7.2
cs_param_cdo.h
1 #ifndef __CS_PARAM_CDO_H__
2 #define __CS_PARAM_CDO_H__
5  * Manage the definition/setting of a computation
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
44 /* Specifications for OpenMP loops */
45
46 #define CS_CDO_OMP_CHUNK_SIZE 128
47 #define CS_CDO_OMP_SCHEDULE schedule(static, CS_CDO_OMP_CHUNK_SIZE)
48 #define CS_CDO_OMP_SYNC_SECTIONS 0 /* > 0 --> critical sections
49  otherwise atomic sections */
50
51 /* Avoid issues with assert in some OpenMp contructs using gcc 9 */
52
53 #if defined(HAVE_OPENMP) && defined(__GNUC__)
54  #if __GNUC__ == 9
55  #define CS_CDO_OMP_ASSERT(e)
56  #else
57  #define CS_CDO_OMP_ASSERT(e) assert(e)
58  #endif
59 #else
60  #define CS_CDO_OMP_ASSERT(e) assert(e)
61 #endif
62
63 /* Size of the buffer used to collect global ids for rows and columns
64  when assembling the values in the global matrix from the local cellwise
65  matrices */
66
67 #define CS_CDO_ASSEMBLE_BUF_SIZE 200
68
69 /* The following limitation only results from an optimization in the size of
70  the bit mask (can be changed if needed by changing the definition of
71  the type cs_mask_t)
72  Here is the max. number of reaction terms allowed in an equation */
73
74 #define CS_CDO_N_MAX_REACTIONS 8
75
76 #define CS_ALL_FACES 0 /* All faces: interior + border */
77 #define CS_BND_FACES 1 /* Boundary faces */
78 #define CS_INT_FACES 2 /* Interior faces */
79
80 /* Number of DoFs on faces and cells according to the polynomial space */
81
82 #define CS_N_DOFS_FACE_0TH 1
83 #define CS_N_DOFS_FACE_1ST 3
84 #define CS_N_DOFS_FACE_2ND 6
85
86 #define CS_N_DOFS_CELL_0TH 1
87 #define CS_N_DOFS_CELL_1ST 4
88 #define CS_N_DOFS_CELL_2ND 10
89
90 /*============================================================================
91  * Type definitions
92  *============================================================================*/
93
94 /* OpenMP STRATEGY FOR THE ASSEMBLY STEP */
95 /* ===================================== */
96
97 typedef enum {
98
102
104
105 /*============================================================================
106  * Global variables
107  *============================================================================*/
108
109 /*============================================================================
110  * Public function prototypes
111  *============================================================================*/
112
113 /*----------------------------------------------------------------------------*/
114
116
117 #endif /* __CS_PARAM_CDO_H__ */
Definition: cs_param_cdo.h:99
cs_param_assemble_omp_strategy_t
Definition: cs_param_cdo.h:97
Definition: cs_param_cdo.h:101
Definition: cs_param_cdo.h:100
