7.2
cs_multigrid.h File Reference
#include "cs_grid.h"
#include "cs_sles.h"
#include "cs_sles_it.h"
#include "cs_sles_pc.h"
#include "cs_time_plot.h"
+ Include dependency graph for cs_multigrid.h:
Typedefs
typedef struct _cs_multigrid_t cs_multigrid_t
Enumerations
enum  cs_multigrid_type_t { CS_MULTIGRID_V_CYCLE, CS_MULTIGRID_K_CYCLE, CS_MULTIGRID_K_CYCLE_HPC, CS_MULTIGRID_N_TYPES }
void cs_multigrid_initialize (void)
 Initialize multigrid solver API. More...
void cs_multigrid_finalize (void)
 Finalize multigrid solver API. More...
cs_multigrid_tcs_multigrid_define (int f_id, const char *name, cs_multigrid_type_t mg_type)
 Define and associate a multigrid sparse linear system solver for a given field or equation name. More...
cs_multigrid_tcs_multigrid_create (cs_multigrid_type_t mg_type)
 Create multigrid linear system solver info and context. More...
void cs_multigrid_destroy (void **context)
 Destroy multigrid linear system solver info and context. More...
void * cs_multigrid_copy (const void *context)
 Create multigrid sparse linear system solver info and context based on existing info and context. More...
void cs_multigrid_set_coarsening_options (cs_multigrid_t *mg, int aggregation_limit, int coarsening_type, int n_max_levels, cs_gnum_t min_g_rows, double p0p1_relax, int postprocess_block_size)
 Set multigrid coarsening parameters. More...
void cs_multigrid_set_solver_options (cs_multigrid_t *mg, cs_sles_it_type_t descent_smoother_type, cs_sles_it_type_t ascent_smoother_type, cs_sles_it_type_t coarse_solver_type, int n_max_cycles, int n_max_iter_descent, int n_max_iter_ascent, int n_max_iter_coarse, int poly_degree_descent, int poly_degree_ascent, int poly_degree_coarse, double precision_mult_descent, double precision_mult_ascent, double precision_mult_coarse)
 Set multigrid parameters for associated iterative solvers. More...
void cs_multigrid_set_max_cycles (cs_multigrid_t *mg, int n_max_cycles)
 Set the max. number of cycles for a multigrid. More...
cs_sles_it_type_t cs_multigrid_get_fine_solver_type (const cs_multigrid_t *mg)
 Return solver type used on fine mesh. More...
void cs_multigrid_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity)
 Setup multigrid sparse linear equation solver. More...
void cs_multigrid_setup_conv_diff (void *context, const char *name, const cs_matrix_t *a, bool conv_diff, int verbosity)
cs_sles_convergence_state_t cs_multigrid_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
 Call multigrid sparse linear equation solver. More...
void cs_multigrid_free (void *context)
 Free multigrid sparse linear equation solver setup context. More...
void cs_multigrid_log (const void *context, cs_log_t log_type)
 Log multigrid solver info. More...
cs_sles_pc_tcs_multigrid_pc_create (cs_multigrid_type_t mg_type)
 Create a multigrid preconditioner. More...
bool cs_multigrid_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
void cs_multigrid_set_plot_options (cs_multigrid_t *mg, const char *base_name, bool use_iteration)
 Set plotting options for multigrid. More...
void cs_multigrid_get_merge_options (const cs_multigrid_t *mg, int *rank_stride, int *rows_mean_threshold, cs_gnum_t *rows_glob_threshold)
 Query the global multigrid parameters for parallel grid merging. More...
void cs_multigrid_set_merge_options (cs_multigrid_t *mg, int rank_stride, int rows_mean_threshold, cs_gnum_t rows_glob_threshold)
 Set global multigrid parameters for parallel grid merging behavior. More...
const cs_grid_tcs_multigrid_get_grid (const cs_multigrid_t *mg, int level)
 Return a pointer to a grid associated with a given multigrid setup and level. More...
const char * cs_multigrid_type_name []
Typedef Documentation
◆ cs_multigrid_t
◆ cs_multigrid_type_t
Enumerator
Use a V-cycle
Use a K-cycle
Use a K-cycle tuned for HPC systems
Number of multigrid types
◆ cs_multigrid_copy()
void* cs_multigrid_copy ( const void *  context)
[in]contextpointer to reference info and context (actual type: cs_multigrid_t *)
pointer to newly created solver info object (actual type: cs_multigrid_t *)
◆ cs_multigrid_create()
cs_multigrid_t* cs_multigrid_create ( cs_multigrid_type_t  mg_type)
The multigrid variant is an ACM (Additive Corrective Multigrid) method.
[in]mg_typetype of multigrid algorithm to use
pointer to new multigrid info and context
◆ cs_multigrid_define()
cs_multigrid_t* cs_multigrid_define ( int  f_id,
const char *  name,
This is a utility function: if finer control is needed, see cs_sles_define and cs_multigrid_create.
Note that this function returns a pointer directly to the multigrid solver management structure. This may be used to set further options, for example calling cs_multigrid_set_coarsening_options and cs_multigrid_set_solver_options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
[in]nameassociated name if f_id < 0, or NULL
◆ cs_multigrid_destroy()
void cs_multigrid_destroy ( void **  context)
[in,out]contextpointer to multigrid linear solver info (actual type: cs_multigrid_t **)
◆ cs_multigrid_error_post_and_abort()
bool cs_multigrid_error_post_and_abort ( cs_sles_t sles,
const cs_matrix_t a,
const cs_real_t rhs,
cs_real_t vx
◆ cs_multigrid_finalize()
void cs_multigrid_finalize ( void  )
◆ cs_multigrid_free()
void cs_multigrid_free ( void *  context)
This function frees resolution-related data, incuding the current grid hierarchy, but does not free the whole context, as info used for logging (especially performance data) is maintained.
