7.2
cs_base_cuda.h
1 #ifndef __CS_BASE_CUDA_H__
2 #define __CS_BASE_CUDA_H__
5  * Definitions, global variables, and base functions for CUDA
30 #include "cs_defs.h"
36 #include <stdio.h>
39  * Local headers
42 #include "cs_log.h"
45  * Macro definitions
48 #define CS_CUDA_CHECK(a) { \
49  cudaError_t ret_code = a; \
50  if (cudaSuccess != ret_code) { \
51  bft_error(__FILE__, __LINE__, 0, "[CUDA error] %d: %s\n running: %s", \
52  ret_code, ::cudaGetErrorString(ret_code), #a); \
53  } \
54  }
55
56 #define CS_CUDA_CHECK_CALL(a, file_name, line_num) { \
57  cudaError_t ret_code = a; \
58  if (cudaSuccess != ret_code) { \
59  bft_error(file_name, line_num, 0, "[CUDA error] %d: %s\n running: %s", \
60  ret_code, ::cudaGetErrorString(ret_code), #a); \
61  } \
62  }
63
64 /* For all current compute capabilities, the warp size is 32; If it ever
65  changes, it can be obtained through cudaDeviceProp, so we could then
66  replace this macro with a global variable */
67
68 #define CS_CUDA_WARP_SIZE 32
69
70 /*----------------------------------------------------------------------------*/
71
73
74 /*============================================================================
75  * Type definitions
76  *============================================================================*/
77
78 /*=============================================================================
79  * Global variable definitions
80  *============================================================================*/
81
82 extern int cs_glob_cuda_device_id;
83
84 /* Other device parameters */
85
88 extern int cs_glob_cuda_max_blocks;
89 extern int cs_glob_cuda_n_mp; /* Number of multiprocessors */
90
91 /*============================================================================
92  * Semi-private function prototypes
93  *
94  * The following functions are intended to be used by the common
95  * host-device memory management functions from cs_base_accel.c, and
96  * not directly by the user.
97  *============================================================================*/
98
99 #if defined(HAVE_CUDA)
100
101 /*----------------------------------------------------------------------------*/
119 /*----------------------------------------------------------------------------*/
120
121 void *
122 cs_cuda_mem_malloc_device(size_t n,
123  const char *var_name,
124  const char *file_name,
125  int line_num);
126
145 /*----------------------------------------------------------------------------*/
146
147 void *
148 cs_cuda_mem_malloc_host(size_t n,
149  const char *var_name,
150  const char *file_name,
151  int line_num);
152
153 /*----------------------------------------------------------------------------*/
171 /*----------------------------------------------------------------------------*/
172
173 void *
174 cs_cuda_mem_malloc_managed(size_t n,
175  const char *var_name,
176  const char *file_name,
177  int line_num);
178
179 /*----------------------------------------------------------------------------*/
197 /*----------------------------------------------------------------------------*/
198
199 void
200 cs_cuda_mem_free(void *p,
201  const char *var_name,
202  const char *file_name,
203  int line_num);
204
205 /*----------------------------------------------------------------------------*/
223 /*----------------------------------------------------------------------------*/
224
225 void
226 cs_cuda_mem_free_host(void *p,
227  const char *var_name,
228  const char *file_name,
229  int line_num);
230
231 /*----------------------------------------------------------------------------*/
243 /*----------------------------------------------------------------------------*/
244
245 void
246 cs_cuda_copy_h2d(void *dst,
247  const void *src,
248  size_t size);
249
250 /*----------------------------------------------------------------------------*/
265 /*----------------------------------------------------------------------------*/
266
267 void
268 cs_cuda_copy_h2d_async(void *dst,
269  const void *src,
270  size_t size);
271
272 /*----------------------------------------------------------------------------*/
286 /*----------------------------------------------------------------------------*/
287
288 void
289 cs_cuda_copy_d2h(void *dst,
290  const void *src,
291  size_t size);
292
293 /*----------------------------------------------------------------------------*/
307 /*----------------------------------------------------------------------------*/
308
309 void
310 cs_cuda_copy_d2h_async(void *dst,
311  const void *src,
312  size_t size);
313
314 /*----------------------------------------------------------------------------*/
328 /*----------------------------------------------------------------------------*/
329
330 void
331 cs_cuda_prefetch_h2d(void *dst,
332  size_t size);
333
334 /*----------------------------------------------------------------------------*/
348 /*----------------------------------------------------------------------------*/
349
350 void
351 cs_cuda_prefetch_d2h(void *dst,
352  size_t size);
353
354 /*----------------------------------------------------------------------------*/
366 /*----------------------------------------------------------------------------*/
367
368 void
369 cs_cuda_copy_d2d(void *dst,
370  const void *src,
371  size_t size);
372
373 #endif
374
375 /*=============================================================================
376  * Inline static function prototypes
377  *============================================================================*/
378
379 /*----------------------------------------------------------------------------*/
392 /*----------------------------------------------------------------------------*/
393
394 static inline unsigned int
396  unsigned int block_size)
397 {
398  return (n % block_size) ? n/block_size : n/block_size + 1;
399 }
400
401 /*=============================================================================
402  * Public function prototypes
403  *============================================================================*/
404
405 #if defined(HAVE_CUDA)
406
407 /*----------------------------------------------------------------------------*/
413 /*----------------------------------------------------------------------------*/
414
415 void
416 cs_base_cuda_device_info(cs_log_t log_id);
417
418 /*----------------------------------------------------------------------------*/
424 /*----------------------------------------------------------------------------*/
425
426 void
427 cs_base_cuda_version_info(cs_log_t log_id);
428
429 /*----------------------------------------------------------------------------*/
435 /*----------------------------------------------------------------------------*/
436
437 void
438 cs_base_cuda_compiler_info(cs_log_t log_id);
439
440 /*----------------------------------------------------------------------------*/
449 /*----------------------------------------------------------------------------*/
450
451 int
452 cs_base_cuda_select_default_device(void);
453
454 /*----------------------------------------------------------------------------*/
460 /*----------------------------------------------------------------------------*/
461
462 int
463 cs_base_cuda_get_device(void);
464
465 #endif
466
467 /*----------------------------------------------------------------------------*/
468
470
471 #endif /* __CS_BASE_CUDA_H__ */
Definition: cs_field_pointer.h:67
int cs_glob_cuda_max_threads_per_block
cs_log_t
Definition: cs_log.h:48
Definition: cs_defs.h:316
static unsigned int cs_cuda_grid_size(cs_lnum_t n, unsigned int block_size)
Compute grid size for given array and block sizes.
Definition: cs_base_cuda.h:395
int cs_glob_cuda_max_block_size
