7.2
cs_blas.h
1 #ifndef __CS_BLAS_H__
2 #define __CS_BLAS_H__
5  * BLAS (Basic Linear Algebra Subroutine) functions
30 #include "cs_defs.h"
33  * External library headers
37  * Local headers
40 #include "cs_base.h"
45
47  * Macro definitions
49
51  * Type definitions
53
54 /* BLAS reduction algorithm families */
55
56 typedef enum {
57
60
62
63 /*============================================================================
64  * Public function prototypes
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------*/
76 /*----------------------------------------------------------------------------*/
77
78 void
80
81 /*----------------------------------------------------------------------------
82  * Constant times a vector plus a vector: y <-- ax + y
83  *
84  * parameters:
85  * n <-- size of arrays x and y
86  * a <-- multiplier for x
87  * x <-- array of floating-point values
88  * y <-- array of floating-point values
89  *----------------------------------------------------------------------------*/
90
91 void
93  double a,
94  const cs_real_t *x,
95  cs_real_t *restrict y);
96
97 /*----------------------------------------------------------------------------
98  * Return the sum of a vector. For better precision, a superblock algorithm
99  * is used.
100  *
101  * parameters:
102  * n <-- size of array x
103  * x <-- array of floating-point values
104  *
105  * returns:
106  * the resulting sum
107  *----------------------------------------------------------------------------*/
108
109 double
110 cs_sum(cs_lnum_t n,
111  const cs_real_t *x);
112
113 /*----------------------------------------------------------------------------
114  * Return the weighted sum of a vector. For better precision, a superblock
115  * algorithm is used.
116  *
117  * \param[in] n size of array x
118  * \param[in] w array of floating-point weights
119  * \param[in] x array of floating-point values
120  *
121  * \return the resulting weighted sum
122  *----------------------------------------------------------------------------*/
123
124 double
126  const cs_real_t *w,
127  const cs_real_t *x);
128
129 /*----------------------------------------------------------------------------
130  * Return the dot product of 2 vectors: x.y
131  *
132  * parameters:
133  * n <-- size of arrays x and y
134  * x <-- array of floating-point values
135  * y <-- array of floating-point values
136  *
137  * returns:
138  * dot product
139  *----------------------------------------------------------------------------*/
140
141 double
142 cs_dot(cs_lnum_t n,
143  const cs_real_t *x,
144  const cs_real_t *y);
145
146 /*----------------------------------------------------------------------------
147  * Return dot products of a vector with itself: x.x
148  *
149  * parameters:
150  * n <-- size of arrays x
151  * x <-- array of floating-point values
152  *
153  * returns:
154  * dot product
155  *----------------------------------------------------------------------------*/
156
157 double
159  const cs_real_t *x);
160
161 /*----------------------------------------------------------------------------
162  * Return weighted dot products of a vector with itself: x.x
163  *
164  * For better precision, a superblock algorithm is used.
165  *
166  * parameters:
167  * n <-- size of arrays x
168  * w <-- array of weights
169  * x <-- array of floating-point values
170  *
171  * returns:
172  * dot product
173  *----------------------------------------------------------------------------*/
174
175 double
177  const cs_real_t *w,
178  const cs_real_t *x);
179
180 /*----------------------------------------------------------------------------
181  * Return the double dot product of 2 vectors: x.x, and x.y
182  *
183  * The products could be computed separately, but computing them
184  * simultaneously adds more optimization opportunities and possibly better
185  * cache behavior.
186  *
187  * parameters:
188  * n <-- size of arrays x and y
189  * x <-- array of floating-point values
190  * y <-- array of floating-point values
191  * xx --> x.x dot product
192  * xy --> x.y dot product
193  *----------------------------------------------------------------------------*/
194
195 void
197  const cs_real_t *restrict x,
198  const cs_real_t *restrict y,
199  double *xx,
200  double *xy);
201
202 /*----------------------------------------------------------------------------
203  * Return the double dot product of 3 vectors: x.y, and y.z
204  *
205  * The products could be computed separately, but computing them
206  * simultaneously adds more optimization opportunities and possibly better
207  * cache behavior.
208  *
209  * parameters:
210  * n <-- size of arrays x and y
211  * x <-- array of floating-point values
212  * y <-- array of floating-point values
213  * z <-- array of floating-point values
214  * xy --> x.y dot product
215  * yz --> x.z dot product
216  *----------------------------------------------------------------------------*/
217
218 void
220  const cs_real_t *restrict x,
221  const cs_real_t *restrict y,
222  const cs_real_t *restrict z,
223  double *xx,
224  double *xy);
225
226 /*----------------------------------------------------------------------------
227  * Return 3 dot products of 3 vectors: x.x, x.y, and y.z
228  *
229  * The products could be computed separately, but computing them
230  * simultaneously adds more optimization opportunities and possibly better
231  * cache behavior.
232  *
233  * parameters:
234  * n <-- size of arrays x and y
235  * x <-- array of floating-point values
236  * y <-- array of floating-point values
237  * z <-- array of floating-point values
238  * xx --> x.y dot product
239  * xy --> x.y dot product
240  * yz --> y.z dot product
241  *----------------------------------------------------------------------------*/
242
243 void
245  const cs_real_t *restrict x,
246  const cs_real_t *restrict y,
247  const cs_real_t *restrict z,
248  double *xx,
249  double *xy,
250  double *yz);
251
252 /*----------------------------------------------------------------------------
253  * Return 5 dot products of 3 vectors: x.x, y.y, x.y, x.z, and y.z
254  *
255  * The products could be computed separately, but computing them
256  * simultaneously adds more optimization opportunities and possibly better
257  * cache behavior.
