7.2
cs_parameters.h
1 #ifndef __CS_PARAMETERS_H__
2 #define __CS_PARAMETERS_H__
5  * General parameters management.
34 #include <stdarg.h>
37  * Local headers
40 #include "cs_defs.h"
41 #include "cs_equation_param.h"
42 #include "cs_field.h"
43 #include "cs_tree.h"
45 /*----------------------------------------------------------------------------*/
46
48
49 /*=============================================================================
50  * Macro definitions
52
54  * Type definitions
56
58  * Structure of variable calculation options
59  * (now an alias of cs_equation_param_t)
60  *----------------------------------------------------------------------------*/
61
63
64 /*----------------------------------------------------------------------------
65  * Structure of the solving info
66  *----------------------------------------------------------------------------*/
67
68 typedef struct {
69  int n_it;
70  double rhs_norm;
71  double res_norm;
72  double derive;
73  double l2residual;
75
76 /*----------------------------------------------------------------------------
77  * Boundary condition types
78  *----------------------------------------------------------------------------*/
79
80 enum {
81  CS_INDEF = 1,
82  CS_INLET = 2,
83  CS_OUTLET = 3,
87  CS_ESICF = 7,
88  CS_SSPCF = 8,
89  CS_SOPCF = 9,
90  CS_EPHCF = 10,
91  CS_EQHCF = 11,
92  CS_COUPLED = 12, /* coupled face */
93  CS_COUPLED_FD = 13, /* coupled face with decentered flux */
97 };
98
99 /*----------------------------------------------------------------------------
100  * flag for computing the drift mass flux:
101  * (for coal classes for instance, only the first
102  * scalar of a class compute the drift flux of the class
103  * and the other scalars use it without recomputing it)
104  *----------------------------------------------------------------------------*/
105
106 enum {
107  CS_DRIFT_SCALAR_ON = (1 << 0),
116 };
117
118 /*----------------------------------------------------------------------------
119  * Space discretisation options descriptor
120  *----------------------------------------------------------------------------*/
121
122 typedef struct {
123
124  int imvisf; /* face viscosity field interpolation
125  - 1: harmonic
126  - 0: arithmetic (default) */
127
128  int imrgra; /* type of gradient reconstruction
129  - 0: iterative process
130  - 1: standard least square method
131  - 2: least square method with extended
132  neighborhood
133  - 3: least square method with reduced extended
134  neighborhood
135  - 4: Green-Gauss using least squares face
136  values interpolation */
137
138  int iflxmw; /* method to compute interior mass flux due to ALE
139  mesh velocity
140  - 1: based on cell center mesh velocity
141  - 0: based on nodes displacement */
142
143  int itbrrb; /* accurate treatment of the wall temperature
144  - 1: true
145  - 0: false (default) */
146
148
149 /*----------------------------------------------------------------------------
150  * Time scheme descriptor
151  *----------------------------------------------------------------------------*/
152
153 typedef struct {
154
155  int time_order; /* Global time order of the time stepping */
156
157  int isto2t; /* time scheme activated for the source
158  terms of turbulent equations */
159
160  double thetst; /* value of \f$theta\f$ for turbulence */
161
162  int iccvfg; /* calculation with a fixed velocity field
163  - 1: true (default)
164  - 0: false */
166
167 /*----------------------------------------------------------------------------
168  * Auxiliary checkpoint/restart file parameters
169  *----------------------------------------------------------------------------*/
170
171 typedef struct {
172
173  int read_auxiliary; /* Activate reading of auxiliary restart file */
174  int write_auxiliary; /* Activate output of auxiliary restart file */
175
177
178 /*============================================================================
179  * Static global variables
180  *============================================================================*/
181
182 /* Pointer to space discretisation options structure */
183
184 extern const cs_space_disc_t *cs_glob_space_disc;
185
186 /* Pointer to time scheme options structure */
187
189
190 /* Pointer to auxiliary checkpoint/restart file parameters */
191
193
194 /*============================================================================
195  * Global variables
196  *============================================================================*/
197
200 extern cs_tree_node_t *cs_glob_tree;
201
202 /*=============================================================================
203  * Public function prototypes
204  *============================================================================*/
205
206 /*----------------------------------------------------------------------------*/
