#include "cs_advection_field.h"#include "cs_enforcement.h"#include "cs_hodge.h"#include "cs_iter_algo.h"#include "cs_param_cdo.h"#include "cs_param_sles.h"#include "cs_property.h"#include "cs_xdef.h"
Include dependency graph for cs_equation_param.h:Go to the source code of this file.
| struct | cs_equation_param_t |
| Set of parameters to handle an unsteady convection-diffusion-reaction equation with term sources. More... | |
Macros | |
Flags specifying which term is needed for an equation. | |
| #define | CS_EQUATION_LOCKED (1 << 0) /* 1 */ |
| Parameters for setting an equation are not modifiable anymore. More... | |
| #define | CS_EQUATION_UNSTEADY (1 << 1) /* 2 */ |
| Unsteady term is needed. More... | |
| #define | CS_EQUATION_CONVECTION (1 << 2) /* 4 */ |
| Convection term is needed. More... | |
| #define | CS_EQUATION_DIFFUSION (1 << 3) /* 8 */ |
| Diffusion term is needed. A scalar-/vector-valued Laplacian with div .grad. More... | |
| #define | CS_EQUATION_CURLCURL (1 << 4) /* 16 */ |
| The term related to the curl-curl operator is needed. More... | |
| #define | CS_EQUATION_GRADDIV (1 << 5) /* 32 */ |
| The term related to the grad-div operator is needed. More... | |
| #define | CS_EQUATION_REACTION (1 << 6) /* 64 */ |
| Reaction term is needed. More... | |
| #define | CS_EQUATION_FORCE_VALUES (1 << 7) /* 128 */ |
| Add an algebraic manipulation to set the value of a given set of interior degrees of freedom. More... | |
| #define | CS_EQUATION_INSIDE_SYSTEM (1 << 8) /* 256 */ |
| The current equation settings belong to a system of equation. More... | |
| #define | CS_EQUATION_BUILD_HOOK (1 << 9) /* 512 */ |
| Activate a build hook to get a fine control of the discretization process during the cellwise building of the linear system Need to match the cs_equation_build_hook_t prototype. More... | |
| #define | CS_EQUATION_USER_TRIGGERED (1 << 10) /* 1024 */ |
| The resolution of the current equation is driven by the user and so this user-defined equation is not solved with the other user-defined equations. More... | |
Flags specifying which extra operation is needed for an equation. | |
| #define | CS_EQUATION_POST_BALANCE (1 << 0) /* 1 */ |
| Compute and postprocess the equation balance. More... | |
| #define | CS_EQUATION_POST_PECLET (1 << 1) /* 2 */ |
| Compute and postprocess the Peclet number. More... | |
| #define | CS_EQUATION_POST_UPWIND_COEF (1 << 2) /* 4 */ |
| Postprocess the value of the upwinding coefficient. More... | |
| #define | CS_EQUATION_POST_NORMAL_FLUX (1 << 3) /* 8 */ |
| Postprocess the value of the normal flux across the boundary faces. More... | |
| static void | cs_equation_param_set_flag (cs_equation_param_t *eqp, cs_flag_t flag) |
| Update the flag related to a cs_equation_param_t structure. More... | |
| static bool | cs_equation_param_has_diffusion (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs a diffusion term. More... | |
| static bool | cs_equation_param_has_curlcurl (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs a curl-curl term. More... | |
| static bool | cs_equation_param_has_graddiv (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs a grad-div term. More... | |
| static bool | cs_equation_param_has_convection (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs a convection term. More... | |
| static bool | cs_equation_param_has_reaction (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs a reaction term. More... | |
| static bool | cs_equation_param_has_time (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs an unsteady term. More... | |
| static bool | cs_equation_param_has_sourceterm (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation needs a source term. More... | |
| static bool | cs_equation_param_has_internal_enforcement (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation has an internal enforcement of the degrees of freedom. More... | |
| static bool | cs_equation_param_has_implicit_advection (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation induces an implicit treatment of the advection term. More... | |
| static bool | cs_equation_param_has_user_hook (const cs_equation_param_t *eqp) |
| Ask if the parameters of the equation has activated a user hook to get a fine tuning of the cellwise system building. More... | |