258  *
259  * parameters:
260  * n <-- size of arrays x and y
261  * x <-- array of floating-point values
262  * y <-- array of floating-point values
263  * z <-- array of floating-point values
264  * xx --> x.y dot product
265  * yy --> y.y dot product
266  * xy --> x.y dot product
267  * xz --> x.z dot product
268  * yz --> y.z dot product
269  *----------------------------------------------------------------------------*/
270
271 void
273  const cs_real_t *restrict x,
274  const cs_real_t *restrict y,
275  const cs_real_t *restrict z,
276  double *xx,
277  double *yy,
278  double *xy,
279  double *xz,
280  double *yz);
281
282 /*----------------------------------------------------------------------------
283  * Return the global dot product of 2 vectors: x.y
284  *
285  * In parallel mode, the local results are summed on the default
286  * global communicator.
287  *
288  * parameters:
289  * n <-- size of arrays x and y
290  * x <-- array of floating-point values
291  * y <-- array of floating-point values
292  *
293  * returns:
294  * dot product
295  *----------------------------------------------------------------------------*/
296
297 double
299  const cs_real_t *x,
300  const cs_real_t *y);
301
302 /*----------------------------------------------------------------------------
303  * Return the global residual of 2 intensive vectors:
304  * 1/sum(vol) . sum(vol.x.y)
305  *
306  * parameters:
307  * n <-- size of arrays x and y
308  * vol <-- array of floating-point values
309  * x <-- array of floating-point values
310  * y <-- array of floating-point values
311  *
312  * returns:
313  * global residual
314  *----------------------------------------------------------------------------*/
315
316 double
318  const cs_real_t *vol,
319  const cs_real_t *x,
320  const cs_real_t *y);
321
322 /*----------------------------------------------------------------------------
323  * Return the global volume weighted mean
324  * 1/sum(vol) . sum(vol.x)
325  *
326  * parameters:
327  * n <-- size of arrays x
328  * vol <-- array of floating-point values
329  * x <-- array of floating-point values
330  *
331  * returns:
332  * global residual
333  *----------------------------------------------------------------------------*/
334
335 double
337  const cs_real_t *vol,
338  const cs_real_t *x);
339
340 /*----------------------------------------------------------------------------*/
341
343
344 #endif /* __CS_BLAS_H__ */
#define restrict
Definition: cs_defs.h:142
cs_blas_reduce_t
Reduction algorithm type.
Definition: cs_blas.h:56
double cs_gmean(cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x)
Return the global spacial average of an intensive vectors: 1/sum(vol) . sum(x.vol) ...
Definition: cs_blas.c:1739
double cs_gdot(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y)
Return the global dot product of 2 vectors: x.y.
Definition: cs_blas.c:1685
void cs_axpy(cs_lnum_t n, double a, const cs_real_t *x, cs_real_t *restrict y)
Constant times a vector plus a vector: y <– ax + y.
Definition: cs_blas.c:1321
double cs_dot(cs_lnum_t n, const cs_real_t *x, const cs_real_t *y)
Return the dot product of 2 vectors: x.y.
Definition: cs_blas.c:1465
Definition: cs_defs.h:322
Definition: cs_blas.h:59
double cs_dot_wxx(cs_lnum_t n, const cs_real_t *w, const cs_real_t *x)
Definition: cs_blas.c:1505
void cs_dot_xx_xy(cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, double *xx, double *xy)
Return 2 dot products of 2 vectors: x.x, and x.y.
Definition: cs_blas.c:1566
double precision, save a
double cs_dot_xx(cs_lnum_t n, const cs_real_t *x)
Return dot products of a vector with itself: x.x.
Definition: cs_blas.c:1486
void cs_blas_set_reduce_algorithm(cs_blas_reduce_t mode)
Set the preferred BLAS reduction algorithm family.
Definition: cs_blas.c:1282
void cs_dot_xx_xy_yz(cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, const cs_real_t *restrict z, double *xx, double *xy, double *yz)
Return 3 dot products of 3 vectors: x.x, x.y, and y.z.
Definition: cs_blas.c:1622
double cs_sum(cs_lnum_t n, const cs_real_t *x)
Definition: cs_blas.c:1354
Definition: cs_defs.h:316
void cs_dot_xx_yy_xy_xz_yz(cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, const cs_real_t *restrict z, double *xx, double *yy, double *xy, double *xz, double *yz)
Return 5 dot products of 3 vectors: x.x, y.y, x.y, x.z, and y.z.
Definition: cs_blas.c:1654
double cs_weighted_sum(cs_lnum_t n, const cs_real_t *w, const cs_real_t *x)
Definition: cs_blas.c:1408
double cs_gres(cs_lnum_t n, const cs_real_t *vol, const cs_real_t *x, const cs_real_t *y)
Return the global residual of 2 intensive vectors: 1/sum(vol) . sum(x.y.vol)
Definition: cs_blas.c:1714
Definition: cs_blas.h:58
void cs_dot_xy_yz(cs_lnum_t n, const cs_real_t *restrict x, const cs_real_t *restrict y, const cs_real_t *restrict z, double *xx, double *xy)
Return 2 dot products of 3 vectors: x.y, and y.z.
Definition: cs_blas.c:1593