217 /*----------------------------------------------------------------------------*/
218
219 static inline int
221 {
222  int iscvr = 0, f_id = 0;
223  int kscavr = cs_field_key_id("first_moment_id");
224  int keysca = cs_field_key_id("scalar_id");
225
226  if (kscavr >= 0) {
227  f_id = cs_field_get_key_int(f, kscavr);
228  if (f_id >= 0)
229  iscvr = cs_field_get_key_int(cs_field_by_id(f_id), keysca);
230  }
231
232  return iscvr;
233 }
234
235 /*----------------------------------------------------------------------------*/
243 /*----------------------------------------------------------------------------*/
244
247
248 /*----------------------------------------------------------------------------*/
256 /*----------------------------------------------------------------------------*/
257
260
261 /*----------------------------------------------------------------------------*/
268 /*----------------------------------------------------------------------------*/
269
270 void
272
273 /*----------------------------------------------------------------------------*/
279 /*----------------------------------------------------------------------------*/
280
281 void
283
284 /*----------------------------------------------------------------------------*/
293 /*----------------------------------------------------------------------------*/
294
295 void
296 cs_parameters_add_variable(const char *name,
297  int dim);
298
299 /*----------------------------------------------------------------------------*/
308 /*----------------------------------------------------------------------------*/
309
310 void
311 cs_parameters_add_variable_variance(const char *name,
312  const char *variable_name);
313
314 /*----------------------------------------------------------------------------*/
322 /*----------------------------------------------------------------------------*/
323
324 void
325 cs_parameters_add_property(const char *name,
326  int dim,
327  int location_id);
328
329 /*----------------------------------------------------------------------------*/
338 /*----------------------------------------------------------------------------*/
339
340 int
342
343 /*----------------------------------------------------------------------------*/
352 /*----------------------------------------------------------------------------*/
353
354 int
356
357 /*----------------------------------------------------------------------------*/
361 /*----------------------------------------------------------------------------*/
362
363 void
365
366 /*----------------------------------------------------------------------------*/
370 /*----------------------------------------------------------------------------*/
371
372 void
374
375 /*----------------------------------------------------------------------------*/
383 /*----------------------------------------------------------------------------*/
384
385 cs_field_t *
387
388 /*----------------------------------------------------------------------------*/
399 /*----------------------------------------------------------------------------*/
400
401 cs_field_t *
403
404 /*----------------------------------------------------------------------------*/
408 /*----------------------------------------------------------------------------*/
409
410 void
412
413 /*----------------------------------------------------------------------------*/
417 /*----------------------------------------------------------------------------*/
418
419 void
421
422 /*----------------------------------------------------------------------------*/
429 /*----------------------------------------------------------------------------*/
430
433
434 /*----------------------------------------------------------------------------*/
438 /*----------------------------------------------------------------------------*/
439
440 void
442
443 /*----------------------------------------------------------------------------*/
447 /*----------------------------------------------------------------------------*/
448
449 void
451
452 /*----------------------------------------------------------------------------*/
453
455
456 #endif /* __CS_PARAMETERS_H__ */
Definition: cs_parameters.h:107
void cs_parameters_eqp_complete(void)
Complete general equation parameter definitions.
Definition: cs_parameters.c:1491
Definition: cs_parameters.h:87
cs_field_t * cs_parameters_add_boundary_values(cs_field_t *f)
Define a boundary values field for a variable field.
Definition: cs_parameters.c:1303
Definition: cs_parameters.h:114
Definition: cs_parameters.h:68
Definition: cs_parameters.h:108
int read_auxiliary
Definition: cs_parameters.h:173
double thetst
Definition: cs_parameters.h:160
int imrgra
Definition: cs_parameters.h:128
const cs_space_disc_t * cs_glob_space_disc
Definition: cs_parameters.h:112
Definition: cs_parameters.h:84
void cs_parameters_create_added_variables(void)
Create previously added user variables.
