7.2
cs_lagr.c File Reference
#include <limits.h>
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "cs_array.h"
#include "cs_field_pointer.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_boundary_conditions.h"
#include "cs_boundary_zone.h"
#include "cs_volume_zone.h"
#include "cs_parameters.h"
#include "cs_prototypes.h"
#include "cs_time_step.h"
#include "cs_thermal_model.h"
#include "cs_post.h"
#include "cs_post_default.h"
#include "cs_gui_particles.h"
#include "cs_gui_util.h"
#include "cs_lagr.h"
#include "cs_lagr_lec.h"
#include "cs_lagr_geom.h"
#include "cs_lagr_dlvo.h"
#include "cs_lagr_clogging.h"
#include "cs_lagr_injection.h"
#include "cs_lagr_aux_mean_fluid_quantities.h"
#include "cs_lagr_car.h"
#include "cs_lagr_coupling.h"
#include "cs_lagr_new.h"
#include "cs_lagr_particle.h"
#include "cs_lagr_resuspension.h"
#include "cs_lagr_stat.h"
#include "cs_lagr_tracking.h"
#include "cs_lagr_print.h"
#include "cs_lagr_poisson.h"
#include "cs_lagr_post.h"
#include "cs_lagr_sde.h"
#include "cs_lagr_sde_model.h"
#include "cs_lagr_orientation.h"
#include "cs_lagr_agglo.h"
#include "cs_lagr_fragmentation.h"
#include "cs_random.h"
void cs_lagr_init_c_arrays (int dim_cs_glob_lagr_source_terms[2], cs_real_t **p_cs_glob_lagr_source_terms)
void cs_lagr_finalize (void)
void cs_lagr_add_fields (void)
 Create additional fields needed by the Lagrangien model. More...
cs_lagr_injection_set_tcs_lagr_get_injection_set (cs_lagr_zone_data_t *zone_data, int zone_id, int set_id)
 Provide access to injection set structure. More...
void cs_lagr_injection_set_default (cs_lagr_injection_set_t *zis)
 Initialize injection set data structure fields to defaults. More...
cs_lagr_particle_counter_tcs_lagr_get_particle_counter (void)
 Get read/write pointer to global particle counter. More...
cs_lagr_particle_counter_tcs_lagr_update_particle_counter (void)
 Update global particle counter. More...
cs_lagr_specific_physics_tcs_get_lagr_specific_physics (void)
 Provide access to cs_lagr_specific_physics_t. More...
cs_lagr_reentrained_model_tcs_get_lagr_reentrained_model (void)
 Provide access to cs_lagr_reentrained_model_t. More...
cs_lagr_precipitation_model_tcs_get_lagr_precipitation_model (void)
 Provide access to cs_lagr_precipitation_model_t. More...
cs_lagr_clogging_model_tcs_get_lagr_clogging_model (void)
cs_lagr_shape_model_tcs_get_lagr_shape_model (void)
cs_lagr_agglomeration_model_tcs_get_lagr_agglomeration_model (void)
cs_lagr_consolidation_model_tcs_get_lagr_consolidation_model (void)
cs_lagr_time_step_tcs_get_lagr_time_step (void)
cs_lagr_source_terms_tcs_get_lagr_source_terms (void)
cs_lagr_encrustation_tcs_get_lagr_encrustation (void)
cs_lagr_physico_chemical_tcs_get_lagr_physico_chemical (void)
cs_lagr_brownian_tcs_get_lagr_brownian (void)
cs_lagr_internal_condition_tcs_lagr_get_internal_conditions (void)
 Return pointer to the main internal conditions structure. More...
cs_lagr_zone_data_tcs_lagr_get_boundary_conditions (void)
 Return pointer to the main boundary conditions structure. More...
cs_lagr_zone_data_tcs_lagr_get_volume_conditions (void)
 Return pointer to the main volume conditions structure. More...
