Field descriptor. More...
#include <cs_field.h>
Collaboration diagram for cs_field_t:Data Fields | |
| const char * | name |
| int | id |
| int | type |
| int | dim |
| int | location_id |
| int | n_time_vals |
| cs_real_t ** | vals |
| cs_real_t * | val |
| cs_real_t * | val_pre |
| cs_field_bc_coeffs_t * | bc_coeffs |
| bool | is_owner |
Members of this field are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
| bc_coeffs |
Boundary condition coefficients, for variable type fields
| dim |
Field dimension (usually 1 for scalar, 3 for vector, or 6 for symmetric tensor)
| id |
Field id (based on order of field declaration, starting at 0)
| is_owner |
Ownership flag for values
| location_id |
Id of matching mesh location
| n_time_vals |
Number of time values
| name |
Canonical name
| type |
Field type flag (sum of field mask constants, defining if a field is a variable, a property, ...)
| val |
For each active location, pointer to matching values array
| val_pre |
For each active location, pointer to matching previous values array (only if n_time_vals > 1)
| vals |
vals[0][:] is a pointer to val vals[1][:] is a pointer to val_pre vals[p][:] is a pointer to p ith previous field values