[in,out]contextpointer to multigrid solver info and context (actual type: cs_multigrid_t *)
◆ cs_multigrid_get_fine_solver_type()
cs_sles_it_type_t cs_multigrid_get_fine_solver_type ( const cs_multigrid_t mg)
[in]mgpointer to multigrid info and context
type of smoother for descent (used for fine mesh)
◆ cs_multigrid_get_grid()
const cs_grid_t* cs_multigrid_get_grid ( const cs_multigrid_t mg,
int  level
If the multigrid hierarchy is not set up, or a level coarser than the coarsest level is requested, NULL is returned.
[in]levellevel of the requested grid (or -1 for coarsest)
pointer to grid of requested level (NULL id not present)
◆ cs_multigrid_get_merge_options()
void cs_multigrid_get_merge_options ( const cs_multigrid_t mg,
int *  rank_stride,
int *  rows_mean_threshold,
[out]rank_stridenumber of ranks over which merging takes place, or NULL
[out]rows_mean_thresholdmean number of rows under which merging should be applied, or NULL
[out]rows_glob_thresholdglobal number of rows under which merging should be applied, or NULL
◆ cs_multigrid_initialize()
void cs_multigrid_initialize ( void  )
◆ cs_multigrid_log()
void cs_multigrid_log ( const void *  context,
cs_log_t  log_type
[in]contextpointer to iterative solver info and context (actual type: cs_multigrid_t *)
[in]log_typelog type
◆ cs_multigrid_pc_create()
cs_sles_pc_t* cs_multigrid_pc_create ( cs_multigrid_type_t  mg_type)
pointer to newly created preconditioner object.
◆ cs_multigrid_set_coarsening_options()
void cs_multigrid_set_coarsening_options ( cs_multigrid_t mg,
int  n_max_levels,
double  p0p1_relax,
int  postprocess
[in,out]mgpointer to multigrid info and context
[in]aggregation_limitmaximum allowed fine rows per coarse row
[in]coarsening_typecoarsening type; see cs_grid_coarsening_t
[in]n_max_levelsmaximum number of grid levels
[in]min_g_rowsglobal number of rows on coarse grids under which no coarsening occurs
[in]p0p1_relaxp0/p1 relaxation_parameter
[in]postprocessif > 0, postprocess coarsening (uses coarse row numbers modulo this value)
◆ cs_multigrid_set_max_cycles()
void cs_multigrid_set_max_cycles ( cs_multigrid_t mg,
int  n_max_cycles
[in]n_max_cyclesmaximum number of cycles
◆ cs_multigrid_set_merge_options()
void cs_multigrid_set_merge_options ( cs_multigrid_t mg,
int  rank_stride,
[in]rank_stridenumber of ranks over which merging takes place
[in]rows_mean_thresholdmean number of rows under which merging should be applied
[in]rows_glob_thresholdglobal number of rows under which merging should be applied
◆ cs_multigrid_set_plot_options()
void cs_multigrid_set_plot_options ( cs_multigrid_t mg,
const char *  base_name,
bool  use_iteration
[in]base_namebase plot name to activate, NULL otherwise
[in]use_iterationif true, use iteration as time stamp otherwise, use wall clock time
◆ cs_multigrid_set_solver_options()
void cs_multigrid_set_solver_options ( cs_multigrid_t mg,
int  n_max_cycles,
[in]descent_smoother_typetype of smoother for descent
[in]ascent_smoother_typetype of smoother for ascent
[in]coarse_solver_typetype of solver for coarsest grid
[in]n_max_iter_descentmaximum iterations per descent smoothing
[in]n_max_iter_ascentmaximum iterations per ascent smoothing
[in]n_max_iter_coarsemaximum iterations per coarsest solution
[in]poly_degree_descentpreconditioning polynomial degree for descent phases (0: diagonal)
[in]poly_degree_ascentpreconditioning polynomial degree for ascent phases (0: diagonal)
[in]poly_degree_coarsepreconditioning polynomial degree for coarse solver (0: diagonal)
[in]precision_mult_descentprecision multiplier for descent smoothers (levels >= 1)
[in]precision_mult_ascentprecision multiplier for ascent smoothers
[in]precision_mult_coarseprecision multiplier for coarsest grid
◆ cs_multigrid_setup()
void cs_multigrid_setup ( void *  context,
const char *  name,
int  verbosity
[in]namepointer to name of linear system
[in]aassociated matrix
[in]verbosityassociated verbosity
◆ cs_multigrid_setup_conv_diff()
void cs_multigrid_setup_conv_diff ( void *  context,
const char *  name,
bool  conv_diff,
int  verbosity
[in]conv_diffconvection-diffusion mode
◆ cs_multigrid_solve()
cs_sles_convergence_state_t cs_multigrid_solve ( void *  context,
const char *  name,
int  verbosity,
double  precision,
double  r_norm,
int *  n_iter,
double *  residue,
cs_real_t vx,
size_t  aux_size,
void *  aux_vectors
[in]amatrix
[in]precisionsolver precision
[in]r_normresidue normalization
[out]residueresidue
[in]rhsright hand side
[in,out]vxsystem solution
[in]aux_sizesize of aux_vectors (in bytes)
aux_vectorsoptional working area (internal allocation if NULL)
convergence state
◆ cs_multigrid_type_name
const char* cs_multigrid_type_name[]