| static bool | cs_equation_param_has_name (cs_equation_param_t *eqp, const char *name) |
| Check if a cs_equation_param_t structure has its name member equal to the given name. More... | |
| cs_equation_param_t * | cs_equation_param_create (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc) |
| Create a cs_equation_param_t structure. More... | |
| static cs_equation_param_t * | cs_equation_create_param (const char *name, cs_equation_type_t type, int dim, cs_param_bc_type_t default_bc) |
| void | cs_equation_param_copy_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fid) |
| Copy the settings from one cs_equation_param_t structure to another one. The name is not copied. More... | |
| void | cs_equation_param_copy_bc (const cs_equation_param_t *ref, cs_equation_param_t *dst) |
| Copy only the part dedicated to the boundary conditions and the DoF (degrees of freedom) enforcement from one cs_equation_param_t structure to another one. More... | |
| static void | cs_equation_copy_param_from (const cs_equation_param_t *ref, cs_equation_param_t *dst, bool copy_fid) |
| void | cs_equation_param_clear (cs_equation_param_t *eqp) |
| Free the contents of a cs_equation_param_t. More... | |
| static void | cs_equation_clear_param (cs_equation_param_t *eqp) |
| cs_equation_param_t * | cs_equation_param_free (cs_equation_param_t *eqp) |
| Free a cs_equation_param_t. More... | |
| static cs_equation_param_t * | cs_equation_free_param (cs_equation_param_t *eqp) |
| void | cs_equation_param_set (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval) |
| Set a parameter attached to a keyname in a cs_equation_param_t structure. More... | |
| static void | cs_equation_set_param (cs_equation_param_t *eqp, cs_equation_key_t key, const char *keyval) |
| void | cs_equation_param_set_sles (cs_equation_param_t *eqp) |
| Set parameters for initializing SLES structures used for the resolution of the linear system. Settings are related to this equation. More... | |
| void | cs_equation_param_last_stage (cs_equation_param_t *eqp) |
| Last modification of the cs_equation_param_t structure before launching the computation. More... | |
| void | cs_equation_param_log (const cs_equation_param_t *eqp) |
| Print the detail of a cs_equation_param_t structure. More... | |
| bool | cs_equation_param_has_robin_bc (const cs_equation_param_t *eqp) |
| Ask if the parameter settings of the equation has requested the treatment of Robin boundary conditions. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_value (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here a constant value is set to all the unknows belonging to the given zone with name z_name. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_qov (cs_equation_param_t *eqp, const char *z_name, double quantity) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the value set to each unknown belonging to the given zone with name z_name is such that the integral over the cells of the zone returns the requested quantity. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Here the initial value for each unknown associated to the zone with name z_name is set according to an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_ic_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Define the initial condition for the unknown related to this equation. This definition applies to a volume zone. By default, the unknown is set to zero everywhere. Case of a definition by a DoF function. More... | |
| void | cs_equation_add_xdef_bc (cs_equation_param_t *eqp, cs_xdef_t *xdef) |
| Set a boundary condition from an existing cs_xdef_t structure The lifecycle of the cs_xdef_t structure is now managed by the current cs_equation_param_t structure. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_value (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_real_t *values) |
| Define and initialize a new structure to set a boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_array (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, const cs_lnum_t *index, const cs_lnum_t *ids) |
| cs_xdef_t * | cs_equation_add_bc_by_field (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_field_t *field) |
