7.2
cs_sles_it_cuda.h
1 #ifndef __CS_SLES_IT_CUDA_H__
2 #define __CS_SLES_IT_CUDA_H__
5  * Sparse Linear Equation Solvers using CUDA
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_matrix.h"
36 #include "cs_sles.h"
37 #include "cs_sles_pc.h"
38
44  * Macro definitions
46
48  * Type definitions
50
52  * Global variables
54
56  * User function prototypes
58
59 /*=============================================================================
60  * Public function prototypes
62
63 /*----------------------------------------------------------------------------
64  * Solution of A.vx = Rhs using Jacobi.
65  *
66  * On entry, vx is considered initialized.
67  *
68  * parameters:
69  * c <-- pointer to solver context info
70  * a <-- linear equation matrix
71  * diag_block_size <-- diagonal block size
72  * rotation_mode <-- halo update option for rotational periodicity
73  * convergence <-- convergence information structure
74  * rhs <-- right hand side
75  * vx <-> system solution
76  * aux_size <-- number of elements in aux_vectors (in bytes)
77  * aux_vectors --- optional working area (allocation otherwise)
78  *
79  * returns:
80  * convergence state
81  *----------------------------------------------------------------------------*/
82
85  const cs_matrix_t *a,
86  cs_lnum_t diag_block_size,
87  cs_sles_it_convergence_t *convergence,
88  const cs_real_t *rhs,
89  cs_real_t *restrict vx,
90  size_t aux_size,
91  void *aux_vectors);
92
93 /*----------------------------------------------------------------------------
94  * Solution of A.vx = Rhs using block Jacobi.
95  *
96  * On entry, vx is considered initialized.
97  *
98  * parameters:
99  * c <-- pointer to solver context info
100  * a <-- linear equation matrix
101  * diag_block_size <-- diagonal block size
102  * rotation_mode <-- halo update option for rotational periodicity
103  * convergence <-- convergence information structure
104  * rhs <-- right hand side
105  * vx <-> system solution
106  * aux_size <-- number of elements in aux_vectors (in bytes)
107  * aux_vectors --- optional working area (allocation otherwise)
108  *
109  * returns:
110  * convergence state
111  *----------------------------------------------------------------------------*/
112
115  const cs_matrix_t *a,
116  cs_lnum_t diag_block_size,
117  cs_sles_it_convergence_t *convergence,
118  const cs_real_t *rhs,
119  cs_real_t *restrict vx,
120  size_t aux_size,
121  void *aux_vectors);
122
123 /*----------------------------------------------------------------------------
124  * Solution of A.vx = Rhs using optimised preconditioned GCR (CUDA version).
125  *
126  * On entry, vx is considered initialized.
127  *
128  * parameters:
129  * c <-- pointer to solver context info
130  * a <-- matrix
131  * diag_block_size <-- diagonal block size (unused here)
132  * convergence <-- convergence information structure
133  * rhs <-- right hand side
134  * vx <-> system solution
135  * aux_size <-- number of elements in aux_vectors (in bytes)
136  * aux_vectors --- optional working area (allocation otherwise)
137  *
138  * returns:
139  * convergence state
140  *----------------------------------------------------------------------------*/
141
144  const cs_matrix_t *a,
145  cs_lnum_t diag_block_size,
146  cs_sles_it_convergence_t *convergence,
147  const cs_real_t *rhs,
148  cs_real_t *restrict vx,
149  size_t aux_size,
150  void *aux_vectors);
151
152 /*----------------------------------------------------------------------------*/
153
155
156 #endif /* __CS_SLES_IT_CUDA_H__ */
#define restrict
Definition: cs_defs.h:142
struct _cs_sles_it_t cs_sles_it_t
Definition: cs_sles_it.h:86
Definition: cs_defs.h:322
Definition: cs_matrix.h:110
cs_sles_convergence_state_t
Convergence status indicator.
Definition: cs_sles.h:56
struct _cs_sles_it_convergence_t cs_sles_it_convergence_t
Definition: cs_sles_it.h:90
double precision, save a
Definition: cs_defs.h:316
cs_sles_convergence_state_t cs_sles_it_cuda_jacobi(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *restrict vx, size_t aux_size, void *aux_vectors)
cs_sles_convergence_state_t cs_sles_it_cuda_block_jacobi(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *restrict vx, size_t aux_size, void *aux_vectors)
cs_sles_convergence_state_t cs_sles_it_cuda_gcr(cs_sles_it_t *c, const cs_matrix_t *a, cs_lnum_t diag_block_size, cs_sles_it_convergence_t *convergence, const cs_real_t *rhs, cs_real_t *restrict vx, size_t aux_size, void *aux_vectors)