Definition: cs_parameters.c:1178
Definition: cs_parameters.h:115
int iflxmw
Definition: cs_parameters.h:138
Definition: cs_field.h:125
Definition: cs_parameters.h:96
Definition: cs_field.c:2314
cs_time_scheme_t * cs_get_glob_time_scheme(void)
Provide access to cs_glob_time_scheme.
Definition: cs_parameters.c:863
void cs_parameters_add_variable(const char *name, int dim)
Definition: cs_parameters.c:1039
void cs_parameters_read_restart_info(void)
Read general restart info.
Definition: cs_parameters.c:1017
void cs_space_disc_log_setup(void)
Print the space discretization structure to setup.log.
Definition: cs_parameters.c:1606
cs_tree_node_t * cs_glob_tree
Definition: cs_parameters.h:111
void cs_parameters_add_variable_variance(const char *name, const char *variable_name)
Define a user variable which is a variance of another variable.
Definition: cs_parameters.c:1080
cs_restart_auxiliary_t * cs_glob_restart_auxiliary
Definition: cs_parameters.h:86
void cs_parameters_add_property(const char *name, int dim, int location_id)
Define a user property.
Definition: cs_parameters.c:1117
Additional checkpoint/restart files.
Definition: cs_parameters.h:171
Definition: cs_parameters.h:95
int time_order
Definition: cs_parameters.h:155
cs_space_disc_t * cs_get_glob_space_disc(void)
Provide access to cs_glob_space_disc.
Definition: cs_parameters.c:847
Definition: cs_parameters.h:110
void cs_parameters_create_added_properties(void)
Create previously added user properties.
Definition: cs_parameters.c:1253
Definition: cs_field.c:2991
Definition: cs_parameters.h:81
Definition: cs_field.c:2497
Definition: cs_parameters.h:82
int iccvfg
Definition: cs_parameters.h:162
int itbrrb
Definition: cs_parameters.h:143
Definition: cs_parameters.h:94
Definition: cs_parameters.h:113
int cs_parameters_n_added_variables(void)
Return the number of defined user variables not added yet.
Definition: cs_parameters.c:1152
Time scheme descriptor.
Definition: cs_parameters.h:153
Definition: cs_parameters.h:85
int n_it
Definition: cs_parameters.h:69
cs_equation_param_t cs_var_cal_opt_t
Definition: cs_parameters.h:62
const cs_time_scheme_t * cs_glob_time_scheme
double l2residual
Definition: cs_parameters.h:73
Definition: cs_parameters.h:109
void cs_time_scheme_log_setup(void)
Print the time scheme structure to setup.log.
Definition: cs_parameters.c:1580
static int cs_parameters_iscavr(cs_field_t *f)
For a given field, returns the scalar number of the fluctuating field if given field is a variance...
Definition: cs_parameters.h:220
Definition: cs_parameters.h:88
Space discretisation options descriptor.
Definition: cs_parameters.h:122
Definition: cs_parameters.h:93
int cs_parameters_n_added_properties(void)
Return the number of defined user properties not added yet.
Definition: cs_parameters.c:1166
int isto2t
Definition: cs_parameters.h:157
Definition: cs_parameters.h:89
Definition: cs_parameters.h:90
double rhs_norm
Definition: cs_parameters.h:70
void cs_parameters_define_field_keys(void)
Define general field keys.
Definition: cs_parameters.c:878
Definition: cs_parameters.h:91
int write_auxiliary
Definition: cs_parameters.h:174
Definition: cs_parameters.h:92
Definition: cs_parameters.h:83
int imvisf
Definition: cs_parameters.h:124
double derive
Definition: cs_parameters.h:72
cs_var_cal_opt_t cs_parameters_var_cal_opt_default(void)
Return a local variable calculation options structure, with default options.
Definition: cs_parameters.c:1568
void cs_parameters_output_complete(void)
Complete general output options definitions.
Definition: cs_parameters.c:1518
cs_field_t * cs_parameters_add_boundary_temperature(void)
Define a boundary values field for temperature, if applicable.
Definition: cs_parameters.c:1408
double res_norm
Definition: cs_parameters.h:71
