Include dependency graph for cs_blas_cuda.h:Go to the source code of this file.
| void | cs_blas_cuda_finalize (void) |
| Finalize CUDA BLAS API. More... | |
| double * | cs_blas_cuda_get_2_stage_reduce_buffer (cs_lnum_t n, cs_lnum_t tuple_size, unsigned int grid_size) |
| Return pointer to reduction buffer needed for 2-stage reductions. More... | |
| double | cs_blas_cuda_asum (cs_lnum_t n, const cs_real_t x[]) |
| Return the absolute sum of vector values using CUDA. More... | |
| double | cs_blas_cuda_dot (cs_lnum_t n, const cs_real_t x[], const cs_real_t y[]) |
| Return the dot product of 2 vectors: x.y using CUDA. More... | |
| void | cs_blas_cuda_axpy (cs_lnum_t n, const cs_real_t *alpha, const cs_real_t *restrict x, cs_real_t *restrict y) |
| void | cs_blas_cuda_scal (cs_lnum_t n, const cs_real_t *alpha, cs_real_t *restrict x) |
| [in] | n | size of array x |
| [in] | x | array of floating-point values (on device) |
| void cs_blas_cuda_axpy | ( | cs_lnum_t | n, |
| const cs_real_t * | alpha, | ||
| const cs_real_t *restrict | x, | ||
| cs_real_t *restrict | y | ||
| [in] | n | size of arrays x and y |
| [in] | y | array of floating-point values (on device) |
| void cs_blas_cuda_finalize | ( | void | ) |
This frees resources such as the cuBLAS handle, if used.
| double* cs_blas_cuda_get_2_stage_reduce_buffer | ( | cs_lnum_t | n, |
| cs_lnum_t | tuple_size, | ||
| unsigned int | grid_size | ||
This buffer is used internally by all cs_blas_cuda 2-stage operations, allocated and resized updon demand, and freed when calling cs_blas_cuda_finalize, so it is assumed no two operations (in different threads) use this simultaneously.
Also check initialization of work arrays.
| [in] | n | size of arrays |
| [in] | tuple_size | number of values per tuple simultaneously reduced |
| [in] | grid_size | associated grid size |