| cs_xdef_t * | cs_equation_add_bc_by_analytic (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_analytic_func_t *analytic, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given equation param structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More... | |
| cs_xdef_t * | cs_equation_add_bc_by_dof_func (cs_equation_param_t *eqp, const cs_param_bc_type_t bc_type, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Define and initialize a new structure to set a boundary condition related to the given cs_equation_param_t structure ml_name corresponds to the name of a pre-existing cs_mesh_location_t. More... | |
| cs_xdef_t * | cs_equation_find_bc (cs_equation_param_t *eqp, const char *z_name) |
| Return pointer to existing boundary condition definition structure for the given equation param structure and zone. More... | |
| void | cs_equation_remove_bc (cs_equation_param_t *eqp, const char *z_name) |
| Remove boundary condition from the given equation param structure for a given zone. More... | |
| void | cs_equation_add_sliding_condition (cs_equation_param_t *eqp, const char *z_name) |
| Define and initialize a new structure to set a sliding boundary condition related to the given equation structure z_name corresponds to the name of a pre-existing cs_zone_t. More... | |
| void | cs_equation_add_diffusion (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the Laplacian operator for the equation associated to the given cs_equation_param_t structure Laplacian means div-grad (either for vector-valued or scalar-valued equations) More... | |
| void | cs_equation_add_curlcurl (cs_equation_param_t *eqp, cs_property_t *property, int inversion) |
| Associate a new term related to the curl-curl operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_graddiv (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the grad-div operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_time (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the time derivative operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_advection (cs_equation_param_t *eqp, cs_adv_field_t *adv_field) |
| Associate a new term related to the advection operator for the equation associated to the given cs_equation_param_t structure. More... | |
| void | cs_equation_add_advection_scaling_property (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a scaling property to the advection. More... | |
| int | cs_equation_add_reaction (cs_equation_param_t *eqp, cs_property_t *property) |
| Associate a new term related to the reaction operator for the equation associated to the given cs_equation_param_t structure. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_val (cs_equation_param_t *eqp, const char *z_name, cs_real_t *val) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a constant value. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by a DoF function. More... | |
| cs_xdef_t * | cs_equation_add_source_term_by_array (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, const cs_lnum_t *index, const cs_lnum_t *ids) |
| Add a new source term by initializing a cs_xdef_t structure. Case of a definition by an array. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_value (cs_equation_param_t *eqp, const char *z_name, double *val) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant value. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_qov (cs_equation_param_t *eqp, const char *z_name, double *quantity) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a constant quantity distributed over the associated zone's volume. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_analytic (cs_equation_param_t *eqp, const char *z_name, cs_analytic_func_t *func, void *input) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using an analytical function. More... | |
| cs_xdef_t * | cs_equation_add_volume_mass_injection_by_dof_func (cs_equation_param_t *eqp, const char *z_name, cs_flag_t loc_flag, cs_dof_func_t *func, void *input) |
| Add a new volume mass injection definition source term by initializing a cs_xdef_t structure, using a DoF function. More... | |
| cs_enforcement_param_t * | cs_equation_add_vertex_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_vertices, const cs_lnum_t vertex_ids[], const cs_real_t ref_value[], const cs_real_t vtx_values[]) |
