7.2
cs_gradient.h File Reference
#include "cs_halo.h"
#include "cs_internal_coupling.h"
+ Include dependency graph for cs_gradient.h:
Enumerations
enum  cs_gradient_type_t { CS_GRADIENT_GREEN_ITER, CS_GRADIENT_LSQ, CS_GRADIENT_GREEN_LSQ, CS_GRADIENT_GREEN_VTX }
enum  cs_gradient_limit_t { CS_GRADIENT_LIMIT_NONE = -1, CS_GRADIENT_LIMIT_CELL = 0, CS_GRADIENT_LIMIT_FACE = 1 }
void grdpor (const int *const inc)
void cgdvec (const int *const f_id, const int *const imrgra, const int *const inc, const int *const n_r_sweeps, const int *const iwarnp, const int *const imligp, const cs_real_t *const epsrgp, const cs_real_t *const climgp, const cs_real_3_t coefav[], const cs_real_33_t coefbv[], cs_real_3_t pvar[], cs_real_33_t grad[])
void cs_gradient_initialize (void)
 Initialize gradient computation API. More...
void cs_gradient_finalize (void)
 Finalize gradient computation API. More...
void cs_gradient_free_quantities (void)
 Free saved gradient quantities. More...
void cs_gradient_scalar (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, bool recompute_cocg, int n_r_sweeps, int tr_dim, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_3_t f_ext[], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], cs_real_t var[restrict], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
 Compute cell gradient of scalar field or component of vector or tensor field. More...
void cs_gradient_vector (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], cs_real_t var[restrict][3], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t gradv[restrict][3][3])
 Compute cell gradient of vector field. More...
void cs_gradient_tensor (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_6_t bc_coeff_a[], const cs_real_66_t bc_coeff_b[], cs_real_6_t *restrict var, cs_real_63_t *restrict grad)
 Compute cell gradient of tensor. More...
void cs_gradient_scalar_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, bool recompute_cocg, int n_r_sweeps, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_t f_ext[][3], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[restrict], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
void cs_gradient_vector_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3][3])
void cs_gradient_tensor_synced_input (const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], cs_real_63_t *restrict grad)
void cs_gradient_scalar_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[], const cs_real_t c_weight[], cs_real_t grad[3])
 Compute the gradient of a scalar field at a given cell using least-squares reconstruction. More...
void cs_gradient_vector_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[], cs_real_t grad[3][3])
 Compute the gradient of a vector field at a given cell using least-squares reconstruction. More...
void cs_gradient_tensor_cell (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], const cs_real_t c_weight[], cs_real_t grad[6][3])
 Compute the gradient of a tensor field at a given cell using least-squares reconstruction. More...
void cs_gradient_type_by_imrgra (int imrgra, cs_gradient_type_t *gradient_type, cs_halo_type_t *halo_type)
void cs_gradient_porosity_balance (int inc)
 compute the steady balance due to porous modelling for the pressure gradient. More...
const char * cs_gradient_type_name []
◆ cs_gradient_limit_t
Enumerator
no limiter
cell values extrapolated by cell gradient to neighbor cells can not exceed the limiting factor times the actual value
cell values extrapolated by face gradient (mean of cell gradients) extrapolated to neighbor cells can not exceed the limiting factor times the actual value
◆ cs_gradient_type_t
Enumerator
Iterative
CS_GRADIENT_LSQ
Least-squares
Green-Gauss reconstruction with least squares gradient face values
Green-Gauss with vertex interpolation
◆ cgdvec()
void cgdvec ( const int *const  f_id,
cs_real_3_t  pvar[],
cs_real_33_t  grad[]
◆ cs_gradient_finalize()
void cs_gradient_finalize ( void  )
◆ cs_gradient_free_quantities()
void cs_gradient_free_quantities ( void  )
◆ cs_gradient_initialize()
void cs_gradient_initialize ( void  )
◆ cs_gradient_porosity_balance()
void cs_gradient_porosity_balance ( int  inc)
[in]incif 0, solve on increment; 1 otherwise
◆ cs_gradient_scalar()
void cs_gradient_scalar ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  tr_dim,
int  hyd_p_flag,
int  w_stride,
int  verbosity,
double  epsilon,
double  clip_coeff,
const cs_internal_coupling_t cpl,
[in]var_namevariable name
[in]gradient_typegradient type
[in]halo_typehalo type
[in]recompute_cocgshould COCG FV quantities be recomputed ?
