| cs_sles_hypre_t * | cs_sles_hypre_define (int f_id, const char *name, cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context) |
| | Define and associate a HYPRE linear system solver for a given field or equation name. More...
| cs_sles_hypre_t * | cs_sles_hypre_create (cs_sles_hypre_type_t solver_type, cs_sles_hypre_type_t precond_type, cs_sles_hypre_setup_hook_t *setup_hook, void *context) |
| | Create HYPRE linear system solver info and context. More...
| void | cs_sles_hypre_destroy (void **context) |
| void * | cs_sles_hypre_copy (const void *context) |
| void | cs_sles_hypre_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| cs_sles_convergence_state_t | cs_sles_hypre_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| void | cs_sles_hypre_free (void *context) |
| bool | cs_sles_hypre_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx) |
| | Error handler for HYPRE solver. More...
| void | cs_sles_hypre_log (const void *context, cs_log_t log_type) |
| void | cs_sles_hypre_set_n_max_iter (cs_sles_hypre_t *context, int n_max_iter) |
| | Set the max. number of iterations associated to the given HYPRE contrext. More...
| void | cs_sles_hypre_set_host_device (cs_sles_hypre_t *context, int use_device) |
| | Define whether the solver should run on the host or accelerated device. More...
| int | cs_sles_hypre_get_host_device (const cs_sles_hypre_t *context) |
| | Query whether the solver should run on the host or accelerated device. More...
| void | cs_sles_hypre_library_info (cs_log_t log_type) |
| | Print information on hypre library. More...
| cs_sles_hypre_setup_hook_t |
Function pointer for settings of a HYPRE solver setup.
This function is called during the setup stage for a HYPRE solver.
When first called, the solver argument is NULL, and must be created using HYPRE functions.
Note: if the context pointer is non-NULL, it must point to valid data when the selection function is called so that value or structure should not be temporary (i.e. local);
- Parameters
| [in,out] | context | pointer to optional (untyped) value or structure |
| [in,out] | solver | handle to HYPRE solver (to be cast as HYPRE_Solver) |
This is a utility function: if finer control is needed, see cs_sles_define and cs_sles_petsc_create.
The associated solver required that the matrix passed to it is a HYPRE matrix (see cs_matrix_set_type_hypre).
Note that this function returns a pointer directly to the iterative solver management structure. This may be used to set further options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
- Parameters
| [in] | solver_type | HYPRE solver type |
| [in] | precond_type | HYPRE preconditioner type |
| [in] | setup_hook | pointer to optional setup epilogue function |
| [in,out] | context | pointer to optional (untyped) value or structure for setup_hook, or NULL |
- Returns
- pointer to newly created iterative solver info object.