| Add an enforcement of the value of degrees of freedom located at the mesh vertices. The spatial discretization scheme for the given equation has to be CDO vertex-based or CDO vertex+cell-based schemes. More... | |
| cs_enforcement_param_t * | cs_equation_add_edge_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_edges, const cs_lnum_t edge_ids[], const cs_real_t ref_value[], const cs_real_t edge_values[]) |
| Add an enforcement of the value of degrees of freedom located at the mesh edges. The spatial discretization scheme for the given equation has to be CDO edge-based schemes. More... | |
| cs_enforcement_param_t * | cs_equation_add_face_dof_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t ref_value[], const cs_real_t face_values[]) |
| Add an enforcement of the value of degrees of freedom located at the mesh faces. The spatial discretization scheme for the given equation has to be CDO face-based schemes. More... | |
| cs_enforcement_param_t * | cs_equation_add_cell_enforcement (cs_equation_param_t *eqp, cs_lnum_t n_cells, const cs_lnum_t elt_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[]) |
| Add an enforcement of the value related to the degrees of freedom associated to the list of selected cells. More... | |
| cs_enforcement_param_t * | cs_equation_add_or_replace_cell_enforcement (cs_equation_param_t *eqp, int enforcement_id, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], const cs_real_t ref_value[], const cs_real_t cell_values[]) |
| Add a new enforcement if enforcement_id does not exist or replace it otherwise. Enforcement of the value related to the degrees of freedom associated to the list of selected cells. More... | |
| #define CS_EQUATION_BUILD_HOOK (1 << 9) /* 512 */ |
| #define CS_EQUATION_CONVECTION (1 << 2) /* 4 */ |
| #define CS_EQUATION_CURLCURL (1 << 4) /* 16 */ |
| #define CS_EQUATION_DIFFUSION (1 << 3) /* 8 */ |
| #define CS_EQUATION_FORCE_VALUES (1 << 7) /* 128 */ |
| #define CS_EQUATION_GRADDIV (1 << 5) /* 32 */ |
| #define CS_EQUATION_INSIDE_SYSTEM (1 << 8) /* 256 */ |
| #define CS_EQUATION_LOCKED (1 << 0) /* 1 */ |
| #define CS_EQUATION_POST_BALANCE (1 << 0) /* 1 */ |
| #define CS_EQUATION_POST_NORMAL_FLUX (1 << 3) /* 8 */ |
| #define CS_EQUATION_POST_PECLET (1 << 1) /* 2 */ |
| #define CS_EQUATION_POST_UPWIND_COEF (1 << 2) /* 4 */ |
| #define CS_EQUATION_REACTION (1 << 6) /* 64 */ |
| #define CS_EQUATION_UNSTEADY (1 << 1) /* 2 */ |
| #define CS_EQUATION_USER_TRIGGERED (1 << 10) /* 1024 */ |
| enum cs_equation_key_t |
List of available keys for setting the parameters of an equation.
| Enumerator | |
| CS_EQKEY_ADV_EXTRAPOL | Choice in the way to extrapolate the advection field when building the advection operator
| CS_EQKEY_ADV_FORMULATION | Kind of formulation of the advective term. Available choices are:
| CS_EQKEY_ADV_SCHEME | Type of numerical scheme for the advective term. The available choices depend on the space discretization scheme.
| CS_EQKEY_ADV_STRATEGY | Strategy used to handle the advection term
| CS_EQKEY_ADV_UPWIND_PORTION | Value between 0 and 1 specifying the portion of upwind added to a centered discretization. |
| CS_EQKEY_AMG_TYPE | Specify which type of algebraic multigrid (AMG) to choose. Available choices are:
| CS_EQKEY_BC_ENFORCEMENT | Set the type of enforcement of the boundary conditions. Available choices are:
For HHO and CDO-Face based schemes, only the "penalization" and "algebraic" technique is available up to now. |
| CS_EQKEY_BC_QUADRATURE | Set the quadrature algorithm used for evaluating integral quantities on faces or volumes. Available choices are:
Remark: "higher" and "highest" implies automatically a subdivision into tetrahedra of each cell. |
| CS_EQKEY_BC_STRONG_PENA_COEFF | Set the value of the penalization coefficient when "penalization" is activated The default value is 1e12. cf. CS_PARAM_BC_ENFORCE_PENALIZED |
| CS_EQKEY_BC_WEAK_PENA_COEFF | Set the value of the penalization coefficient when "weak" or "weak_sym" is activated. The default value is 100. cf. CS_PARAM_BC_ENFORCE_WEAK_NITSCHE or CS_PARAM_BC_ENFORCE_WEAK_SYM |
| CS_EQKEY_DO_LUMPING | |
| CS_EQKEY_DOF_REDUCTION | Set how is defined each degree of freedom (DoF).