[in]n_r_sweepsif > 1, number of reconstruction sweeps (only used by CS_GRADIENT_GREEN_ITER)
[in]tr_dimignored
[in]hyd_p_flagflag for hydrostatic pressure
[in]w_stridestride for weighting coefficient
[in]verbosityverbosity level
[in]clip_modeclipping mode
[in]epsilonprecision for iterative gradient calculation
[in]clip_coeffclipping coefficient
[in]f_extexterior force generating the hydrostatic pressure
[in]bc_coeff_aboundary condition term a
[in]bc_coeff_bboundary condition term b
[in,out]vargradient's base variable
[in,out]c_weightcell variable weight, or NULL
[in]cplassociated internal coupling, or NULL
[out]gradgradient
◆ cs_gradient_scalar_cell()
void cs_gradient_scalar_cell ( const cs_mesh_t m,
const cs_mesh_quantities_t fvq,
cs_lnum_t  c_id,
cs_real_t  grad[3]
When boundary conditions are provided, both the bc_coeff_a and bc_coeff_b arrays must be given. If boundary values are known, bc_coeff_a can point to the boundary values array, and bc_coeff_b set to NULL. If bc_coeff_a is NULL, bc_coeff_b is ignored.
[in]mpointer to associated mesh structure
[in]fvqpointer to associated finite volume quantities
[in]c_idcell id
[in]bc_coeff_aboundary condition term a, or NULL
[in]bc_coeff_bboundary condition term b, or NULL
[in]vargradient's base variable
[in]c_weightcell variable weight, or NULL
[out]gradgradient
◆ cs_gradient_scalar_synced_input()
void cs_gradient_scalar_synced_input ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  hyd_p_flag,
int  w_stride,
int  verbosity,
double  epsilon,
double  clip_coeff,
This variant of the cs_gradient_scalar function assumes ghost cell values for input arrays (var and optionally c_weight) have already been synchronized.
[out]gradgradient
◆ cs_gradient_tensor()
void cs_gradient_tensor ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
[out]gradgradient ( $ \der{t_ij}{x_k} $ is grad[][ij][k])
◆ cs_gradient_tensor_cell()
void cs_gradient_tensor_cell ( const cs_mesh_t m,
cs_lnum_t  c_id,
[in]c_idcell id
[out]gradgradient
◆ cs_gradient_tensor_synced_input()
void cs_gradient_tensor_synced_input ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
◆ cs_gradient_type_by_imrgra()
void cs_gradient_type_by_imrgra ( int  imrgra,
◆ cs_gradient_vector()
void cs_gradient_vector ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
[out]gradvgradient ( $ \der{u_i}{x_j} $ is gradv[][i][j])
◆ cs_gradient_vector_cell()
void cs_gradient_vector_cell ( const cs_mesh_t m,
cs_lnum_t  c_id,
[in]c_idcell id
[out]gradgradient
◆ cs_gradient_vector_synced_input()
void cs_gradient_vector_synced_input ( const char *  var_name,
int  inc,
int  n_r_sweeps,
int  verbosity,
double  epsilon,
double  clip_coeff,
[out]gradgradient ( $ \der{u_i}{x_j} $ is gradv[][i][j])
◆ grdpor()
void grdpor ( const int *const  inc)
◆ cs_gradient_type_name
const char* cs_gradient_type_name[]
