *default_value, cs_field_log_key_struct_t *log_func, cs_field_log_key_struct_t *log_func_default, cs_field_clear_key_struct_t *clear_func, size_t size, int type_flag)
Define a key for a structure value by its name and return an associated id.
Definition: cs_field.c:2678
bool is_owner
Definition: cs_field.h:156
Definition: cs_field.c:2314
double cs_field_get_key_double(const cs_field_t *f, int key_id)
Definition: cs_field.c:3171
int cs_field_define_key_int(const char *name, int default_value, int type_flag)
Definition: cs_field.c:2552
cs_field_error_type_t
Definition: cs_field.h:89
cs_real_t * a
Definition: cs_field.h:108
const void * cs_field_get_key_struct_const_ptr(const cs_field_t *f, int key_id)
Return a read-only pointer to a simple structure for a given key to a field.
Definition: cs_field.c:3565
void() cs_field_log_key_struct_t(const void *t)
Definition: cs_field.h:168