| CS_EQKEY_EXTRA_OP | Set the additional post-processing to perform. Available choices are:
| CS_EQKEY_HODGE_DIFF_ALGO | Set the algorithm used for building the discrete Hodge operator used in the diffusion term. Available choices are:
| CS_EQKEY_HODGE_DIFF_COEF | This key is only useful if CS_EQKEY_HODGE_{TIME, DIFF, REAC}_ALGO is set to "cost". keyval is either a name or a value:
| CS_EQKEY_HODGE_TIME_ALGO | Set the algorithm used for building the discrete Hodge operator used in the unsteady term. Available choices are:
| CS_EQKEY_HODGE_REAC_ALGO | Set the algorithm used for building the discrete Hodge operator used in the reaction term. Available choices are:
| CS_EQKEY_ITSOL | Specify the iterative solver for solving the linear system related to an equation. Avalaible choices are:
| CS_EQKEY_ITSOL_EPS | Tolerance factor for stopping the iterative processus for solving the linear system related to an equation
| CS_EQKEY_ITSOL_MAX_ITER | Maximum number of iterations for solving the linear system
| CS_EQKEY_ITSOL_RESNORM_TYPE | Normalized or not the residual before testing if one continues iterating for solving the linear system. This normalization is performed before applying the boundary conditions to avoid handling the penalization of Dirichlet boundary conditions. If the RHS norm is equal to zero, then the "vol_tot" option is used for rescaling the residual. Available choices are: "false" or "none" (default) "rhs" "weighted_rhs" or "weighted" "filtered_rhs" or "filtered_rhs" |
| CS_EQKEY_ITSOL_RESTART | Maximum number of iterations before restarting a Krylov solver Only useful with GMRES, flexible GMRES or GCR solvers. This value has an impact on the memory footprint since one has to store a buffer of double with a size equal to restart*sizeof(solution array)
| CS_EQKEY_OMP_ASSEMBLY_STRATEGY | Choice of the way to perform the assembly when OpenMP is active Available choices are:
| CS_EQKEY_PRECOND | Specify the preconditioner associated to an iterative solver. Be careful some options are only available with a given solver class. Be sure that your installation has been installed with the appropriate library. Available choices are:
| CS_EQKEY_PRECOND_BLOCK_TYPE | Specify the type of block preconditioner associated to a preconditioner. When "full" is specified. That means that the smallest possible blocks are considered. Be careful: Most of these options are available only with PETSc/HYPRE. Available choices are:
| CS_EQKEY_SLES_VERBOSITY | Level of details written by the code for the resolution of the linear system
| CS_EQKEY_SOLVER_FAMILY | |
| CS_EQKEY_SPACE_SCHEME | Set the space discretization scheme. Available choices are:
| CS_EQKEY_TIME_SCHEME | Set the scheme for the temporal discretization. Available choices are:
| CS_EQKEY_TIME_THETA | Set a value betwwen 0 and 1 for the theta parameter when a "theta_scheme" is set for the time discretization. Only useful if CS_EQKEY_TIME_SCHEME is set to "theta_scheme".
| CS_EQKEY_VERBOSITY | Set the level of details written by the code for an equation. The higher the more detailed information is displayed.
| CS_EQKEY_N_KEYS | |
| enum cs_equation_type_t |
Type of equations managed by the solver.