void cs_lagr_finalize_zone_conditions (void)
void cs_lagr_finalize_internal_cond (void)
cs_lagr_boundary_interactions_tcs_get_lagr_boundary_interactions (void)
cs_lagr_extra_module_tcs_get_lagr_extra_module (void)
void cs_lagr_solve_initialize (const cs_real_t *dt)
void cs_lagr_solve_time_step (const int itypfb[], const cs_real_t *dt)
◆ cs_get_lagr_agglomeration_model()
cs_lagr_agglomeration_model_t* cs_get_lagr_agglomeration_model ( void  )
◆ cs_get_lagr_boundary_interactions()
cs_lagr_boundary_interactions_t* cs_get_lagr_boundary_interactions ( void  )
◆ cs_get_lagr_brownian()
cs_lagr_brownian_t* cs_get_lagr_brownian ( void  )
◆ cs_get_lagr_clogging_model()
cs_lagr_clogging_model_t* cs_get_lagr_clogging_model ( void  )
◆ cs_get_lagr_consolidation_model()
cs_lagr_consolidation_model_t* cs_get_lagr_consolidation_model ( void  )
◆ cs_get_lagr_encrustation()
cs_lagr_encrustation_t* cs_get_lagr_encrustation ( void  )
◆ cs_get_lagr_extra_module()
cs_lagr_extra_module_t* cs_get_lagr_extra_module ( void  )
◆ cs_get_lagr_physico_chemical()
cs_lagr_physico_chemical_t* cs_get_lagr_physico_chemical ( void  )
◆ cs_get_lagr_precipitation_model()
cs_lagr_precipitation_model_t* cs_get_lagr_precipitation_model ( void  )
pointer to lagrangian precipitation model options
◆ cs_get_lagr_reentrained_model()
cs_lagr_reentrained_model_t* cs_get_lagr_reentrained_model ( void  )
pointer to lagrangian reentrained model options
◆ cs_get_lagr_shape_model()
cs_lagr_shape_model_t* cs_get_lagr_shape_model ( void  )
◆ cs_get_lagr_source_terms()
cs_lagr_source_terms_t* cs_get_lagr_source_terms ( void  )
◆ cs_get_lagr_specific_physics()
cs_lagr_specific_physics_t* cs_get_lagr_specific_physics ( void  )
pointer to lagrangian specific physics options
◆ cs_get_lagr_time_step()
cs_lagr_time_step_t* cs_get_lagr_time_step ( void  )
◆ cs_lagr_add_fields()
void cs_lagr_add_fields ( void  )
Most additional fields can be defined directly in cs_lagr_options_definition, but some fields may be mapped to different fields based on the calling module (i.e. code_saturne or neptune_cfd), and possibly defined after that call.
◆ cs_lagr_finalize()
void cs_lagr_finalize ( void  )
◆ cs_lagr_finalize_internal_cond()
void cs_lagr_finalize_internal_cond ( void  )
◆ cs_lagr_finalize_zone_conditions()
void cs_lagr_finalize_zone_conditions ( void  )
Finalize the global boundary and volume condition structures.
pointer to current internal conditions structure
◆ cs_lagr_get_boundary_conditions()
cs_lagr_zone_data_t* cs_lagr_get_boundary_conditions ( void  )
pointer to current boundary zone data structure
◆ cs_lagr_get_injection_set()
cs_lagr_injection_set_t* cs_lagr_get_injection_set ( cs_lagr_zone_data_t zone_data,
int  zone_id,
int  set_id
This access method ensures the strucure is initialized for the given zone and injection set.
[in]zone_datapointer to boundary or volume conditions structure
[in]zone_idzone id
[in]set_idinjection set id
pointer to injection set data structure
◆ cs_lagr_get_internal_conditions()
cs_lagr_internal_condition_t* cs_lagr_get_internal_conditions ( void  )
The structure is allocated on demand, when this function is first called.
pointer to current internal_conditions structure
◆ cs_lagr_get_particle_counter()
cs_lagr_particle_counter_t* cs_lagr_get_particle_counter ( void  )
pointer to lagrangian particle counter structure
◆ cs_lagr_get_volume_conditions()
cs_lagr_zone_data_t* cs_lagr_get_volume_conditions ( void  )
pointer to current volume zone data structure
◆ cs_lagr_init_c_arrays()
void cs_lagr_init_c_arrays ( int  dim_cs_glob_lagr_source_terms[2],
cs_real_t **  p_cs_glob_lagr_source_terms
◆ cs_lagr_injection_set_default()
void cs_lagr_injection_set_default ( cs_lagr_injection_set_t zis)
[in,out]zispointer to structure to initialize
◆ cs_lagr_solve_initialize()
void cs_lagr_solve_initialize ( const cs_real_t dt)
◆ cs_lagr_solve_time_step()
void cs_lagr_solve_time_step ( const int  itypfb[],
const cs_real_t dt
◆ cs_lagr_update_particle_counter()
cs_lagr_particle_counter_t* cs_lagr_update_particle_counter ( void  )
All fields handled in the local particle set are updated relative to that data (using global sums).
