#include <dmumps_c.h>
#include <smumps_c.h>
#include "cs_halo_perio.h"
#include "cs_matrix.h"
#include "cs_param_sles.h"
#include "cs_time_plot.h"
#include "cs_sles.h"
| void | cs_user_sles_mumps_hook (const cs_param_sles_t *slesp, void *context, DMUMPS_STRUC_C *dmumps, SMUMPS_STRUC_C *smumps) |
| | Function pointer for user settings of a MUMPS solver. This function is called at the end of the setup stage. More...
| cs_sles_mumps_t * | cs_sles_mumps_define (int f_id, const char *name, const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| | Define and associate a MUMPS linear system solver for a given field or equation name. More...
| cs_sles_mumps_t * | cs_sles_mumps_create (const cs_param_sles_t *slesp, cs_sles_mumps_setup_hook_t *setup_hook, void *context) |
| | Create MUMPS linear system solver info and context. More...
| void * | cs_sles_mumps_copy (const void *context) |
| | Create MUMPS linear system solver info and context based on existing info and context. More...
| void | cs_sles_mumps_free (void *context) |
| | Free MUMPS linear equation solver setup context. More...
| void | cs_sles_mumps_destroy (void **context) |
| | Destroy MUMPS linear system solver info and context. More...
| void | cs_sles_mumps_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| | Setup MUMPS linear equation solver. More...
| cs_sles_convergence_state_t | cs_sles_mumps_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| | Call MUMPS linear equation solver. More...
| void | cs_sles_mumps_log (const void *context, cs_log_t log_type) |
| | Log sparse linear equation solver info. More...
◆ CNTL
| #define CNTL |
I | ) |
cntl[(I)-1] |
◆ CS_SLES_MUMPS_JOB_INIT
| #define CS_SLES_MUMPS_JOB_INIT -1 |
◆ ICNTL
| #define ICNTL |
I | ) |
icntl[(I)-1] |
◆ INFO
| #define INFO |
I | ) |
info[(I)-1] |
◆ INFOG
| #define INFOG |
I | ) |
infog[(I)-1] |
◆ RINFO
| #define RINFO |
I | ) |
rinfo[(I)-1] |
◆ RINFOG
| #define RINFOG |
I | ) |
rinfog[(I)-1] |
◆ cs_sles_mumps_setup_hook_t
| cs_sles_mumps_setup_hook_t |
Function pointer for user settings of a MUMPS DMUMPS_STRUC_C solver setup.
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
- Parameters
| [in] | slesp | pointer to the related cs_param_sles_t structure |
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | dmumps | pointer to DMUMPS_STRUC_C (double-precision) |
| [in,out] | smumps | pointer to SMUMPS_STRUC_C (single-precision) |
This function is called the end of the setup stage.
- Parameters
| [in,out] | dmumps | pointer to DMUMPS_STRUC_C structure |
◆ cs_sles_mumps_t
◆ cs_sles_mumps_copy()
| void* cs_sles_mumps_copy |
const void * |
context | ) |
- Parameters
| [in] | context | pointer to reference info and context (actual type: cs_sles_mumps_t *) |
- Returns
- pointer to newly created solver info object. (actual type: cs_sles_mumps_t *)
◆ cs_sles_mumps_create()
- Parameters
| [in] | slesp | pointer to a cs_param_sles_t structure |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
- Returns
- pointer to associated linear system object.
◆ cs_sles_mumps_define()
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_mumps_create.
Note that this function returns a pointer directly to the sparse direct solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
- Parameters
- Returns
- pointer to newly created sparse direct solver info object.
◆ cs_sles_mumps_destroy()
| void cs_sles_mumps_destroy |
void ** |
context | ) |
- Parameters
| [in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t **) |
◆ cs_sles_mumps_free()
| void cs_sles_mumps_free |
void * |
context | ) |
- Parameters
| [in,out] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
◆ cs_sles_mumps_log()
| void cs_sles_mumps_log |
const void * |
context, |
cs_log_t |
log_type |
- Parameters
| [in] | context | pointer to sparse direct solver info and context (actual type: cs_sles_mumps_t *) |
◆ cs_sles_mumps_setup()
| void cs_sles_mumps_setup |
void * |
context, |
const char * |
name, |
const cs_matrix_t * |
a, |
int |
verbosity |
- Parameters
◆ cs_sles_mumps_solve()
| cs_sles_convergence_state_t cs_sles_mumps_solve |
void * |
context, |
const char * |
name, |
a, |
int |
verbosity, |
double |
precision, |
double |
r_norm, |
int * |
n_iter, |
double * |
residue, |
const cs_real_t * |
rhs, |
cs_real_t * |
vx, |
size_t |
aux_size, |
void * |
aux_vectors |
- Parameters
| [in] | a | matrix |
| [out] | residue | residue |
- Returns
- convergence state
◆ cs_user_sles_mumps_hook()
| void cs_user_sles_mumps_hook |
const cs_param_sles_t * |
slesp, |
void * |
context, |
DMUMPS_STRUC_C * |
dmumps, |
SMUMPS_STRUC_C * |
smumps |
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that structure should not be temporary (i.e. local);
- Parameters