| void cs_equation_add_advection | ( | cs_equation_param_t * | eqp, |
| cs_adv_field_t * | adv_field | ||
| [in,out] | eqp | pointer to a cs_equation_param_t structure |
| [in] | adv_field | pointer to a cs_adv_field_t structure |
| void cs_equation_add_advection_scaling_property | ( | cs_equation_param_t * | eqp, |
| cs_property_t * | property | ||
| [in] | property | pointer to a cs_property_t structure |
| cs_xdef_t* cs_equation_add_bc_by_analytic | ( | cs_equation_param_t * | eqp, |
| const cs_param_bc_type_t | bc_type, | ||
| const char * | z_name, | ||
| cs_analytic_func_t * | analytic, | ||
| void * | input | ||
| [in] | bc_type | type of boundary condition to add |
| [in] | z_name | name of the associated zone (if NULL or "" if all cells are considered) |
| [in] | analytic | pointer to an analytic function defining the value |
| cs_xdef_t* cs_equation_add_bc_by_array | ( | cs_equation_param_t * | eqp, |
| cs_flag_t | loc, | ||
| cs_real_t * | array, | ||
| bool | is_owner, | ||
| const cs_lnum_t * | index, | ||
| const cs_lnum_t * | ids | ||
| [in] | z_name | name of the related boundary zone |
| [in] | is_owner | transfer the lifecycle to the cs_xdef_t structure (true or false) |
| [in] | index | optional pointer to an array of index values |
| [in] | ids | optional pointer to a list of entity ids |
| cs_xdef_t* cs_equation_add_bc_by_dof_func | ( | cs_equation_param_t * | eqp, |
| cs_flag_t | loc_flag, | ||
| void * | input | ||
| [in] | loc_flag | location where values are computed |
| [in] | func | pointer to cs_dof_func_t function |
| cs_xdef_t* cs_equation_add_bc_by_field | ( | cs_equation_param_t * | eqp, |
| cs_field_t * | field | ||
| cs_xdef_t* cs_equation_add_bc_by_value | ( | cs_equation_param_t * | eqp, |
| cs_real_t * | values | ||
| [in] | values | pointer to a array storing the values |
| cs_enforcement_param_t* cs_equation_add_cell_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_cells, | ||
| const cs_real_t | ref_value[], | ||
| const cs_real_t | cell_values[] | ||
One assumes that values are interlaced if eqp->dim > 1 ref_value or elt_values has to be defined. If both parameters are defined, one keeps the definition in elt_values
| [in] | n_cells | number of selected cells |
| [in] | cell_ids | list of cell ids |
| [in] | ref_value | ignored if NULL |
| [in] | cell_values | list of associated values, ignored if NULL |
| void cs_equation_add_curlcurl | ( | cs_equation_param_t * | eqp, |
| cs_property_t * | property, | ||
| int | inversion | ||
| [in] | inversion | 1: true, false otherwise |
| [in] | inversion | > 0: true, false otherwise |
| void cs_equation_add_diffusion | ( | cs_equation_param_t * | eqp, |
| cs_enforcement_param_t* cs_equation_add_edge_dof_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_edges, | ||
| const cs_lnum_t | edge_ids[], | ||
| const cs_real_t | edge_values[] | ||
| [in] | n_edges | number of edges to enforce |
| [in] | edge_ids | list of edges |
| [in] | ref_value | default values or ignored (may be NULL) |
| [in] | edge_values | list of associated values, ignored if NULL |
| cs_enforcement_param_t* cs_equation_add_face_dof_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_faces, | ||
| const cs_lnum_t | face_ids[], | ||
| const cs_real_t | face_values[] | ||
| [in] | n_faces | number of faces to enforce |
| [in] | face_ids | list of faces |
| [in] | face_values | list of associated values, ignored if NULL |
| void cs_equation_add_graddiv | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t* cs_equation_add_ic_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | analytic | pointer to an analytic function |
| cs_xdef_t* cs_equation_add_ic_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | loc_flag | where information is computed |
| [in] | func | pointer to a DoF function |
| cs_xdef_t* cs_equation_add_ic_by_qov | ( | cs_equation_param_t * | eqp, |
| double | quantity | ||
| [in] | z_name | name of the associated zone (if NULL or "" all cells are considered) |
| [in] | quantity | quantity to distribute over the mesh location |
| cs_xdef_t* cs_equation_add_ic_by_value | ( | cs_equation_param_t * | eqp, |
