#include "base/cs_defs.h"#include <assert.h>#include <errno.h>#include <ctype.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <float.h>#include "bft/bft_mem.h"#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "atmo/cs_air_props.h"#include "base/cs_array.h"#include "atmo/cs_atmo_profile_std.h"#include "base/cs_base.h"#include "base/cs_boundary_conditions.h"#include "base/cs_boundary_conditions_set_coeffs.h"#include "base/cs_boundary_zone.h"#include "cdo/cs_domain.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_halo.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_location.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_measures_util.h"#include "base/cs_parall.h"#include "base/cs_equation_iterative_solve.h"#include "base/cs_parameters_check.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_post.h"#include "base/cs_prototypes.h"#include "rayt/cs_rad_transfer.h"#include "base/cs_thermal_model.h"#include "turb/cs_turbulence_bc.h"#include "turb/cs_turbulence_model.h"#include "base/cs_volume_zone.h"#include "alge/cs_balance.h"#include "alge/cs_blas.h"#include "alge/cs_convection_diffusion.h"#include "base/cs_parameters.h"#include "base/cs_porous_model.h"#include "base/cs_timer.h"#include "alge/cs_matrix_building.h"#include "alge/cs_sles.h"#include "alge/cs_sles_default.h"#include "alge/cs_face_viscosity.h"#include "alge/cs_divergence.h"#include "base/cs_restart.h"#include "base/cs_restart_default.h"#include "base/cs_velocity_pressure.h"#include "atmo/cs_intprf.h"#include "atmo/cs_atmo.h"#include "atmo/cs_atmo_aerosol.h"Functions | |
| void | cs_atmo_fields_init0 (void) |
| void | cs_atmo_bcond (void) |
| void | cs_soil_model (void) |
| Deardorff force restore model. | |
| void | cs_atmo_init_meteo_profiles (void) |
| Initialize meteo profiles if no meteo file is given. | |
| void | cs_atmo_compute_meteo_profiles (void) |
| Compute meteo profiles if no meteo file is given. | |
| void | cs_atmo_z_ground_compute (void) |
| Compute the ground elevation. | |
| void | cs_atmo_hydrostatic_profiles_compute (void) |
| Compute hydrostatic profiles of density and pressure. | |
| void | cs_atmo_set_meteo_file_name (const char *file_name) |
| This function set the file name of the meteo file. | |
| void | cs_atmo_set_chem_conc_file_name (const char *file_name) |
| This function set the file name of the chemistry file. | |
| void | cs_atmo_set_aero_conc_file_name (const char *file_name) |
| This function set the file name of the aerosol file. | |
| void | cs_atmo_init_chemistry (void) |
| Initialize chemistry array. | |
| void | cs_atmo_chemistry_set_spack_file_name (const char *file_name) |
| This function set the file name of the SPACK file. | |
| void | cs_atmo_chemistry_set_aerosol_file_name (const char *file_name) |
| This function sets the file name to initialize the aerosol library. | |
| void | cs_atmo_declare_chem_from_spack (void) |
| This function declares additional transported variables for atmospheric module for the chemistry defined from SPACK. | |
| void | cs_atmo_compute_solar_angles (cs_real_t latitude, cs_real_t longitude, cs_real_t squant, cs_real_t utc, int sea_id, cs_real_t *albedo, cs_real_t *za, cs_real_t *muzero, cs_real_t *omega, cs_real_t *fo) |
| 1D Radiative scheme - Solar data + zenithal angle) | |
| void | cs_atmo_chemistry_initialization_deactivate (void) |
| Deactivate chemistry initialization procedure. | |
| int | cs_atmo_chemistry_need_initialization (void) |
| Check if the chemistry module needs initialization. | |
| void | cs_atmo_log_setup (void) |
| Print the atmospheric module options to setup.log. | |
| void | cs_atmo_chemistry_log_setup (void) |
| Print the atmospheric chemistry options to setup.log. | |
| void | cs_atmo_aerosol_log_setup (void) |
| Print the atmospheric aerosols options to setup.log. | |
| void | cs_atmo_finalize (void) |
| Deallocate arrays for atmo module. | |
| void cs_atmo_aerosol_log_setup | ( | void | ) |
| void cs_atmo_bcond | ( | void | ) |
| void cs_atmo_chemistry_initialization_deactivate | ( | void | ) |
| void cs_atmo_chemistry_log_setup | ( | void | ) |
| int cs_atmo_chemistry_need_initialization | ( | void | ) |
| void cs_atmo_chemistry_set_aerosol_file_name | ( | const char * | file_name | ) |
| [in] | file_name | name of the file. |
| void cs_atmo_chemistry_set_spack_file_name | ( | const char * | file_name | ) |
| void cs_atmo_compute_meteo_profiles | ( | void | ) |
| void cs_atmo_compute_solar_angles | ( | cs_real_t | latitude, |
| cs_real_t | longitude, | ||
| cs_real_t | squant, | ||
| cs_real_t | utc, | ||
| int | sea_id, | ||
| cs_real_t * | albedo, | ||
| cs_real_t * | za, | ||
| cs_real_t * | muzero, | ||
| cs_real_t * | omega, | ||
| cs_real_t * | fo ) |
Compute:
| [in] | latitude | latitude |
| [in] | longitude | longitude |
| [in] | squant | start day in the year |
| [in] | utc | Universal time (hour) |
| [in] | sea_id | sea index |
| [out] | albedo | albedo |
| [out] | za | zenithal angle |
| [out] | muzero | cosin of zenithal angle |
| [out] | omega | solar azimut angle |
| [out] | fo | solar constant |
| void cs_atmo_declare_chem_from_spack | ( | void | ) |
This function declare additional transported variables for atmospheric module for the chemistry defined from SPACK.
| void cs_atmo_fields_init0 | ( | void | ) |
| void cs_atmo_finalize | ( | void | ) |
| void cs_atmo_hydrostatic_profiles_compute | ( | void | ) |
This function solves the following transport equation on
![\[ \divs \left( \grad \varia \right)
= \divs \left( \dfrac{\vect{g}}{c_p \theta} \right)
\]](form_82.png)
where
The boundary conditions on
![\[ \varia = \left(\dfrac{P_{sea}}{p_s}\right)^{R/C_p} \textrm{on the ground}
\]](form_84.png)
and Neumann elsewhere.
| void cs_atmo_init_chemistry | ( | void | ) |
| void cs_atmo_init_meteo_profiles | ( | void | ) |
| void cs_atmo_log_setup | ( | void | ) |
| void cs_atmo_set_aero_conc_file_name | ( | const char * | file_name | ) |
This function set the file name of the aerosol concentration file.
| void cs_atmo_set_chem_conc_file_name | ( | const char * | file_name | ) |
This function set the file name of the chemistry concentration file.
| void cs_atmo_set_meteo_file_name | ( | const char * | file_name | ) |
| void cs_atmo_z_ground_compute | ( | void | ) |
![\[ \dfrac{\partial \varia}{\partial t} + \divs \left( \varia \vect{g} \right)
- \divs \left( \vect{V} \right) \varia = 0
\]](form_78.png)
where
![\[ \varia = z \textrm{ on walls}
\]](form_80.png)
![\[ \dfrac{\partial \varia}{\partial n} = 0 \textrm{ elsewhere}
\]](form_81.png)
Remarks:
| void cs_soil_model | ( | void | ) |
Compute soil and interface values using Deardorff force restore method.
