7.2
cs_param_sles.c File Reference
#include <bft_error.h>
#include <bft_mem.h>
#include <bft_printf.h>
#include "cs_fp_exception.h"
#include "cs_multigrid.h"
#include "cs_sles.h"
#include "cs_param_sles.h"
+ Include dependency graph for cs_param_sles.c:
static bool _mumps_is_needed (cs_param_itsol_type_t solver)
 Return true if a solver involving the MUMPS library is requested. More...
static bool _system_should_be_sym (cs_param_itsol_type_t solver)
 Return true if the prescribed solver implies a symmetric linear system. More...
static void _check_settings (cs_param_sles_t *slesp)
 Check if the settings are consitent. Can apply minor modifications. More...
static int _get_poly_degree (const cs_param_sles_t *slesp)
 Retrieve the value of the polynomial degree to consider according to the settings. Only for in-house solvers. More...
static void _set_saturne_sles (bool use_field_id, cs_param_sles_t *slesp)
 Set parameters for initializing SLES structures used for the resolution of the linear system. Case of saturne's own solvers. More...
static void _set_mumps_sles (bool use_field_id, cs_param_sles_t *slesp)
 Set parameters for initializing SLES structures used for the resolution of the linear system. Case of MUMPS's own solvers. More...
static void _set_petsc_hypre_sles (bool use_field_id, cs_param_sles_t *slesp)
 Set parameters for initializing SLES structures used for the resolution of the linear system. Case of PETSc and Hypre families of solvers. More...
cs_param_sles_tcs_param_sles_create (int field_id, const char *system_name)
 Create a cs_param_sles_t structure and assign a default settings. More...
void cs_param_sles_free (cs_param_sles_t **p_slesp)
 Free a cs_param_sles_t structure. More...
void cs_param_sles_log (cs_param_sles_t *slesp)
 Log information related to the linear settings stored in the structure. More...
void cs_param_sles_copy_from (cs_param_sles_t *src, cs_param_sles_t *dst)
 Copy a cs_param_sles_t structure from src to dst. More...
int cs_param_sles_set (bool use_field_id, cs_param_sles_t *slesp)
 Define cs_sles_t structure in accordance with the settings of a cs_param_sles_t structure (SLES = Sparse Linear Equation Solver) More...
void cs_param_sles_update_cvg_settings (bool use_field_id, const cs_param_sles_t *slesp)
 Update the settings associated to a cs_sles_t structure and apply those defined in the given cs_param_sles_t structure. This function is used only when a first setup has been performed. More...
cs_param_sles_class_t cs_param_sles_get_class_from_amg (cs_param_amg_type_t amg_type)
 Retrieve the related solver class from the amg type. More...
cs_param_sles_class_t cs_param_sles_check_class (cs_param_sles_class_t wanted_class)
 Check the availability of a solver library and return the requested one if this is possible or an alternative or CS_PARAM_SLES_N_CLASSES if no alternative is available. More...
void cs_param_sles_check_amg (cs_param_sles_t *slesp)
 Check if the setting related to the AMG is consistent with the solver class. More...
◆ _check_settings()
static void _check_settings ( cs_param_sles_t slesp)
static
[in,out]slesppointer to a cs_param_sles_t structure
◆ _get_poly_degree()
static int _get_poly_degree ( const cs_param_sles_t slesp)
static
[in]slesppointer to a cs_param_sles_t structure
◆ _mumps_is_needed()
static bool _mumps_is_needed ( cs_param_itsol_type_t  solver)
inlinestatic
◆ _set_mumps_sles()
static void _set_mumps_sles ( bool  use_field_id,
static
[in]use_field_idif false use system name
◆ _set_petsc_hypre_sles()
static void _set_petsc_hypre_sles ( bool  use_field_id,
static
◆ _set_saturne_sles()
static void _set_saturne_sles ( bool  use_field_id,
static
◆ _system_should_be_sym()
static bool _system_should_be_sym ( cs_param_itsol_type_t  solver)
inlinestatic
◆ cs_param_sles_check_amg()
void cs_param_sles_check_amg ( cs_param_sles_t slesp)
[in,out]slesppointer to a cs_pparam_sles_t structure
◆ cs_param_sles_check_class()
cs_param_sles_class_t cs_param_sles_check_class ( cs_param_sles_class_t  wanted_class)
[in]wanted_classrequested class of solvers
the available solver class related to the requested class
◆ cs_param_sles_copy_from()
void cs_param_sles_copy_from ( cs_param_sles_t src,
cs_param_sles_t dst
[in]srcreference cs_param_sles_t structure to copy
[in,out]dstcopy of the reference at exit
◆ cs_param_sles_create()
cs_param_sles_t* cs_param_sles_create ( int  field_id,
const char *  system_name
[in]field_idid related to to the variable field or -1
[in]system_namename of the system to solve or NULL
a pointer to a cs_param_sles_t stucture
◆ cs_param_sles_free()
void cs_param_sles_free ( cs_param_sles_t **  p_slesp)
[in,out]slesppointer to a structure to free
◆ cs_param_sles_get_class_from_amg()
cs_param_sles_class_t cs_param_sles_get_class_from_amg ( cs_param_amg_type_t  amg_type)
[in]amg_typetype of AMG to consider
the related solver class or CS_PARAM_SLES_CLASS_CS
◆ cs_param_sles_log()
void cs_param_sles_log ( cs_param_sles_t slesp)
[in]slesppointer to a cs_param_sles_log
◆ cs_param_sles_set()
int cs_param_sles_set ( bool  use_field_id,
[in]use_field_idif false use system name to define a SLES
an error code (-1 if a problem is encountered, 0 otherwise)
◆ cs_param_sles_update_cvg_settings()
void cs_param_sles_update_cvg_settings ( bool  use_field_id,
One modifies only some specific options like the max. number of iterations or the relative tolerance
[in]use_field_idif false use a name to retrieve the cs_sles_t struc.