| cs_real_t * | val | ||
| [in] | val | pointer to the value |
| cs_enforcement_param_t* cs_equation_add_or_replace_cell_enforcement | ( | cs_equation_param_t * | eqp, |
| int | enforcement_id, | ||
| [in] | enforcement_id | id of the enforcement to handle |
| int cs_equation_add_reaction | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_sliding_condition | ( | cs_equation_param_t * | eqp, |
| const char * | z_name | ||
| cs_xdef_t* cs_equation_add_source_term_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | func | pointer to an analytical function |
| cs_xdef_t* cs_equation_add_source_term_by_array | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t* cs_equation_add_source_term_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| [in] | loc_flag | location of element ids given as parameter |
| cs_xdef_t* cs_equation_add_source_term_by_val | ( | cs_equation_param_t * | eqp, |
| void cs_equation_add_time | ( | cs_equation_param_t * | eqp, |
| cs_enforcement_param_t* cs_equation_add_vertex_dof_enforcement | ( | cs_equation_param_t * | eqp, |
| cs_lnum_t | n_vertices, | ||
| const cs_lnum_t | vertex_ids[], | ||
| const cs_real_t | vtx_values[] | ||
| [in] | n_vertices | number of vertices to enforce |
| [in] | vertex_ids | list of vertices |
| [in] | vtx_values | list of associated values, ignored if NULL |
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_analytic | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_dof_func | ( | cs_equation_param_t * | eqp, |
| void * | input | ||
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_qov | ( | cs_equation_param_t * | eqp, |
| double * | quantity | ||
| [in] | quantity | pointer to quantity to distribute over the zone |
| cs_xdef_t* cs_equation_add_volume_mass_injection_by_value | ( | cs_equation_param_t * | eqp, |
| double * | val | ||
| void cs_equation_add_xdef_bc | ( | cs_equation_param_t * | eqp, |
| cs_xdef_t * | xdef | ||
| [in] | xdef | pointer to the cs_xdef_t structure to transfer |
inlinestatic |
The cs_equation_param_t structure itself is not freed, but all its sub-structures are freed.
This is useful for equation parameters which are accessed through field keywords.
| [in,out] | eqp | pointer to a cs_equation_param_t |
inlinestatic |
| [in] | ref | pointer to the reference cs_equation_param_t |
| [in,out] | dst | pointer to the cs_equation_param_t to update |
| [in] | copy_fid | copy also the field id or not |
inlinestatic |
| [in] | name | name of the equation |
| [in] | type | type of equation |
| [in] | dim | dim of the variable associated to this equation |
| [in] | default_bc | type of boundary condition set by default |
| cs_xdef_t* cs_equation_find_bc | ( | cs_equation_param_t * | eqp, |
inlinestatic |
| [in] | eqp | pointer to a cs_equation_param_t |
| void cs_equation_param_clear | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_param_copy_bc | ( | const cs_equation_param_t * | ref, |
| cs_equation_param_t * | dst | ||
| void cs_equation_param_copy_from | ( | const cs_equation_param_t * | ref, |
| cs_equation_param_t * | dst, | ||
| bool | copy_fid | ||
| cs_equation_param_t* cs_equation_param_create | ( | const char * | name, |
| cs_equation_type_t | type, | ||
| int | dim, | ||
| cs_param_bc_type_t | default_bc | ||
| cs_equation_param_t* cs_equation_param_free | ( | cs_equation_param_t * | eqp | ) |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
| bool cs_equation_param_has_robin_bc | ( | const cs_equation_param_t * | eqp | ) |
inlinestatic |
inlinestatic |
inlinestatic |
| void cs_equation_param_last_stage | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_param_log | ( | const cs_equation_param_t * | eqp | ) |
| void cs_equation_param_set | ( | cs_equation_param_t * | eqp, |
| cs_equation_key_t | key, | ||
| const char * | keyval | ||
inlinestatic |
| [in] | flag | flag to add |
| void cs_equation_param_set_sles | ( | cs_equation_param_t * | eqp | ) |
| void cs_equation_remove_bc | ( | cs_equation_param_t * | eqp, |
If no matching boundary condition is found, the function returns silently.
inlinestatic |
